[PATCH] Add raspberry pi board BSP
Cudmore, Alan P. (GSFC-5820) alan.p.cudmore at nasa.gov
Mon Feb 25 17:22:19 UTC 2013
Thanks.. This is not something I need to do now, I'm just curious. I am less than a git beginner right now.
Alan
On Feb 25, 2013, at 12:06 PM, Joel Sherrill <joel.sherrill at oarcorp.com> wrote:
> On 2/25/2013 10:58 AM, Cláudio Silva wrote:
>> You could also fork it on github, make your changes and then make a
>> pull request. I don't know if the maintainers currently advise it but
>> it is a technical possibility. I think it has been done in the past
>> for GSOC2012 projects.
> That should work.
> The biggest issue is that we are all still learning git. I don't know
> that we
> have pulled from github yet. But I am willing to try it.
> --joel
>> On Mon, Feb 25, 2013 at 4:29 PM, Joel Sherrill
>>> On 2/25/2013 10:17 AM, Cudmore, Alan P. (GSFC-5820) wrote:
>>>> I'm just learning Git, but wouldn't it be nice if RTEMS developers could
>>>> fork a repo, make changes and have an online code review using a tool like
>>>> Gerrit? http://code.google.com/p/gerrit/
>>> Yes! It is on my wishlist. :)
>>> I think it would make BSP reviews, GSOC, GCI, etc. easier.
>>> My understanding is that we want a Buildbot in place before putting
>>> an online code review took in the workflow.
>>> --joel
>>>> Alan
>>>> On Feb 25, 2013, at 10:06 AM, Gedare Bloom <gedare at rtems.org> wrote:
>>>>> Hi Alan,
>>>>> I've made a few comments. Some repeated issues are the $Id$ which we
>>>>> got rid of now, and there were a lot of copy-pasted file comments that
>>>>> might be a little inaccurate, or that you should update the copyright
>>>>> and add your own authorship info to.
>>>>> -Gedare
>>>>> On Sun, Feb 24, 2013 at 8:41 PM, Cudmore, Alan P. (GSFC-5820)
>>>>> <alan.p.cudmore at nasa.gov> wrote:
>>>>>> This patch is my Raspberry Pi BSP.
>>>>>> - Based on the lpc32xx BSP ( no libcpu ). I removed the MMU setup code,
>>>>>> it could probably be added back in
>>>>>> - Interrupt driven console code is included, but does not work yet. The
>>>>>> polled driver works.
>>>>>> - The benchmark timer driver does not work yet, I was trying to
>>>>>> troubleshoot that this weekend.
>>>>>> - It was compiled and tested with the rtems-4.11 ( non-eabi ) toolchain.
>>>>>> Alan
>>>>>> diff --git a/c/src/lib/libbsp/arm/acinclude.m4
>>>>>> b/c/src/lib/libbsp/arm/acinclude.m4
>>>>>> index 9512b26..82aba6f 100644
>>>>>> --- a/c/src/lib/libbsp/arm/acinclude.m4
>>>>>> +++ b/c/src/lib/libbsp/arm/acinclude.m4
>>>>>> @@ -24,6 +24,8 @@ AC_DEFUN([RTEMS_CHECK_BSPDIR],
>>>>>>      AC_CONFIG_SUBDIRS([lpc32xx]);;
>>>>>>    nds )
>>>>>>      AC_CONFIG_SUBDIRS([nds]);;
>>>>>> +  raspberry_pi )
>>>>>> +    AC_CONFIG_SUBDIRS([raspberry_pi]);;
>>>>> do we have any other BSPs with an underscore in the name? maybe just
>>>>> "raspberrypi" or even just "pi" would be ok?
>>>>>>    rtl22xx )
>>>>>>      AC_CONFIG_SUBDIRS([rtl22xx]);;
>>>>>>    smdk2410 )
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/ChangeLog
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/ChangeLog
>>>>>> new file mode 100755
>>>>>> index 0000000..3b85dbb
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/ChangeLog
>>>>>> @@ -0,0 +1,4 @@
>>>>>> +2013-02-15     Alan Cudmores <alan.cudmore at gmail.com>
>>>>>> +       * created raspberry_pi bsp from lpc32xx
>>>>> We don't use ChangeLog anymore. Instead we rely on git commit messages.
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/Makefile.am
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/Makefile.am
>>>>>> index 0000000..f19ad95
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/Makefile.am
>>>>>> @@ -0,0 +1,151 @@
>>>>>> +# @file
>>>>>> +# @brief Makefile of LibBSP for the raspberry_pi board.
>>>>>> +# $Id: Makefile.am,v 1.5 2010/05/20 13:15:35 sh Exp $
>>>>> We don't use $Id$ anymore. Please remove any of these.
>>>>>> +ACLOCAL_AMFLAGS = -I ../../../../aclocal
>>>>>> +include $(top_srcdir)/../../../../automake/compile.am
>>>>>> +include_bspdir = $(includedir)/bsp
>>>>>> +include_libcpudir = $(includedir)/libcpu
>>>>>> +dist_project_lib_DATA = bsp_specs
>>>>>> +#                  Header
>>>>>> +include_HEADERS = include/bsp.h
>>>>>> +include_HEADERS += ../../shared/include/tm27.h
>>>>>> +nodist_include_HEADERS = ../../shared/include/coverhd.h \
>>>>>> +       include/bspopts.h
>>>>>> +nodist_include_bsp_HEADERS = ../../shared/include/bootcard.h
>>>>>> +include_bsp_HEADERS =
>>>>>> +include_bsp_HEADERS += ../../shared/include/utility.h
>>>>>> +include_bsp_HEADERS += ../../shared/include/irq-generic.h
>>>>>> +include_bsp_HEADERS += ../../shared/include/irq-info.h
>>>>>> +include_bsp_HEADERS += ../../shared/include/stackalloc.h
>>>>>> +include_bsp_HEADERS += ../../shared/include/uart-output-char.h
>>>>>> +include_bsp_HEADERS += ../../shared/tod.h
>>>>>> +include_bsp_HEADERS += ../shared/include/linker-symbols.h
>>>>>> +include_bsp_HEADERS += ../shared/include/start.h
>>>>>> +include_bsp_HEADERS += ../shared/lpc/include/lpc-timer.h
>>>>>> +include_bsp_HEADERS += ../shared/lpc/include/lpc-dma.h
>>>>>> +include_bsp_HEADERS += include/irq.h
>>>>>> +include_bsp_HEADERS += include/mmu.h
>>>>>> +include_bsp_HEADERS += include/raspberry_pi.h
>>>>>> +include_libcpu_HEADERS = ../../../libcpu/arm/shared/include/cache_.h \
>>>>>> +       ../../../libcpu/arm/shared/include/arm-cp15.h
>>>>>> +#                  Data
>>>>>> +noinst_LIBRARIES = libbspstart.a
>>>>>> +libbspstart_a_SOURCES = ../shared/start/start.S
>>>>>> +project_lib_DATA = start.$(OBJEXT)
>>>>>> +project_lib_DATA += startup/linkcmds
>>>>>> +project_lib_DATA += ../shared/startup/linkcmds.base
>>>>>> +EXTRA_DIST = startup/linkcmds
>>>>>> +#                  LibBSP
>>>>>> +noinst_LIBRARIES += libbsp.a
>>>>>> +libbsp_a_SOURCES =
>>>>>> +libbsp_a_CPPFLAGS =
>>>>>> +libbsp_a_LIBADD =
>>>>>> +# Shared
>>>>>> +libbsp_a_SOURCES += ../../shared/bootcard.c
>>>>>> +libbsp_a_SOURCES += ../../shared/bspclean.c
>>>>>> +libbsp_a_SOURCES += ../../shared/bspgetworkarea.c
>>>>>> +libbsp_a_SOURCES += ../../shared/bsplibc.c
>>>>>> +libbsp_a_SOURCES += ../../shared/bsppost.c
>>>>>> +libbsp_a_SOURCES += ../../shared/bsppredriverhook.c
>>>>>> +libbsp_a_SOURCES += ../../shared/bsppretaskinghook.c
>>>>>> +libbsp_a_SOURCES += ../../shared/gnatinstallhandler.c
>>>>>> +libbsp_a_SOURCES += ../../shared/sbrk.c
>>>>>> +libbsp_a_SOURCES += ../../shared/src/stackalloc.c
>>>>>> +libbsp_a_SOURCES += ../shared/abort/simple_abort.c
>>>>>> +libbsp_a_SOURCES += ../shared/startup/bsp-start-memcpy.S
>>>>>> +# libbsp_a_SOURCES += ../../shared/src/uart-output-char.c
>>>>>> +# Startup
>>>>>> +libbsp_a_SOURCES += startup/bspreset.c
>>>>>> +libbsp_a_SOURCES += startup/bspstart.c
>>>>>> +# IRQ
>>>>>> +libbsp_a_SOURCES += ../../shared/src/irq-default-handler.c
>>>>>> +libbsp_a_SOURCES += ../../shared/src/irq-generic.c
>>>>>> +libbsp_a_SOURCES += ../../shared/src/irq-info.c
>>>>>> +libbsp_a_SOURCES += ../../shared/src/irq-legacy.c
>>>>>> +libbsp_a_SOURCES += ../../shared/src/irq-server.c
>>>>>> +libbsp_a_SOURCES += ../../shared/src/irq-shell.c
>>>>>> +libbsp_a_SOURCES += irq/irq.c
>>>>>> +# Console
>>>>>> +libbsp_a_SOURCES += console/console.c
>>>>>> +# clock
>>>>>> +libbsp_a_SOURCES += clock/clockdrv.c ../../../shared/clockdrv_shell.h
>>>>>> +# Timer
>>>>>> +libbsp_a_SOURCES += misc/timer.c
>>>>>> +# RTC
>>>>>> +# SSP
>>>>>> +# I2C
>>>>>> +# Cache
>>>>>> +libbsp_a_SOURCES += ../../../libcpu/shared/src/cache_manager.c
>>>>>> +libbsp_a_SOURCES += ../../../libcpu/arm/shared/include/cache_.h
>>>>>> +libbsp_a_CPPFLAGS += -I$(srcdir)/../../../libcpu/arm/shared/include
>>>>>> +# Start hooks
>>>>>> +libbsp_a_SOURCES += startup/bspstarthooks.c
>>>>>> +#                  Network
>>>>>> +#if HAS_NETWORKING
>>>>>> +#noinst_PROGRAMS = network.rel
>>>>>> +#network_rel_SOURCES = ../shared/lpc/network/lpc-ethernet.c
>>>>>> +#network_rel_CPPFLAGS = $(AM_CPPFLAGS)
>>>>>> -D__INSIDE_RTEMS_BSD_TCPIP_STACK__ -D__BSD_VISIBLE
>>>>>> +#network_rel_LDFLAGS = $(RTEMS_RELLDFLAGS)
>>>>>> +#libbsp_a_LIBADD += network.rel
>>>>>> +#endif
>>>>>> +#                  Special Rules
>>>>>> +DISTCLEANFILES = include/bspopts.h
>>>>>> +include $(srcdir)/preinstall.am
>>>>>> +include $(top_srcdir)/../../../../automake/local.am
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/README
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/README
>>>>>> index 0000000..7c92d55
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/README
>>>>>> @@ -0,0 +1,65 @@
>>>>>> +BSP for the Raspberry Pi ARM board
>>>>>> +This is a basic port that should work on either Model A or Model B.
