[PATCH v3 0/3] Moxie port resub w/ code style mods
Anthony Green
green at moxielogic.com
Wed Feb 27 18:13:18 UTC 2013
Here's version 3. I ran the BSP submission script on got the following output:
http://paste.fedoraproject.org/3915/
I believe the last two warnings are wrong.
This version of the patch series removes legacy CVS bits ($Id$,
.cvsignore, ChangeLog files/entries), and removes tabs and trailing
whitespace.
Thanks,
AG
Anthony Green (3):
Add Moxie CPU support
Add sample Moxie BSP for GDB sim
Common file changes in support of Moxie port
c/src/aclocal/rtems-cpu-subdirs.m4 | 1 +
c/src/lib/libbsp/moxie/Makefile.am | 11 +
c/src/lib/libbsp/moxie/acinclude.m4 | 10 +
c/src/lib/libbsp/moxie/configure.ac | 21 +
c/src/lib/libbsp/moxie/moxiesim/Makefile.am | 49 +
c/src/lib/libbsp/moxie/moxiesim/bsp_specs | 11 +
c/src/lib/libbsp/moxie/moxiesim/configure.ac | 22 +
.../lib/libbsp/moxie/moxiesim/console/console-io.c | 66 ++
c/src/lib/libbsp/moxie/moxiesim/console/syscalls.S | 15 +
c/src/lib/libbsp/moxie/moxiesim/include/bsp.h | 45 +
.../libbsp/moxie/moxiesim/make/custom/moxiesim.cfg | 15 +
c/src/lib/libbsp/moxie/moxiesim/preinstall.am | 67 ++
c/src/lib/libbsp/moxie/moxiesim/start/start.S | 22 +
c/src/lib/libbsp/moxie/moxiesim/startup/__main.c | 21 +
c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds | 251 +++++
.../moxie/moxiesim/startup/moxiebdinstallirq.c | 20 +
cpukit/configure.ac | 1 +
cpukit/librpc/src/xdr/xdr_float.c | 2 +-
cpukit/score/cpu/Makefile.am | 1 +
cpukit/score/cpu/moxie/Makefile.am | 19 +
cpukit/score/cpu/moxie/cpu.c | 150 +++
cpukit/score/cpu/moxie/cpu_asm.S | 117 +++
.../score/cpu/moxie/moxie-exception-frame-print.c | 18 +
cpukit/score/cpu/moxie/preinstall.am | 41 +
cpukit/score/cpu/moxie/rtems/asm.h | 116 +++
cpukit/score/cpu/moxie/rtems/score/cpu.h | 1090 ++++++++++++++++++++
cpukit/score/cpu/moxie/rtems/score/moxie.h | 43 +
cpukit/score/cpu/moxie/rtems/score/types.h | 53 +
28 files changed, 2297 insertions(+), 1 deletion(-)
create mode 100644 c/src/lib/libbsp/moxie/Makefile.am
create mode 100644 c/src/lib/libbsp/moxie/acinclude.m4
create mode 100644 c/src/lib/libbsp/moxie/configure.ac
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/Makefile.am
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/bsp_specs
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/configure.ac
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/console/console-io.c
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/console/syscalls.S
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/include/bsp.h
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/make/custom/moxiesim.cfg
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/preinstall.am
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/start/start.S
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/startup/__main.c
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/startup/linkcmds
create mode 100644 c/src/lib/libbsp/moxie/moxiesim/startup/moxiebdinstallirq.c
create mode 100644 cpukit/score/cpu/moxie/Makefile.am
create mode 100644 cpukit/score/cpu/moxie/cpu.c
create mode 100644 cpukit/score/cpu/moxie/cpu_asm.S
create mode 100644 cpukit/score/cpu/moxie/moxie-exception-frame-print.c
create mode 100644 cpukit/score/cpu/moxie/preinstall.am
create mode 100644 cpukit/score/cpu/moxie/rtems/asm.h
create mode 100644 cpukit/score/cpu/moxie/rtems/score/cpu.h
create mode 100644 cpukit/score/cpu/moxie/rtems/score/moxie.h
create mode 100644 cpukit/score/cpu/moxie/rtems/score/types.h
1.8.1.4
