[PATCH 4/7] score: atomic support for RTEMS. Atomic operations for PowerPC.
    Gedare Bloom
    gedare at rtems.org
    Mon Feb  4 19:33:35 UTC 2013
 cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h |  537 ++++++++++++++++++++++
 1 files changed, 537 insertions(+), 0 deletions(-)
 create mode 100644 cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h
diff --git a/cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h b/cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h
new file mode 100644
index 0000000..eeefa36
--- /dev/null
+++ b/cpukit/score/cpu/powerpc/rtems/score/cpuatomic.h
@@ -0,0 +1,537 @@
+ * @file  rtems/score/cpuatomic.h
+ * This include file implements the atomic operations for PowerPC and defines
+ * atomic data types which are used by the atomic operations API file. This
+ * file should use fixed name cpuatomic.h and should be included in atomic
+ * operations API file atomic.h. Most of the parts of implementations are
+ * imported from FreeBSD kernel.
+ * Copyright (c) 2008 Marcel Moolenaar
+ * Copyright (c) 2001 Benno Rice
+ * Copyright (c) 2001 David E. O'Brien
+ * Copyright (c) 1998 Doug Rabson
+ * All rights reserved.
+ * are met:
+ * THIS SOFTWARE IS PROVIDED BY THE AUTHOR AND CONTRIBUTORS ``AS IS'' AND
+ * ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE
+ * ARE DISCLAIMED.  IN NO EVENT SHALL THE AUTHOR OR CONTRIBUTORS BE LIABLE
+ * FOR ANY DIRECT, INDIRECT, INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL
+ * DAMAGES (INCLUDING, BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS
+ * OR SERVICES; LOSS OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION)
+ * HOWEVER CAUSED AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT
+ * LIABILITY, OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY
+ * OUT OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF
+ * SUCH DAMAGE.
+ * $FreeBSD$
+#ifndef _RTEMS_SCORE_ATOMIC_CPU_H
+#define _RTEMS_SCORE_ATOMIC_CPU_H
+#include <rtems/score/genericcpuatomic.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMS atomic implementation
+#define	__ATOMIC_BARRIER                   \
+    __asm __volatile("sync" : : : "memory")
+#define mb()	__ATOMIC_BARRIER
+#define	wmb()	mb()
+#define	rmb()	mb()
+ * Atomic_Fetch_add(p, v)
+ * { *p += v; }
+#define __CPU_Atomic_Fetch_add_int(p, v, t)         \
+  __asm __volatile(                                 \
+     "1:lwarx	%0, 0, %2\n"                        \
+     "	add	%0, %3, %0\n"                       \
+     "	stwcx.	%0, 0, %2\n"                        \
+     "	bne-	1b\n"                               \
+     : "=&r" (t), "=m" (*p)                         \
+     : "r" (p), "r" (v), "m" (*p)                   \
+     : "cc", "memory")                              \
+     /* __CPU_Atomic_Fetch_add_int */
+#define	__CPU_Atomic_Fetch_add_long(p, v, t)        \
+     "	bne-	1b\n"                               \
+     /* __CPU_Atomic_Fetch_add_long */
+#define	_ATOMIC_ADD(typename, type)                           \
+  static __inline void                              \
+  _CPU_Atomic_Fetch_add_##typename(volatile Atomic_##type *p, Atomic_##type v) {  \
+    Atomic_##type t;                                \
+    __CPU_Atomic_Fetch_add_##typename(p, v, t);         \
+  _CPU_Atomic_Fetch_add_acq_##typename(volatile Atomic_##type *p, Atomic_##type v) { \
+   __ATOMIC_BARRIER;                                            \
+  _CPU_Atomic_Fetch_add_rel_##typename(volatile Atomic_##type *p, Atomic_##type v) { \
+  /* _ATOMIC_ADD */
+_ATOMIC_ADD(int, Int)
+_ATOMIC_ADD(long, Long)
+#define _CPU_Atomic_Fetch_add_32(p, v)  \
