[GSOC 2013] - RTEMS Run-Time Oriented projects and Raspberry Pi BSP
Sagara Paranagama
sagara89dev at gmail.com
Wed Feb 27 03:48:19 UTC 2013
> This task has a series of steps which make this more obvious at the
> SuperCore
> level. Names suck at this point but hopefully this makes sense.
> + Create SuperCore Handlers for Task Sets:
> - Refactor "FIFO for Priority Ordering" from Scheduler Simple into
> something like "ThreadSetSimplePriority"
> - Refactor priority discipline from Thread Queue (e.g. Block 2-n
> structure)
> and name it something like "ThreadSetBlock2nPriority"
> - Reflactor Thread Set from Deterministic Priority Scheduler and
> name it something like "**ThreadSetDeterministicPriority**"
> + Add Scheduler which uses Block2-n
> + Rework Scheduler Simple SMP to use Block 2-n (if feasible)
> + Run Timing Tests with each scheduler as default
> - A report on this is desirable
> - Helping provide more guidance in selecting a scheduler is important.
> 2. Where can I find more information in developing a BSP for the
>> Raspberry Pi? (ex: a contact person, partial implementation etc.) I have a
>> RPi so I'm extremely interested in this project :)
>> This is underway. A BSP has been submitted this week and is under review.
> It only has basic functionality so there is a lot of room to add
> capabilities to
> it. Alan Cudmore wrote what there is. The Pi Project will change to be "add
> drivers". But this is a good thing with plenty of work.
Hi Joel,
Thank you very much for your informative reply. However, looking at the two
areas of suggestions, I'd rather the RPi project because it aligns more
with my interests :). But thanks again.
Sagara
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130227/81e9cace/attachment.html>