>>>>>> +It currently supports the following devices:
>>>>>> +    o Console using the PL011 UART0
>>>>>> +       The console driver only works with polled mode right now,
>>>>>> +       the interrupt code is there, but it does not work yet.
>>>>>> +       The console driver is currently hardcoded at 115k 8N1
>>>>>> +    o Clock uses the internal ARM timer
>>>>>> +       The Raspberry Pi can be overclocked through the config.txt file,
>>>>>> this
>>>>>> +       would affect the duration of the clock tick.
>>>>>> +    o Benchmark timer reads the lower 32 bit GPU timer register
>>>>>> +To run an RTEMS binary, it must be stripped and loaded on the SD card
>>>>>> along with
>>>>>> +the following files:
>>>>>> +  bootcode.bin
>>>>>> +  config.txt
>>>>>> +  loader.bin
>>>>>> +  start.elf
>>>>>> +  kernel.img ( the RTEMS binary, you can change the name in config.txt
>>>>>> +These files can be obtained from a Linux installation image, or from
>>>>>> here:
>>>>>> +https://github.com/raspberrypi/firmware
>>>>>> +I used an old 256MB SD card to boot RTEMS.
>>>>>> +Much more information about the SD card file and bootloader can be
>>>>>> found here:
>>>>>> +http://elinux.org/RPi_Hub
>>>>>> +http://www.raspberrypi.org
>>>>>> +The linker script is set up for 128MB, so it can be used with a GPU/ARM
>>>>>> split
>>>>>> +of 128/128.
>>>>>> +The bootloader that is used on the SD card determines the split of RAM
>>>>>> between the
>>>>>> +ARM and the GPU. It might make sense to adjust the GPU/ARM memory split
>>>>>> to give
>>>>>> +more memory to RTEMS, especially on a 512MB board.
>>>>>> +To do:
>>>>>> +    It would be nice to get support in the BSP for the following:
>>>>>> +    o SD card
>>>>>> +    o USB and USB 10/100 network chip on Model B
>>>>>> +    o SPI
>>>>>> +    o GPIO
>>>>>> +    o ARM MMU
>>>>>> +    o Graphics console
>>>>>> +    o Sound
>>>>>> +Credits and links:
>>>>>> +  There is a wealth of code and information to reference on the
>>>>>> raspberrypi.org bare metal forums:
>>>>>> +  http://www.raspberrypi.org/phpBB3/viewforum.php?f=72
>>>>>> +  I found information about how to program the timers, interrupts, and
>>>>>> UART 0
>>>>>> +  from the examples provided by:
>>>>>> +  David Welch:
>>>>>> +  https://github.com/dwelch67/raspberrypi
>>>>>> +  The readme file at his github repository has valuable information
>>>>>> about connecting a UART cable, JTAG etc.
>>>>>> +  Steve Bate:
>>>>>> +  http://www.stevebate.net/chibios-rpi/GettingStarted.html
>>>>>> +  Steve provided a port of the Chibios RTOS to the raspberry Pi
>>>>>> +  James Walmsley:
>>>>>> +  http://www.raspberrypi.org/phpBB3/viewtopic.php?f=72&t=22423
>>>>>> +  James ported FreeRTOS to the raspberry Pi.
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/bsp_specs
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/bsp_specs
>>>>>> index 0000000..082653a
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/bsp_specs
>>>>>> @@ -0,0 +1,13 @@
>>>>>> +%rename endfile old_endfile
>>>>>> +%rename startfile old_startfile
>>>>>> +%rename link old_link
>>>>>> +*startfile:
>>>>>> +%{!qrtems: %(old_startfile)} \
>>>>>> +%{!nostdlib: %{qrtems: start.o%s crti.o%s crtbegin.o%s -e _start}}
>>>>>> +*link:
>>>>>> +%{!qrtems: %(old_link)} %{qrtems: -dc -dp -N}
>>>>>> +*endfile:
>>>>>> +%{!qrtems: *(old_endfiles)} %{qrtems: crtend.o%s crtn.o%s }
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/clock/clockdrv.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/clock/clockdrv.c
>>>>>> index 0000000..63017fb
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/clock/clockdrv.c
>>>>>> @@ -0,0 +1,97 @@
>>>>>> + * BCM2835 Clock driver
>>>>>> + * Copyright (c) 2002 by Jay Monkman <jtm at smoothsmoothie.com>
>>>>>> + *  The license and distribution terms for this file may be
>>>>>> + *  found in the file LICENSE in this distribution or at
>>>>>> + *  http://www.rtems.com/license/LICENSE.
>>>>> Delete the blank line here.
>>>>>> + *  $Id: clockdrv.c,v 1.13 2010/04/30 14:48:52 sh Exp $
>>>>> Deleyte the $Id$ and extra blank lines.
>>>>>> +#include <rtems.h>
>>>>>> +#include <bsp.h>
>>>>>> +#include <bsp/irq.h>
>>>>>> +#include <bsp/irq-generic.h>
>>>>>> +#include <bsp/raspberry_pi.h>
>>>>>> +#define CLOCK_VECTOR 0
>>>>>> +void Clock_isr(rtems_irq_hdl_param arg);
>>>>>> +static void clock_isr_on(const rtems_irq_connect_data *unused);
>>>>>> +static void clock_isr_off(const rtems_irq_connect_data *unused);
>>>>>> +static int clock_isr_is_on(const rtems_irq_connect_data *irq);
>>>>>> +uint32_t clock_driver_get_nanoseconds_since_last_tick(void);
>>>>>> +rtems_irq_connect_data clock_isr_data =
>>>>>> +        BCM2835_IRQ_ID_TIMER_0 ,
>>>>>> +        (rtems_irq_hdl)Clock_isr,
>>>>>> +        NULL,
>>>>>> +        clock_isr_on,
>>>>>> +        clock_isr_off,
>>>>>> +        clock_isr_is_on
>>>>>> +#define Clock_driver_support_at_tick()        \
>>>>>> +  do {                                        \
>>>>>> +         BCM2835_REG(BCM2835_TIMER_CLI) = 0;  \
>>>>>> +  } while(0)
>>>>>> +#define Clock_driver_support_install_isr( _new, _old ) \
>>>>>> +  do {                                                 \
>>>>>> +      (_old) = NULL; /* avoid warning */;              \
>>>>>> +      BSP_install_rtems_irq_handler(&clock_isr_data);  \
>>>>>> +  } while(0)
>>>>>> + * Set up the clock hardware
>>>>>> +#define Clock_driver_support_initialize_hardware()  \
>>>>>> +  do { \
>>>>>> +           BCM2835_REG(BCM2835_TIMER_CTL) = 0x003E0000;             \
>>>>>> +           BCM2835_REG(BCM2835_TIMER_LOD) = 10000 - 1;              \
>>>>>> +           BCM2835_REG(BCM2835_TIMER_RLD) = 10000 - 1;              \
>>>>>> +           BCM2835_REG(BCM2835_TIMER_DIV) = BCM2835_TIMER_PRESCALE; \
>>>>>> +           BCM2835_REG(BCM2835_TIMER_CTL) = 0x003E00A2;             \
>>>>>> +  } while (0)
>>>>>> +#define Clock_driver_support_shutdown_hardware()    \
>>>>>> +  do {                                              \
>>>>>> +    BSP_remove_rtems_irq_handler(&clock_isr_data);  \
>>>>>> +  } while (0)
>>>>>> + *  Return the nanoseconds since last tick
>>>>>> +  return 0;
>>>>>> +#define Clock_driver_nanoseconds_since_last_tick \
>>>>>> +  clock_driver_get_nanoseconds_since_last_tick
>>>>>> +    bsp_interrupt_vector_enable(BCM2835_IRQ_ID_TIMER_0);
>>>>>> +    return;
>>>>>> +    bsp_interrupt_vector_disable(BCM2835_IRQ_ID_TIMER_0);
>>>>>> +    return;
>>>>>> +    return 1;
>>>>>> +#include "../../../shared/clockdrv_shell.h"
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/configure.ac
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/configure.ac
>>>>>> index 0000000..cfb1918
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/configure.ac
>>>>>> @@ -0,0 +1,31 @@
>>>>>> +# @file
>>>>>> +# @brief Configure script of LibBSP for the Raspberry Pi boards.