+    _CPU_Atomic_Fetch_add_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_add_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_add_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_add_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_add_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_add_ptr(p, v) \
+#define _CPU_Atomic_Fetch_add_acq_ptr(p, v) \
+#define _CPU_Atomic_Fetch_add_rel_ptr(p, v) \
+#undef _ATOMIC_ADD
+#undef __CPU_Atomic_Fetch_add_long
+#undef __CPU_Atomic_Fetch_add_int
+ * Atomic_Fetch_and(p, v)
+ * { *p &= v; }
+#define __CPU_Atomic_Fetch_and_int(p, v, t)                     \
+  "1:	lwarx	%0, 0, %2\n"                                    \
+  "	and	%0, %0, %3\n"                                   \
+  "	bne-	1b\n"                                           \
+  /* _CPU_Atomic_Fetch_and_int */
+#define	__CPU_Atomic_Fetch_and_long(p, v, t)                    \
+  "	bne-	1b\n"                                           \
+  /* _CPU_Atomic_Fetch_and_long */
+#define	_ATOMIC_AND(typename, type)                                       \
+  _CPU_Atomic_Fetch_and_##typename(volatile Atomic_##type *p, Atomic_##type v) {  \
+    __CPU_Atomic_Fetch_and_##typename(p, v, t);                     \
+  _CPU_Atomic_Fetch_and_acq_##typename(volatile Atomic_##type *p, Atomic_##type v) {  \
+  _CPU_Atomic_Fetch_and_rel_##typename(volatile Atomic_##type *p, Atomic_##type v) {  \
+  /* _ATOMIC_AND */
+_ATOMIC_AND(int, Int)
+_ATOMIC_AND(long, Long)
+#define _CPU_Atomic_Fetch_and_32(p, v)  \
+    _CPU_Atomic_Fetch_and_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_and_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_and_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_and_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_and_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_and_ptr(p, v) \
+#define _CPU_Atomic_Fetch_and_acq_ptr(p, v) \
+#define _CPU_Atomic_Fetch_and_rel_ptr(p, v) \
+#undef _ATOMIC_AND
+#undef __CPU_Atomic_Fetch_and_long
+#undef __CPU_Atomic_Fetch_and_int
+ * Atomic_Fetch_or(p, v)
+ * { *p |= v; }
+#define __CPU_Atomic_Fetch_or_int(p, v, t)              \
+  "	or	%0, %3, %0\n"                           \
+  "	bne-	1b\n"                                   \
+  /* __CPU_Atomic_Fetch_or_int */
+#define	__CPU_Atomic_Fetch_or_long(p, v, t)             \
+  "	bne-	1b\n"                                   \
+  /* __CPU_Atomic_Fetch_or_long */
+#define	_ATOMIC_OR(typename, type)                                \
+  _CPU_Atomic_Fetch_or_##typename(volatile Atomic_##type *p, Atomic_##type v) {  \
+    __CPU_Atomic_Fetch_or_##typename(p, v, t);              \
+  _CPU_Atomic_Fetch_or_acq_##typename(volatile Atomic_##type *p, Atomic_##type v) { \
+  _CPU_Atomic_Fetch_or_rel_##typename(volatile Atomic_##type *p, Atomic_##type v) {	\
+  /* _ATOMIC_OR */
+_ATOMIC_OR(int, Int)
+_ATOMIC_OR(long, Long)
+#define _CPU_Atomic_Fetch_or_32(p, v)  \
+    _CPU_Atomic_Fetch_or_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_or_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_or_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_or_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_or_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_or_ptr(p, v) \
+#define _CPU_Atomic_Fetch_or_acq_ptr(p, v) \
+#define _CPU_Atomic_Fetch_or_rel_ptr(p, v) \
+#undef _ATOMIC_OR
+#undef __CPU_Atomic_Fetch_or_long
+#undef __CPU_Atomic_Fetch_or_int
+ * Atomic_Fetch_sub(p, v)
+ * { *p -= v; }
+#define __CPU_Atomic_Fetch_sub_int(p, v, t)             \
+  "	subf	%0, %3, %0\n"                           \
+  "	bne-	1b\n"                                   \
+  /* __CPU_Atomic_Fetch_sub_int */
+#define	__CPU_Atomic_Fetch_sub_long(p, v, t)            \