>>>>>> +AC_PREREQ([2.68])
>>>>>> +AC_INIT([rtems-c-src-lib-libbsp-arm-raspberry_pi],[_RTEMS_VERSION],[rtems-bugs at rtems.com])
>>>>> Change the rtems-bugs at rtems.com to  http://www.rtems.org/bugzilla
>>>>>> +AC_CONFIG_SRCDIR([bsp_specs])
>>>>>> +RTEMS_TOP(../../../../../..)
>>>>>> +RTEMS_CANONICAL_TARGET_CPU
>>>>>> +AM_INIT_AUTOMAKE([no-define nostdinc foreign 1.11.1])
>>>>> Bump this to 1.12.2 I think we are on now.
>>>>>> +RTEMS_BSP_CONFIGURE
>>>>>> +RTEMS_PROG_CC_FOR_TARGET
>>>>>> +RTEMS_CANONICALIZE_TOOLS
>>>>>> +RTEMS_PROG_CCAS
>>>>>> +RTEMS_CHECK_NETWORKING
>>>>>> +AM_CONDITIONAL(HAS_NETWORKING,test "$HAS_NETWORKING" = "yes")
>>>>>> +RTEMS_BSPOPTS_SET([BSP_START_RESET_VECTOR],[*],[])
>>>>>> +RTEMS_BSPOPTS_HELP([BSP_START_RESET_VECTOR],[reset vector address for
>>>>>> BSP start])
>>>>>> +RTEMS_BSP_CLEANUP_OPTIONS(0, 0)
>>>>>> +RTEMS_BSP_LINKCMDS
>>>>>> +AC_CONFIG_FILES([Makefile])
>>>>>> +AC_OUTPUT
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/console/console.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/console/console.c
>>>>>> index 0000000..5156737
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/console/console.c
>>>>>> @@ -0,0 +1,457 @@
>>>>>> + * Console driver for the Raspberry Pi PL011 UART0
>>>>>> + * Based on a driver by Jay Monkman <jtm at lopingdog.com>
>>>>>> + * Copyright (c) 2005 by Loping Dog Embedded Systems
>>>>>> + * $Id: uart.c,v 1.9 2010/04/30 14:40:16 sh Exp $
>>>>> Remove $Id$
>>>>>> +#include <bsp.h>
>>>>>> +#include <rtems/libio.h>
>>>>>> +#include <libchip/sersupp.h>
>>>>>> +#include <rtems/error.h>
>>>>>> +#include <rtems/bspIo.h>
>>>>>> +#include <termios.h>
>>>>>> +#include <rtems/irq.h>
>>>>>> +#include <bsp/uart-output-char.h>
>>>>>> +/* Define this to use interrupt driver UART driver */
>>>>>> +/* Note: The interrupt driver does not currently work */
>>>>>> +/* #define USE_INTERRUPTS  1 */
>>>>>> +#undef USE_INTERRUPTS
>>>>>> +#define poll_write(c)  uart0_poll_write_char(0, c)
>>>>>> +#define poll_read()    uart0_poll_read_char(0)
>>>>>> +int   _BSP_poll_char(void);
>>>>>> +void  _BSP_output_char(char c);
>>>>>> +int   uart0_poll_read_char(int minor);
>>>>>> +void  uart0_poll_write_char(int minor, char c);
>>>>>> +static int uart0_first_open(int, int, void *);
>>>>>> +static int uart0_last_close(int, int, void *);
>>>>>> +static int uart0_poll_read(int);
>>>>>> +static int uart0_set_attrs(int, const struct termios *);
>>>>>> +static void uart0_init(int minor);
>>>>>> +static void uart0_set_baud(int, int);
>>>>>> +static ssize_t uart0_poll_write(int, const char *, size_t);
>>>>>> +#if defined(USE_INTERRUPTS)
>>>>>> +static void uart0_isr(rtems_irq_hdl_param);
>>>>>> +static void uart0_isr_on(const rtems_irq_connect_data *irq);
>>>>>> +static void uart0_isr_off(const rtems_irq_connect_data *irq);
>>>>>> +static int  uart0_isr_is_on(const rtems_irq_connect_data *irq);
>>>>>> +static ssize_t uart0_intr_write(int, const char *, size_t);
>>>>>> +#endif
>>>>>> +/* TERMIOS callbacks */
>>>>>> +rtems_termios_callbacks uart0_cbacks =
>>>>>> +    .firstOpen            = uart0_first_open,
>>>>>> +    .lastClose            = uart0_last_close,
>>>>>> +    .pollRead             = NULL,
>>>>>> +    .write                = uart0_intr_write,
>>>>>> +    .setAttributes        = uart0_set_attrs,
>>>>>> +    .stopRemoteTx         = NULL,
>>>>>> +    .startRemoteTx        = NULL,
>>>>>> +    .outputUsesInterrupts = 1,
>>>>>> +#else
>>>>>> +    .pollRead             = uart0_poll_read,
>>>>>> +    .write                = uart0_poll_write,
>>>>>> +    .outputUsesInterrupts = 0,
>>>>>> +#endif
>>>>>> +static rtems_irq_connect_data uart0_isr_data;
>>>>>> +#endif
>>>>>> +typedef struct
>>>>>> +    int                    minor;
>>>>>> +    volatile const char  * buf;
>>>>>> +    volatile int           len;
>>>>>> +    volatile int           idx;
>>>>>> +    void                 * tty;
>>>>>> +} uart0_data_t;
>>>>>> +static uart0_data_t uart0_data;
>>>>>> +static void uart0_delay(uint32_t n)
>>>>>> +    volatile uint32_t i = 0;
>>>>>> +    for(i = 0; i < n; i++);
>>>>>> +rtems_device_driver console_initialize(
>>>>>> +    rtems_device_major_number  major,
>>>>>> +    rtems_device_minor_number  minor,
>>>>>> +    void                      *arg
>>>>>> +    rtems_status_code status;
>>>>>> +    uart0_init(0);
>>>>>> +    rtems_termios_initialize();
>>>>>> +    /* /dev/console and /dev/tty0 are the same */
>>>>>> +    status = rtems_io_register_name("/dev/console", major, 0);
>>>>>> +    if (status != RTEMS_SUCCESSFUL)
>>>>>> +        rtems_panic("%s:%d Error registering /dev/console :: %d\n",
>>>>>> +                    __FUNCTION__, __LINE__, status);
>>>>>> +    status = rtems_io_register_name("/dev/tty0", major, 0);
>>>>>> +        rtems_panic("%s:%d Error registering /dev/tty0 :: %d\n",
>>>>>> +    return RTEMS_SUCCESSFUL;
>>>>>> +rtems_device_driver console_open(
>>>>>> +    void                    * arg
>>>>>> +    rtems_status_code rc;
>>>>>> +    if (minor > 0)
>>>>>> +        return RTEMS_INVALID_NUMBER;
>>>>>> +    rc = rtems_termios_open(major, minor, arg, &uart0_cbacks);
>>>>>> +    return rc;
>>>>>> +rtems_device_driver console_close(
>>>>>> +    void                    * arg
>>>>>> +    return rtems_termios_close(arg);
>>>>>> +rtems_device_driver console_read(
>>>>>> +    void                    * arg
>>>>>> +  return rtems_termios_read(arg);
>>>>>> +rtems_device_driver console_write(
>>>>>> +    void                    * arg
>>>>>> +  return rtems_termios_write(arg);
>>>>>> +rtems_device_driver console_control(
>>>>>> +    void                    * arg
>>>>>> +  return rtems_termios_ioctl(arg);
>>>>>> +    unsigned int gpio_reg;
>>>>>> +    uart0_data.minor = minor;
>>>>>> +    uart0_data.buf   = NULL;
>>>>>> +    uart0_data.len   = 0;
>>>>>> +    uart0_data.idx   = 0;
>>>>>> +    uart0_isr_data.name   = BCM2835_IRQ_ID_UART;
>>>>>> +    uart0_isr_data.hdl    = uart0_isr;
>>>>>> +    uart0_isr_data.handle = &uart0_data;
>>>>>> +    uart0_isr_data.on     = uart0_isr_on;
>>>>>> +    uart0_isr_data.off    = uart0_isr_off;
>>>>>> +    uart0_isr_data.isOn   = uart0_isr_is_on;
>>>>>> +#endif
>>>>>> +    ** Program GPIO pins for UART 0
>>>>>> +    gpio_reg = BCM2835_REG(BCM2835_GPIO_GPFSEL1);
>>>>>> +    gpio_reg &= ~(7<<12);    /* gpio14 */
>>>>>> +    gpio_reg |=  (4<<12);    /* alt0   */
>>>>>> +    gpio_reg &= ~(7<<15);    /* gpio15 */
>>>>>> +    gpio_reg |=  (4<<15);    /* alt0   */
>>>>>> +    BCM2835_REG(BCM2835_GPIO_GPFSEL1) = gpio_reg;
>>>>>> +    BCM2835_REG(BCM2835_GPIO_GPPUD) = 0;
>>>>>> +    uart0_delay(150);
>>>>>> +    BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = (1<<14)|(1<<15);
>>>>>> +    uart0_delay(150);
>>>>>> +    BCM2835_REG(BCM2835_GPIO_GPPUDCLK0) = 0;
>>>>>> +    ** Init the PL011 UART
>>>>>> +    BCM2835_REG(BCM2835_UART0_CR)   = 0;
>>>>>> +    BCM2835_REG(BCM2835_UART0_ICR)  = 0x7FF;
>>>>>> +    BCM2835_REG(BCM2835_UART0_IMSC) = 0;
>>>>>> +    BCM2835_REG(BCM2835_UART0_IBRD) = 1;
>>>>>> +    BCM2835_REG(BCM2835_UART0_FBRD) = 40;
>>>>>> +    BCM2835_REG(BCM2835_UART0_LCRH) = 0x70;
>>>>>> +    BCM2835_REG(BCM2835_UART0_RSRECR) =  0;
>>>>>> +    BCM2835_REG(BCM2835_UART0_CR)   = 0x301;
>>>>>> +    BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_RX;
>>>>>> +    uart0_set_baud(0, 115000);
>>>>>> +static int uart0_first_open(int major, int minor, void *arg)
>>>>>> +    rtems_libio_open_close_args_t *args = arg;
>>>>>> +    uart0_data.tty   = args->iop->data1;
>>>>>> +    BSP_install_rtems_irq_handler(&uart0_isr_data);
>>>>>> +#endif
>>>>>> +    return 0;
>>>>>> +static int uart0_last_close(int major, int minor, void *arg)
>>>>>> +    BSP_remove_rtems_irq_handler(&uart0_isr_data);
>>>>>> +#endif
>>>>>> +    return 0;
>>>>>> +static int uart0_poll_read(int minor)
>>>>>> +   if (minor == 0)
>>>>>> +       if(((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE) ==
>>>>>> 0)
>>>>>> +           return((BCM2835_REG(BCM2835_UART0_DR)) & 0xFF );
>>>>>> +       else
>>>>>> +           return -1;
>>>>>> +   else
>>>>>> +       printk("Unknown console minor number: %d\n", minor);
>>>>>> +       return -1;
>>>>>> +static ssize_t uart0_poll_write(int minor, const char *buf, size_t len)
>>>>>> +   int i;
>>>>>> +   if (minor == 0)
>>>>>> +       for (i = 0; i < len; i++)
>>>>>> +          while (1)
>>>>>> +              if ((BCM2835_REG(BCM2835_UART0_FR) &
>>>>>> BCM2835_UART0_FR_TXFF) == 0) break;
>>>>>> +           BCM2835_REG(BCM2835_UART0_DR) = buf[i];
>>>>>> +   else
>>>>>> +       return -1;
>>>>>> +   return 1;
>>>>>> +/* This is for setting baud rate, bits, etc. */
>>>>>> +static int uart0_set_attrs(int minor, const struct termios *t)
>>>>>> +    int baud;
>>>>>> +    baud = rtems_termios_baud_to_number(t->c_cflag & CBAUD);
>>>>>> +    uart0_set_baud(minor, baud);
>>>>>> +    return 0;
>>>>>> +static ssize_t uart0_intr_write(int minor, const char *buf, size_t len)
>>>>>> +    uart0_data.buf = buf;
>>>>>> +    uart0_data.len = len;
>>>>>> +    /* Enable transmit interrupt */
>>>>>> +    BCM2835_REG(BCM2835_UART0_IMSC) = BCM2835_UART0_IMSC_TX |
>>>>>> +    return 1;
>>>>>> +    bsp_interrupt_vector_enable(BCM2835_IRQ_ID_UART);
>>>>>> +    bsp_interrupt_vector_disable(BCM2835_IRQ_ID_UART);
>>>>>> +    /* TODO: Need a function in irq.c to return interrupt state */
>>>>>> +    return(1);
>>>>>> +** Handle both the receive and transmit interrupts
>>>>>> +static void uart0_isr(rtems_irq_hdl_param param)
>>>>>> +    uart0_data_t *uart_data = param;
>>>>>> +    char              buf[32];
>>>>>> +    int               i=0;
>>>>>> +    int               len;
>>>>>> +    ** Process receive interrupt
>>>>>> +    if (BCM2835_REG(BCM2835_UART0_MIS) & BCM2835_UART0_MIS_RX)
>>>>>> +       while(((BCM2835_REG(BCM2835_UART0_FR)) & BCM2835_UART0_FR_RXFE)
>>>>>> == 0)
>>>>>> +           buf[i] = BCM2835_REG(BCM2835_UART0_DR) & 0xFF;
>>>>>> +           i++;
>>>>>> +        /* Clear RX Interrupt */
>>>>>> +        BCM2835_REG(BCM2835_UART0_ICR) = BCM2835_UART0_ICR_RX;
>>>>>> +       rtems_termios_enqueue_raw_characters(uart_data->tty, buf, i);
>>>>>> +    ** Process transmit interrupt
>>>>>> +     while ( (((uart_data->regs->aux_mu_lsr_reg) & 0x20) == 0x01) &&
>>>>>> +    if (BCM2835_REG(BCM2835_UART0_MIS) & BCM2835_UART0_MIS_TX)
>>>>>> +        if (uart_data->idx < uart_data->len)
>>>>>> +            while ((BCM2835_REG(BCM2835_UART0_FR) &
>>>>>> BCM2835_UART0_FR_TXFF) &&
>>>>>> +                       (uart_data->idx < uart_data->len))
>>>>>> uart_data->buf[uart_data->idx];
>>>>>> +               uart_data->idx++;
>>>>>> +            /* Clear TX Interrupt */
>>>>>> +            BCM2835_REG(BCM2835_UART0_ICR) = BCM2835_UART0_ICR_TX;
>>>>>> +     else
>>>>>> +        len = uart_data->len;
>>>>>> +        uart_data->len = 0;
>>>>>> +        /* Disable TX Interrupt, leaving RX enabled */
>>>>>> +        rtems_termios_dequeue_characters(uart_data->tty, len);
>>>>>> +#endif
>>>>>> +static void uart0_set_baud(int minor, int baud)
>>>>>> +    ** Nothing for now
>>>>>> +    ** just keep it at 115k
>>>>>> +    return;
>>>>>> + * Polled, non-blocking read from UART
>>>>>> +    return uart0_poll_read(minor);
>>>>>> + * Polled, blocking write from UART
>>>>>> +    uart0_poll_write(minor, &c, 1);
>>>>>> + * Functions for printk() and friends.
>>>>>> +    poll_write(c);
>>>>>> +    if (c == '\n')
>>>>>> +        poll_write('\r');
>>>>>> +BSP_output_char_function_type BSP_output_char = _BSP_output_char;
>>>>>> +    return poll_read();
>>>>>> +BSP_polling_getchar_function_type BSP_poll_char = _BSP_poll_char;
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/include/bsp.h
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/include/bsp.h
>>>>>> index 0000000..c83cfe9
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/include/bsp.h
>>>>>> @@ -0,0 +1,44 @@
>>>>>> + * @file
>>>>>> + * @ingroup raspberry_pi
>>>>>> + * @brief Global BSP definitions.