+  "	bne-	1b\n"                                   \
+  /* __CPU_Atomic_Fetch_sub_long */
+#define	_ATOMIC_SUB(typename, type)                               \
+  _CPU_Atomic_Fetch_sub_##typename(volatile Atomic_##type *p, Atomic_##type v) { \
+    __CPU_Atomic_Fetch_sub_##typename(p, v, t);             \
+  _CPU_Atomic_Fetch_sub_acq_##typename(volatile Atomic_##type *p, Atomic_##type v) { \
+  _CPU_Atomic_Fetch_sub_rel_##typename(volatile Atomic_##type *p, Atomic_##type v) { \
+  /* _ATOMIC_SUB */
+_ATOMIC_SUB(int, Int)
+_ATOMIC_SUB(long, Long)
+#define _CPU_Atomic_Fetch_sub_32(p, v)  \
+    _CPU_Atomic_Fetch_sub_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_sub_acq_32(p, v)  \
+    _CPU_Atomic_Fetch_sub_acq_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_sub_rel_32(p, v)  \
+    _CPU_Atomic_Fetch_sub_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Fetch_sub_ptr(p, v) \
+#define _CPU_Atomic_Fetch_sub_acq_ptr(p, v) \
+#define _CPU_Atomic_Fetch_sub_rel_ptr(p, v) \
+#undef _ATOMIC_SUB
+#undef __CPU_Atomic_Fetch_sub_long
+#undef __CPU_Atomic_Fetch_sub_int
+ * We assume that a = b will do atomic loads and stores.
+#define	ATOMIC_STORE_LOAD(TYPENAME, TYPE)                       \
+static __inline Atomic_##TYPE                                   \
+_CPU_Atomic_Load_##TYPENAME(volatile Atomic_##TYPE *p)          \
+  Atomic_##TYPE v;                                              \
+  v = *p;                                                       \
+  return (v);                                                   \
+_CPU_Atomic_Load_acq_##TYPENAME(volatile Atomic_##TYPE *p)      \
+  v = *p;                                                       \
+  return (v);                                                   \
+static __inline void                                            \
+_CPU_Atomic_Store_##TYPENAME(volatile Atomic_##TYPE *p, Atomic_##TYPE v)  \
+  *p = v;                                                       \
+_CPU_Atomic_Store_rel_##TYPENAME(volatile Atomic_##TYPE *p, Atomic_##TYPE v)  \
+  *p = v;                                                       \
+ATOMIC_STORE_LOAD(int, Int)
+#define _CPU_Atomic_Load_32(p)  \
+    _CPU_Atomic_Load_int((volatile Atomic_Int *)(p))
+#define _CPU_Atomic_Load_acq_32(p)  \
+    _CPU_Atomic_Load_acq_int((volatile Atomic_Int *)(p))
+#define _CPU_Atomic_Store_32(p, v)  \
+    _CPU_Atomic_Store_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+#define _CPU_Atomic_Store_rel_32(p, v)  \
+    _CPU_Atomic_Store_rel_int((volatile Atomic_Int *)(p), (Atomic_Int)(v))
+static __inline Atomic_Long
+_CPU_Atomic_Load_long(volatile Atomic_Long *addr)
+  return ((Atomic_Long)_CPU_Atomic_Load_int((volatile Atomic_Int *)addr));
+_CPU_Atomic_Load_acq_long(volatile Atomic_Long *addr)
+  return ((Atomic_Long)_CPU_Atomic_Load_acq_int((volatile Atomic_Int *)addr));
+_CPU_Atomic_Store_long(volatile Atomic_Long *addr, Atomic_Long val)
+  _CPU_Atomic_Store_int((volatile Atomic_Int *)addr, (Atomic_Int)val);
+_CPU_Atomic_Store_rel_long(volatile Atomic_Long *addr, Atomic_Long val)
+  _CPU_Atomic_Store_rel_int((volatile Atomic_Int *)addr, (Atomic_Int)val);
+#define _CPU_Atomic_Load_ptr(p) \
+#define _CPU_Atomic_Load_acq_ptr(p) \
+#define _CPU_Atomic_Store_ptr(p, v) \
+    _CPU_Atomic_Store_int((volatile Atomic_Int *)(p), (v))
+#define _CPU_Atomic_Store_rel_ptr(p, v) \
+    _CPU_Atomic_Store_rel_int((volatile Atomic_Int *)(p), (v))
+#undef ATOMIC_STORE_LOAD
+ *  * Atomically compare the value stored at *p with cmpval and if the
+ *   * two values are equal, update the value of *p with newval. Returns
+ *    * zero if the compare failed, nonzero otherwise.