>>>>>> + * Copyright (c) 2009
>>>>>> + * embedded brains GmbH
>>>>>> + * Obere Lagerstr. 30
>>>>>> + * D-82178 Puchheim
>>>>>> + * Germany
>>>>>> + * <rtems at embedded-brains.de>
>>>>>> +#ifndef LIBBSP_ARM_RASPBERRY_PI_BSP_H
>>>>>> +#define LIBBSP_ARM_RASPBERRY_PI_BSP_H
>>>>>> +#include <bspopts.h>
>>>>>> +#include <rtems.h>
>>>>>> +#include <rtems/console.h>
>>>>>> +#include <rtems/clockdrv.h>
>>>>>> +#ifdef __cplusplus
>>>>>> +extern "C" {
>>>>>> +#endif /* __cplusplus */
>>>>>> +#define BSP_FEATURE_IRQ_EXTENSION
>>>>>> +#ifdef __cplusplus
>>>>>> +#endif /* LIBBSP_ARM_RASPBERRY_PI_BSP_H */
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/include/irq.h
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/include/irq.h
>>>>>> index 0000000..e7ad1e4
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/include/irq.h
>>>>>> @@ -0,0 +1,72 @@
>>>>>> + * @file
>>>>>> + * @ingroup bsp_interrupt
>>>>>> + * @brief Interrupt definitions.
>>>>>> + * Germany
>>>>>> +#ifndef LIBBSP_ARM_RASBPERRY_PI_IRQ_H
>>>>>> +#define LIBBSP_ARM_RASPBERRY_PI_IRQ_H
>>>>>> +#ifndef ASM
>>>>>> +#include <rtems.h>
>>>>>> +#include <rtems/irq-extension.h>
>>>>>> + * @addtogroup bsp_interrupt
>>>>>> +#define BCM2835_INTC_TOTAL_IRQ       64 + 8
>>>>>> +#define BCM2835_IRQ_ID_AUX           29
>>>>>> +#define BCM2835_IRQ_ID_SPI_SLAVE     43
>>>>>> +#define BCM2835_IRQ_ID_PWA0          45
>>>>>> +#define BCM2835_IRQ_ID_PWA1          46
>>>>>> +#define BCM2835_IRQ_ID_SMI           48
>>>>>> +#define BCM2835_IRQ_ID_GPIO_0        49
>>>>>> +#define BCM2835_IRQ_ID_GPIO_1        50
>>>>>> +#define BCM2835_IRQ_ID_GPIO_2        51
>>>>>> +#define BCM2835_IRQ_ID_GPIO_3        52
>>>>>> +#define BCM2835_IRQ_ID_I2C           53
>>>>>> +#define BCM2835_IRQ_ID_SPI           54
>>>>>> +#define BCM2835_IRQ_ID_PCM           55
>>>>>> +#define BCM2835_IRQ_ID_UART          57
>>>>>> +#define BCM2835_IRQ_ID_TIMER_0       64
>>>>>> +#define BCM2835_IRQ_ID_MAILBOX_0     65
>>>>>> +#define BCM2835_IRQ_ID_DOORBELL_0    66
>>>>>> +#define BCM2835_IRQ_ID_DOORBELL_1    67
>>>>>> +#define BCM2835_IRQ_ID_GPU0_HALTED   68
>>>>>> +#define BSP_INTERRUPT_VECTOR_MIN    (0)
>>>>>> +#define BSP_INTERRUPT_VECTOR_MAX    (BCM2835_INTC_TOTAL_IRQ - 1)
>>>>>> +#define BSP_IRQ_COUNT               (BCM2835_INTC_TOTAL_IRQ)
>>>>>> +void raspberry_pi_set_exception_handler(Arm_symbolic_exception_name
>>>>>> exception,
>>>>>> +                                         void (*handler)(void));
>>>>>> +#endif /* ASM */
>>>>>> +#endif /* LIBBSP_ARM_RASPBERRY_PI_IRQ_H */
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/include/mmu.h
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/include/mmu.h
>>>>>> index 0000000..8b50bd2
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/include/mmu.h
>>>>>> @@ -0,0 +1,64 @@
>>>>>> + * @file
>>>>>> + * @ingroup lpc32xx_mmu
>>>>>> + * @brief MMU API.
>>>>>> + * Germany
>>>>>> +#ifndef LIBBSP_ARM_RASPBERRY_PI_MMU_H
>>>>>> +#define LIBBSP_ARM_RASPBERRY_PI_MMU_H
>>>>>> +#include <libcpu/arm-cp15.h>
>>>>>> +#ifdef __cplusplus
>>>>>> +extern "C" {
>>>>>> + * @defgroup raspberry_pi_mmu MMU Support
>>>>>> + * @brief MMU support.
>>>>>> +#define RASPBERRY_PI_MMU_CLIENT_DOMAIN 15U
>>>>>> +#define RASPBERRY_PI_MMU_READ_ONLY \
>>>>>> +  ((RASPBERRY_PI_MMU_CLIENT_DOMAIN << ARM_MMU_SECT_DOMAIN_SHIFT) \
>>>>>> +    | ARM_MMU_SECT_DEFAULT)
>>>>>> +#define RASPBERRY_PI_MMU_READ_ONLY_CACHED \
>>>>>> +  (RASPBERRY_PI_MMU_READ_ONLY | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
>>>>>> +#define RASPBERRY_PI_MMU_READ_WRITE \
>>>>>> +    | ARM_MMU_SECT_AP_0 \
>>>>>> +#define RASPBERRY_PI_MMU_READ_WRITE_CACHED \
>>>>>> +  (RASPBERRY_PI_MMU_READ_WRITE | ARM_MMU_SECT_C | ARM_MMU_SECT_B)
>>>>>> +#ifdef __cplusplus
>>>>>> +#endif /* LIBBSP_ARM_RASPBERRY_PI_MMU_H */
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/include/raspberry_pi.h
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/include/raspberry_pi.h
>>>>>> index 0000000..ed914e4
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/include/raspberry_pi.h
>>>>>> @@ -0,0 +1,186 @@
>>>>>> + * raspberry_pi.h
>>>>>> + * Alan Cudmore
>>>>>> + * alan.cudmore at gmail.com
>>>>> Please add copyright and year here. Can omit email address, we will
>>>>> put it in the git commit message (provide the authorship info in your
>>>>> next submission.)
>>>>>> + * http:
>>>>> Fix this missing license info.
>>>>>> +#ifndef LIBBSP_ARM_RASPBERRY_PI_RASPBERRY_PI_H
>>>>>> +#define LIBBSP_ARM_RASPBERRY_PI_RASPBERRY_PI_H
>>>>>> +#include <stdint.h>
>>>>>> +#include <bsp/utility.h>
>>>>>> + * @defgroup raspberry_pi_reg Register Definitions
>>>>>> + * @brief Register definitions.
>>>>>> +#define BCM2835_REG(x)           (*(volatile uint32_t *)(x))
>>>>>> +#define BCM2835_BIT(n)           (1 << (n))
>>>>>> +#define BCM2835_CLOCK_FREQ       250000000
>>>>>> + * @name Internal ARM Timer Registers
>>>>>> +#define BCM2835_TIMER_BASE       (0x2000B400)
>>>>>> +#define BCM2835_TIMER_LOD        (BCM2835_TIMER_BASE+0x00)
>>>>>> +#define BCM2835_TIMER_VAL        (BCM2835_TIMER_BASE+0x04)
>>>>>> +#define BCM2835_TIMER_CTL        (BCM2835_TIMER_BASE+0x08)
>>>>>> +#define BCM2835_TIMER_CLI        (BCM2835_TIMER_BASE+0x0C)
>>>>>> +#define BCM2835_TIMER_RIS        (BCM2835_TIMER_BASE+0x10)
>>>>>> +#define BCM2835_TIMER_MIS        (BCM2835_TIMER_BASE+0x14)
>>>>>> +#define BCM2835_TIMER_RLD        (BCM2835_TIMER_BASE+0x18)
>>>>>> +#define BCM2835_TIMER_DIV        (BCM2835_TIMER_BASE+0x1C)
>>>>>> +#define BCM2835_TIMER_CNT        (BCM2835_TIMER_BASE+0x20)
>>>>>> +#define BCM2835_TIMER_PRESCALE    0xF9
>>>>>> + * @name GPIO Registers
>>>>>> +#define BCM2835_GPIO_REGS_BASE   (0x20200000)
>>>>>> +#define BCM2835_GPIO_GPFSEL1     (BCM2835_GPIO_REGS_BASE+0x04)
>>>>>> +#define BCM2835_GPIO_GPSET0      (BCM2835_GPIO_REGS_BASE+0x1C)
>>>>>> +#define BCM2835_GPIO_GPCLR0      (BCM2835_GPIO_REGS_BASE+0x28)
>>>>>> +#define BCM2835_GPIO_GPPUD       (BCM2835_GPIO_REGS_BASE+0x94)
>>>>>> +#define BCM2835_GPIO_GPPUDCLK0   (BCM2835_GPIO_REGS_BASE+0x98)
>>>>>> + * @name AUX Registers
>>>>>> +#define BCM2835_AUX_BASE         (0x20215000)
>>>>>> +#define AUX_ENABLES              (BCM2835_AUX_BASE+0x04)
>>>>>> +#define AUX_MU_IO_REG            (BCM2835_AUX_BASE+0x40)
>>>>>> +#define AUX_MU_IER_REG           (BCM2835_AUX_BASE+0x44)
>>>>>> +#define AUX_MU_IIR_REG           (BCM2835_AUX_BASE+0x48)
>>>>>> +#define AUX_MU_LCR_REG           (BCM2835_AUX_BASE+0x4C)
>>>>>> +#define AUX_MU_MCR_REG           (BCM2835_AUX_BASE+0x50)
>>>>>> +#define AUX_MU_LSR_REG           (BCM2835_AUX_BASE+0x54)
>>>>>> +#define AUX_MU_MSR_REG           (BCM2835_AUX_BASE+0x58)
>>>>>> +#define AUX_MU_SCRATCH           (BCM2835_AUX_BASE+0x5C)
>>>>>> +#define AUX_MU_CNTL_REG          (BCM2835_AUX_BASE+0x60)
>>>>>> +#define AUX_MU_STAT_REG          (BCM2835_AUX_BASE+0x64)
>>>>>> +#define AUX_MU_BAUD_REG          (BCM2835_AUX_BASE+0x68)
>>>>>> + * @name UART 0 (PL011) Registers
>>>>>> +#define BCM2835_UART0_BASE       (0x20201000)
>>>>>> +#define BCM2835_UART0_DR         (BCM2835_UART0_BASE+0x00)
>>>>>> +#define BCM2835_UART0_RSRECR     (BCM2835_UART0_BASE+0x04)
>>>>>> +#define BCM2835_UART0_FR         (BCM2835_UART0_BASE+0x18)
>>>>>> +#define BCM2835_UART0_ILPR       (BCM2835_UART0_BASE+0x20)
>>>>>> +#define BCM2835_UART0_IBRD       (BCM2835_UART0_BASE+0x24)
>>>>>> +#define BCM2835_UART0_FBRD       (BCM2835_UART0_BASE+0x28)
>>>>>> +#define BCM2835_UART0_LCRH       (BCM2835_UART0_BASE+0x2C)
>>>>>> +#define BCM2835_UART0_CR         (BCM2835_UART0_BASE+0x30)
>>>>>> +#define BCM2835_UART0_IFLS       (BCM2835_UART0_BASE+0x34)
>>>>>> +#define BCM2835_UART0_IMSC       (BCM2835_UART0_BASE+0x38)
>>>>>> +#define BCM2835_UART0_RIS        (BCM2835_UART0_BASE+0x3C)
>>>>>> +#define BCM2835_UART0_MIS        (BCM2835_UART0_BASE+0x40)
>>>>>> +#define BCM2835_UART0_ICR        (BCM2835_UART0_BASE+0x44)
>>>>>> +#define BCM2835_UART0_DMACR      (BCM2835_UART0_BASE+0x48)
>>>>>> +#define BCM2835_UART0_ITCR       (BCM2835_UART0_BASE+0x80)
>>>>>> +#define BCM2835_UART0_ITIP       (BCM2835_UART0_BASE+0x84)
>>>>>> +#define BCM2835_UART0_ITOP       (BCM2835_UART0_BASE+0x88)
>>>>>> +#define BCM2835_UART0_TDR        (BCM2835_UART0_BASE+0x8C)
>>>>>> +#define BCM2835_UART0_MIS_RX    0x10
>>>>>> +#define BCM2835_UART0_MIS_TX    0x20
>>>>>> +#define BCM2835_UART0_IMSC_RX   0x10
>>>>>> +#define BCM2835_UART0_IMSC_TX   0x20
>>>>>> +#define BCM2835_UART0_FR_RXFE   0x10
>>>>>> +#define BCM2835_UART0_FR_TXFF   0x20
>>>>>> +#define BCM2835_UART0_ICR_RX    0x10
>>>>>> +#define BCM2835_UART0_ICR_TX    0x20
>>>>>> + * @name IRQ Registers
>>>>>> +#define BCM2835_BASE_INTC         (0x2000B200)
>>>>>> +#define BCM2835_IRQ_BASIC         (BCM2835_BASE_INTC + 0x00)
>>>>>> +#define BCM2835_IRQ_PENDING1      (BCM2835_BASE_INTC + 0x04)
>>>>>> +#define BCM2835_IRQ_PENDING2      (BCM2835_BASE_INTC + 0x08)
>>>>>> +#define BCM2835_IRQ_FIQ_CTRL      (BCM2835_BASE_INTC + 0x0C)
>>>>>> +#define BCM2835_IRQ_ENABLE1       (BCM2835_BASE_INTC + 0x10)
>>>>>> +#define BCM2835_IRQ_ENABLE2       (BCM2835_BASE_INTC + 0x14)
>>>>>> +#define BCM2835_IRQ_ENABLE_BASIC  (BCM2835_BASE_INTC + 0x18)
>>>>>> +#define BCM2835_IRQ_DISABLE1      (BCM2835_BASE_INTC + 0x1C)
>>>>>> +#define BCM2835_IRQ_DISABLE2      (BCM2835_BASE_INTC + 0x20)
>>>>>> +#define BCM2835_IRQ_DISABLE_BASIC (BCM2835_BASE_INTC + 0x24)
>>>>>> + * @name GPU Timer Registers
>>>>>> + * NOTE: The GPU uses Compare registers 0 and 2 for
>>>>>> + *       it's own RTOS. 1 and 3 are available for use in
>>>>>> + *       RTEMS.
>>>>>> +#define BCM2835_GPU_TIMER_BASE    (0x20003000)
>>>>>> +#define BCM2835_GPU_TIMER_CS      (BCM2835_TIMER_BASE+0x00)
>>>>>> +#define BCM2835_GPU_TIMER_CLO     (BCM2835_TIMER_BASE+0x04)
>>>>>> +#define BCM2835_GPU_TIMER_CHI     (BCM2835_TIMER_BASE+0x08)
>>>>>> +#define BCM2835_GPU_TIMER_C0      (BCM2835_TIMER_BASE+0x0C)
>>>>>> +#define BCM2835_GPU_TIMER_C1      (BCM2835_TIMER_BASE+0x10)
>>>>>> +#define BCM2835_GPU_TIMER_C2      (BCM2835_TIMER_BASE+0x14)
>>>>>> +#define BCM2835_GPU_TIMER_C3      (BCM2835_TIMER_BASE+0x18)
>>>>>> +#endif /* LIBBSP_ARM_RASPBERRY_PI_RASPBERRY_PI_H */
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/irq/irq.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/irq/irq.c
>>>>>> index 0000000..ae0a81d
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/irq/irq.c
>>>>>> @@ -0,0 +1,124 @@
>>>>>> + * @file
>>>>>> + * @brief Interrupt support.
>>>>>> + * Germany
>>>>>> +#include <rtems/score/armv4.h>
>>>>>> +#include <bsp.h>
>>>>>> +#include <bsp/linker-symbols.h>
>>>>>> +#include <bsp/mmu.h>
>>>>>> +** This sets the main exception vectors
>>>>>> +                        Arm_symbolic_exception_name exception,
>>>>>> +    if ((unsigned) exception < MAX_EXCEPTIONS)
>>>>>> +        uint32_t *table = (uint32_t *) bsp_section_vector_begin +
>>>>>> MAX_EXCEPTIONS;
>>>>>> +        table [exception] = (uint32_t) handler;
>>>>>> +** Determine the source of the interrupt and dispatch the correct
>>>>>> handler.
>>>>>> +void bsp_interrupt_dispatch(void)
>>>>>> +  rtems_vector_number vector = 255;
>>>>>> +  /* ARM timer */
>>>>>> +  if (BCM2835_REG(BCM2835_IRQ_BASIC) && 0x1)
>>>>>> +      vector = BCM2835_IRQ_ID_TIMER_0;
>>>>>> +  /* UART 0 */
>>>>>> +  else if ( BCM2835_REG(BCM2835_IRQ_BASIC) && BCM2835_BIT(19))
>>>>>> +      vector = BCM2835_IRQ_ID_UART;
>>>>>> +  if ( vector < 255 )
>>>>>> +      bsp_interrupt_handler_dispatch(vector);
>>>>>> +rtems_status_code bsp_interrupt_vector_enable(rtems_vector_number
>>>>>> vector)
>>>>>> +  rtems_interrupt_level  level;
>>>>>> +  rtems_interrupt_disable(level);
>>>>>> +   /* ARM Timer */
>>>>>> +  if ( vector == BCM2835_IRQ_ID_TIMER_0 )
>>>>>> +      BCM2835_REG(BCM2835_IRQ_ENABLE_BASIC) = 0x1;
>>>>>> +  /* UART 0 */
>>>>>> +  else if ( vector == BCM2835_IRQ_ID_UART )
>>>>>> +      BCM2835_REG(BCM2835_IRQ_ENABLE2) =  BCM2835_BIT(25);
>>>>>> +  rtems_interrupt_enable(level);
>>>>>> +rtems_status_code bsp_interrupt_vector_disable(rtems_vector_number
>>>>>> vector)
>>>>>> +      BCM2835_REG(BCM2835_IRQ_DISABLE_BASIC) = 0x1;
>>>>>> +      BCM2835_REG(BCM2835_IRQ_DISABLE2) = BCM2835_BIT(25);
>>>>>> +void bsp_interrupt_handler_default(rtems_vector_number vector)
>>>>>> +    printk("spurious interrupt: %u\n", vector);
>>>>>> +rtems_status_code bsp_interrupt_facility_initialize(void)
>>>>>> +   raspberry_pi_set_exception_handler(ARM_EXCEPTION_IRQ,
>>>>>> _ARMV4_Exception_interrupt);
>>>>>> diff --git
>>>>>> a/c/src/lib/libbsp/arm/raspberry_pi/make/custom/raspberry_pi.cfg
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/make/custom/raspberry_pi.cfg
>>>>>> index 0000000..c33c148
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/make/custom/raspberry_pi.cfg
>>>>>> @@ -0,0 +1,24 @@
>>>>>> +#  Config file for RASPBERRY_PI
>>>>>> +#  $Id: $
>>>>> Remove $Id$
>>>>>> +include $(RTEMS_ROOT)/make/custom/default.cfg
>>>>>> +RTEMS_CPU = arm
>>>>>> +CPU_CFLAGS =  -mcpu=arm1176jzf-s \
>>>>>> +             -fomit-frame-pointer -mfpu=vfp -mfloat-abi=soft \
>>>>>> +             -mabi=apcs-gnu -ffreestanding
>>>>>> +CFLAGS_OPTIMIZE_V = -O2 -g
>>>>>> +# This defines the operations performed on the linked executable.