+static __inline int
+_CPU_Atomic_Compare_exchange_int(volatile Atomic_Int* p, Atomic_Int cmpval, Atomic_Int newval)
+  int ret;
+  __asm __volatile (
+    "1:\tlwarx %0, 0, %2\n\t"    /* load old value */
+    "cmplw %3, %0\n\t"           /* compare */
+    "bne 2f\n\t"                 /* exit if not equal */
+    "stwcx. %4, 0, %2\n\t"       /* attempt to store */
+    "bne- 1b\n\t"                /* spin if failed */
+    "li %0, 1\n\t"               /* success - retval = 1 */
+    "b 3f\n\t"                   /* we've succeeded */
+    "2:\n\t"
+    "stwcx. %0, 0, %2\n\t"       /* clear reservation (74xx) */
+    "li %0, 0\n\t"               /* failure - retval = 0 */
+    "3:\n\t"
+    : "=&r" (ret), "=m" (*p)
+    : "r" (p), "r" (cmpval), "r" (newval), "m" (*p)
+    : "cc", "memory");
+  return (ret);
+_CPU_Atomic_Compare_exchange_long(volatile Atomic_Long* p, Atomic_Long cmpval, Atomic_Long newval)
+  int ret;
+    "2:\n\t"
+    "3:\n\t"
+  return (ret);
+_CPU_Atomic_Compare_exchange_acq_int(volatile Atomic_Int *p, Atomic_Int cmpval, Atomic_Int newval)
+  int retval;
+  retval = _CPU_Atomic_Compare_exchange_int(p, cmpval, newval);
+  __ATOMIC_BARRIER;
+  return (retval);
+_CPU_Atomic_Compare_exchange_rel_int(volatile Atomic_Int *p, Atomic_Int cmpval, Atomic_Int newval)
+  __ATOMIC_BARRIER;
+  return (_CPU_Atomic_Compare_exchange_int(p, cmpval, newval));
+_CPU_Atomic_Compare_exchange_acq_long(volatile Atomic_Long *p, Atomic_Long cmpval, Atomic_Long newval)
+  Atomic_Long retval;
+  retval = _CPU_Atomic_Compare_exchange_long(p, cmpval, newval);
+  __ATOMIC_BARRIER;
+  return (retval);
+_CPU_Atomic_Compare_exchange_rel_long(volatile Atomic_Long *p, Atomic_Long cmpval, Atomic_Long newval)
+  __ATOMIC_BARRIER;
+  return (_CPU_Atomic_Compare_exchange_long(p, cmpval, newval));
+#define _CPU_Atomic_Compare_exchange_32(dst, old, new)  \
+    _CPU_Atomic_Compare_exchange_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), (Atomic_Int)(new))
+#define _CPU_Atomic_Compare_exchange_acq_32(dst, old, new)  \
+    _CPU_Atomic_Compare_exchange_acq_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), (Atomic_Int)(new))
+#define _CPU_Atomic_Compare_exchange_rel_32(dst, old, new)  \
+    _CPU_Atomic_Compare_exchange_rel_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), (Atomic_Int)(new))
+#define _CPU_Atomic_Compare_exchange_ptr(dst, old, new) \
+#define _CPU_Atomic_Compare_exchange_acq_ptr(dst, old, new) \
+		_CPU_Atomic_Compare_exchange_acq_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), \
+				(Atomic_Int)(new))
+#define _CPU_Atomic_Compare_exchange_rel_ptr(dst, old, new) \
+		_CPU_Atomic_Compare_exchange_rel_int((volatile Atomic_Int *)(dst), (Atomic_Int)(old), \
+#ifdef __cplusplus
+#endif
+#endif
+/*  end of include file */
1.7.1