>>>>>> +# is currently required.
>>>>>> +define bsp-post-link
>>>>>> +       $(OBJCOPY) -O binary --strip-all \
>>>>>> +           $(basename $@).exe $(basename $@)$(DOWNEXT)
>>>>>> +       $(SIZE) $(basename $@).exe
>>>>>> +endef
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/misc/timer.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/misc/timer.c
>>>>>> index 0000000..522858a
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/misc/timer.c
>>>>>> @@ -0,0 +1,52 @@
>>>>>> + * @file
>>>>>> + * @brief Benchmark timer support.
>>>>>> + * Copyright (c) 2008, 2009
>>>>>> + * Germany
>>>>>> +#include <rtems.h>
>>>>>> +#include <rtems/timerdrv.h>
>>>>>> +static bool benchmark_timer_find_average_overhead = false;
>>>>>> +static uint64_t benchmark_timer_base;
>>>>>> +void benchmark_timer_initialize(void)
>>>>>> +  benchmark_timer_base = BCM2835_REG(BCM2835_GPU_TIMER_CLO);
>>>>>> +uint32_t benchmark_timer_read(void)
>>>>>> +  uint32_t delta = BCM2835_REG(BCM2835_GPU_TIMER_CLO) -
>>>>>> +  if (benchmark_timer_find_average_overhead)
>>>>>> +    return delta;
>>>>>> +  else
>>>>>> +    return BCM2835_REG(BCM2835_GPU_TIMER_CLO);
>>>>>> +void benchmark_timer_disable_subtracting_average_overhead(bool
>>>>>> +  benchmark_timer_find_average_overhead = find_average_overhead;
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/preinstall.am
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/preinstall.am
>>>>>> index 0000000..2c6d75f
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/preinstall.am
>>>>>> @@ -0,0 +1,133 @@
>>>>>> +## Automatically generated by ampolish3 - Do not edit
>>>>>> +if AMPOLISH3
>>>>>> +$(srcdir)/preinstall.am: Makefile.am
>>>>>> +       $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
>>>>>> +endif
>>>>>> +PREINSTALL_DIRS =
>>>>>> +DISTCLEANFILES += $(PREINSTALL_DIRS)
>>>>>> +all-local: $(TMPINSTALL_FILES)
>>>>>> +TMPINSTALL_FILES =
>>>>>> +CLEANFILES = $(TMPINSTALL_FILES)
>>>>>> +all-am: $(PREINSTALL_FILES)
>>>>>> +PREINSTALL_FILES =
>>>>>> +CLEANFILES += $(PREINSTALL_FILES)
>>>>>> +$(PROJECT_LIB)/$(dirstamp):
>>>>>> +       @$(MKDIR_P) $(PROJECT_LIB)
>>>>>> +       @: > $(PROJECT_LIB)/$(dirstamp)
>>>>>> +PREINSTALL_DIRS += $(PROJECT_LIB)/$(dirstamp)
>>>>>> +$(PROJECT_INCLUDE)/$(dirstamp):
>>>>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)
>>>>>> +       @: > $(PROJECT_INCLUDE)/$(dirstamp)
>>>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/$(dirstamp)
>>>>>> +$(PROJECT_INCLUDE)/bsp/$(dirstamp):
>>>>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/bsp
>>>>>> +       @: > $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>>> +$(PROJECT_INCLUDE)/libcpu/$(dirstamp):
>>>>>> +       @$(MKDIR_P) $(PROJECT_INCLUDE)/libcpu
>>>>>> +       @: > $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>>> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/libcpu/$(dirstamp)
>>>>>> +$(PROJECT_LIB)/bsp_specs: bsp_specs $(PROJECT_LIB)/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/bsp_specs
>>>>>> +PREINSTALL_FILES += $(PROJECT_LIB)/bsp_specs
>>>>>> +$(PROJECT_INCLUDE)/bsp.h: include/bsp.h $(PROJECT_INCLUDE)/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp.h
>>>>>> +$(PROJECT_INCLUDE)/tm27.h: ../../shared/include/tm27.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/tm27.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/tm27.h
>>>>>> +$(PROJECT_INCLUDE)/coverhd.h: ../../shared/include/coverhd.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/coverhd.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/coverhd.h
>>>>>> +$(PROJECT_INCLUDE)/bspopts.h: include/bspopts.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bspopts.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bspopts.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/bootcard.h: ../../shared/include/bootcard.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/bootcard.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/utility.h: ../../shared/include/utility.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/utility.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/utility.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/irq-generic.h:
>>>>>> ../../shared/include/irq-generic.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-generic.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/irq-info.h: ../../shared/include/irq-info.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq-info.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq-info.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/stackalloc.h: ../../shared/include/stackalloc.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/stackalloc.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/stackalloc.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/uart-output-char.h:
>>>>>> ../../shared/include/uart-output-char.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/uart-output-char.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/uart-output-char.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/tod.h: ../../shared/tod.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/tod.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/tod.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/linker-symbols.h:
>>>>>> ../shared/include/linker-symbols.h $(PROJECT_INCLUDE)/bsp/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/linker-symbols.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/start.h: ../shared/include/start.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/start.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/start.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/lpc-timer.h: ../shared/lpc/include/lpc-timer.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-timer.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/lpc-dma.h: ../shared/lpc/include/lpc-dma.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/lpc-dma.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/lpc-dma.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/irq.h: include/irq.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/irq.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/irq.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/mmu.h: include/mmu.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/mmu.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/mmu.h
>>>>>> +$(PROJECT_INCLUDE)/bsp/raspberry_pi.h: include/raspberry_pi.h
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/bsp/raspberry_pi.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/bsp/raspberry_pi.h
>>>>>> +$(PROJECT_INCLUDE)/libcpu/arm-cp15.h:
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
>>>>>> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/libcpu/arm-cp15.h
>>>>>> +$(PROJECT_LIB)/start.$(OBJEXT): start.$(OBJEXT)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/start.$(OBJEXT)
>>>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/start.$(OBJEXT)
>>>>>> +$(PROJECT_LIB)/linkcmds: startup/linkcmds $(PROJECT_LIB)/$(dirstamp)
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds
>>>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds
>>>>>> +$(PROJECT_LIB)/linkcmds.base: ../shared/startup/linkcmds.base
>>>>>> +       $(INSTALL_DATA) $< $(PROJECT_LIB)/linkcmds.base
>>>>>> +TMPINSTALL_FILES += $(PROJECT_LIB)/linkcmds.base
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/startup/bspreset.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/startup/bspreset.c
>>>>>> index 0000000..c3583f0
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/startup/bspreset.c
>>>>>> @@ -0,0 +1,31 @@
>>>>>> + * @file
>>>>>> + * @brief Reset code.
>>>>>> + * Germany
>>>>>> +#include <rtems.h>
>>>>>> +#include <bsp/bootcard.h>
>>>>>> +void bsp_reset( void)
>>>>>> +  while (true) {
>>>>>> +    /* Do nothing */
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/startup/bspstart.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/startup/bspstart.c
>>>>>> index 0000000..8075f75
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/startup/bspstart.c
>>>>>> @@ -0,0 +1,33 @@
>>>>>> + * @file
>>>>>> + * @brief Startup code.
>>>>>> + * Copyright (c) 2009, 2010
>>>>>> + * Germany
>>>>>> +#include <bsp.h>
>>>>>> +#include <bsp/stackalloc.h>
>>>>>> +void bsp_start(void)
>>>>>> +    bsp_interrupt_initialize();
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/startup/bspstarthooks.c
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/startup/bspstarthooks.c
>>>>>> index 0000000..9373baf
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/startup/bspstarthooks.c
>>>>>> @@ -0,0 +1,112 @@
>>>>>> + * @file
>>>>>> + * Germany
>>>>>> +#include <stdbool.h>
>>>>>> +#include <bsp/start.h>
>>>>>> +static void BSP_START_TEXT_SECTION clear_bss(void)
>>>>>> +  const int *end = (const int *) bsp_section_bss_end;
>>>>>> +  int *out = (int *) bsp_section_bss_begin;
>>>>>> +  /* Clear BSS */
>>>>>> +  while (out != end) {
>>>>>> +    *out = 0;
>>>>>> +    ++out;
>>>>>> +static void BSP_START_TEXT_SECTION raspberry_pi_cache_setup(void)
>>>>>> +  uint32_t ctrl = 0;
>>>>>> +  /* Disable MMU and cache, basic settings */
>>>>>> +  ctrl = arm_cp15_get_control();
>>>>>> +  ctrl &= ~(ARM_CP15_CTRL_I | ARM_CP15_CTRL_R | ARM_CP15_CTRL_C
>>>>>> +    | ARM_CP15_CTRL_V | ARM_CP15_CTRL_M);
>>>>>> +  ctrl |= ARM_CP15_CTRL_S | ARM_CP15_CTRL_A;
>>>>>> +  arm_cp15_set_control(ctrl);
>>>>>> +  arm_cp15_cache_invalidate();
>>>>>> +  arm_cp15_tlb_invalidate();
>>>>>> +void BSP_START_TEXT_SECTION bsp_start_hook_0(void)
>>>>>> +  raspberry_pi_cache_setup();
>>>>>> +void BSP_START_TEXT_SECTION bsp_start_hook_1(void)
>>>>>> +    /* Copy .text section */
>>>>>> +    arm_cp15_instruction_cache_invalidate();
>>>>>> +    bsp_start_memcpy(
>>>>>> +                     (int *) bsp_section_text_begin,
>>>>>> +                     (const int *) bsp_section_text_load_begin,
>>>>>> +                     (size_t) bsp_section_text_size
>>>>>> +    /* Copy .rodata section */
>>>>>> +    bsp_start_memcpy(
>>>>>> +                     (int *) bsp_section_rodata_begin,
>>>>>> +                     (const int *) bsp_section_rodata_load_begin,
>>>>>> +                     (size_t) bsp_section_rodata_size
>>>>>> +    /* Copy .data section */
>>>>>> +    bsp_start_memcpy(
>>>>>> +                     (int *) bsp_section_data_begin,
>>>>>> +                     (const int *) bsp_section_data_load_begin,
>>>>>> +                     (size_t) bsp_section_data_size
>>>>>> +    /* Copy .fast_text section */
>>>>>> +    bsp_start_memcpy(
>>>>>> +                     (int *) bsp_section_fast_text_begin,
>>>>>> +                     (const int *) bsp_section_fast_text_load_begin,
>>>>>> +                     (size_t) bsp_section_fast_text_size
>>>>>> +    /* Copy .fast_data section */
>>>>>> +    bsp_start_memcpy(
>>>>>> +                     (int *) bsp_section_fast_data_begin,
>>>>>> +                     (const int *) bsp_section_fast_data_load_begin,
>>>>>> +                     (size_t) bsp_section_fast_data_size
>>>>>> +  /* Clear .bss section */
>>>>>> +  clear_bss();
>>>>>> diff --git a/c/src/lib/libbsp/arm/raspberry_pi/startup/linkcmds
>>>>>> b/c/src/lib/libbsp/arm/raspberry_pi/startup/linkcmds
>>>>>> index 0000000..b9e6f02
>>>>>> --- /dev/null
>>>>>> +++ b/c/src/lib/libbsp/arm/raspberry_pi/startup/linkcmds
>>>>>> @@ -0,0 +1,62 @@
>>>>>> + * @file
>>>>>> + * @brief Memory map.
>>>>>> + * @defgroup raspberry_pi Memory Map
>>>>>> + * @ingroup bsp_linker
>>>>>> + * @brief Raspberry Pi memory map.
>>>>>> + * <table>
>>>>>> + *   <tr><th>Region Name</th><th>Region Begin</th><th>Region
>>>>>> Size</th></tr>
>>>>>> + *   <tr><td>VECTOR_RAM</td><td>0x08000000</td><td>8k</td></tr>
>>>>>> + *   <tr><td>RAM</td><td>0x80008000</td><td>128M</td></tr>
>>>>>> + * </table>
>>>>>> + * <table>
>>>>>> + *   <tr><th>Section Name</th><th>Section Runtime
>>>>>> Region</th><th>Section Load Region</th></tr>
>>>>>> + *   <tr><td>.start</td><td>RAM</td><td></td></tr>
>>>>>> + *   <tr><td>.vector</td><td>VECTOR_RAM</td><td></td></tr>
>>>>>> + *   <tr><td>.text</td><td>RAM</td><td>RAM_EXT</td></tr>
>>>>>> + *   <tr><td>.rodata</td><td>RAM</td><td>RAM_EXT</td></tr>
>>>>>> + *   <tr><td>.data</td><td>RAM</td><td>RAM_EXT</td></tr>
>>>>>> + *   <tr><td>.fast</td><td>RAM</td><td>RAM_EXT</td></tr>
>>>>>> + *   <tr><td>.bss</td><td>RAM</td><td></td></tr>
>>>>>> + *   <tr><td>.work</td><td>RAM</td><td></td></tr>
>>>>>> + *   <tr><td>.stack</td><td>RAM</td><td></td></tr>
>>>>>> + * </table>
>>>>>> +MEMORY {
>>>>>> +        VECTOR_RAM     (AIW) : ORIGIN = 0x0       , LENGTH = 0x8000
>>>>>> +        RAM            (AIW) : ORIGIN = 0x00008000, LENGTH = 128M -
>>>>>> 0x8000
>>>>>> +REGION_ALIAS ("REGION_START", RAM);
>>>>>> +REGION_ALIAS ("REGION_VECTOR", VECTOR_RAM);
>>>>>> +REGION_ALIAS ("REGION_TEXT", RAM);
>>>>>> +REGION_ALIAS ("REGION_TEXT_LOAD", RAM);
>>>>>> +REGION_ALIAS ("REGION_RODATA", RAM);
>>>>>> +REGION_ALIAS ("REGION_RODATA_LOAD", RAM);
>>>>>> +REGION_ALIAS ("REGION_DATA", RAM);
>>>>>> +REGION_ALIAS ("REGION_DATA_LOAD", RAM);
>>>>>> +REGION_ALIAS ("REGION_FAST_TEXT", RAM);
>>>>>> +REGION_ALIAS ("REGION_FAST_TEXT_LOAD", RAM);
>>>>>> +REGION_ALIAS ("REGION_FAST_DATA", RAM);
>>>>>> +REGION_ALIAS ("REGION_FAST_DATA_LOAD", RAM);
>>>>>> +REGION_ALIAS ("REGION_BSS", RAM);
>>>>>> +REGION_ALIAS ("REGION_WORK", RAM);
>>>>>> +REGION_ALIAS ("REGION_STACK", RAM);
>>>>>> +bsp_stack_irq_size = DEFINED (bsp_stack_irq_size) ? bsp_stack_irq_size
>>>>>> : 4096;
>>>>>> +bsp_stack_abt_size = DEFINED (bsp_stack_abt_size) ? bsp_stack_abt_size
>>>>>> : 1024;
>>>>>> +bsp_section_robarrier_align = DEFINED (bsp_section_robarrier_align) ?
>>>>>> bsp_section_robarrier_align : 1M;
>>>>>> +INCLUDE linkcmds.armv4
>>>>>> diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h
>>>>>> b/cpukit/score/cpu/arm/rtems/score/arm.h
>>>>>> index 8f8c837..8471bb4 100644
>>>>>> --- a/cpukit/score/cpu/arm/rtems/score/arm.h
>>>>>> +++ b/cpukit/score/cpu/arm/rtems/score/arm.h
>>>>>> @@ -69,6 +69,10 @@ extern "C" {
>>>>>> #  define CPU_MODEL_NAME  "ARMv6J"
>>>>>> #  define ARM_MULTILIB_ARCH_V4
>>>>>> +#elif defined(__ARM_ARCH_6ZK__)
>>>>>> +#  define CPU_MODEL_NAME  "ARMv6ZK"
>>>>>> +#  define ARM_MULTILIB_ARCH_V4
>>>>> This change has been committed separately. You may wish to rebase your
>>>>> work on the rtems.git.
>>>>>> #elif defined(__ARM_ARCH_6M__)
>>>>>> #  define CPU_MODEL_NAME  "ARMv6M"
>>>>>> _______________________________________________
>>>>>> rtems-devel mailing list
>>>>>> rtems-devel at rtems.org
>>>>>> http://www.rtems.org/mailman/listinfo/rtems-devel
>>> Joel Sherrill, Ph.D.             Director of Research & Development
>>> joel.sherrill at OARcorp.com        On-Line Applications Research
>>> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
>>> Support Available                (256) 722-9985
