[PATCH] sptests: Conditionally build atomic tests
Ralf Corsepius ralf.corsepius at rtems.org
Wed Feb 13 10:54:57 UTC 2013
On 02/13/2013 09:15 AM, Sebastian Huber wrote:
> This patch does not work.  On PowerPC Autoconf uses this:
> configure:4918: checking rtems/rtems/atomic.h usability
> configure:4918: powerpc-rtems4.11-gcc -c -mcpu=603e -Dppc603e -O2 -g -fno-keep-inline-functions -Wall -Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes -Wnested-externs  conftest.c >&5
> conftest.c:52:32: fatal error: rtems/rtems/atomic.h: No such file or directory
Reproducer?
> What is missing here is the -B option for the particular BSP compiler search
> path.  How can I teach Autoconf to use the BSP provided flags for the compiler?
They are supposed to be propagated automatically, through a pretty
complex mechanism.
That said, this sounds as if something might have been broken elsewhere.
I can try to have a look into it later today (more likely: tomorrow).
Besides this, using AM-CONDITIONAL-ized SUBDIRS inside of a Makefile.am
is a bad idea. They usually break make-recursion. Move the CONDITIONALS
into the subdir Makefile.ams, instead.
>   testsuites/sptests/Makefile.am  |   14 +++++++++++---
>   testsuites/sptests/configure.ac |    3 +++
>   2 files changed, 14 insertions(+), 3 deletions(-)
> diff --git a/testsuites/sptests/Makefile.am b/testsuites/sptests/Makefile.am
> index c9d20dd..86e269e 100644
> --- a/testsuites/sptests/Makefile.am
> +++ b/testsuites/sptests/Makefile.am
> @@ -27,14 +27,22 @@ SUBDIRS = \
>       spintrcritical17 spintrcritical18 spmkdir spmountmgr01 spheapprot \
>       spsimplesched01 spsimplesched02 spsimplesched03 spnsext01 \
>       spedfsched01 spedfsched02 spedfsched03 \
> -    spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01 \
> -    spatomic01 spatomic02 spatomic03 spatomic04 spatomic05 \
> -    spatomic06 spatomic07
> +    spcbssched01 spcbssched02 spcbssched03 spqreslib sptimespec01
>   SUBDIRS += spfatal26
>   SUBDIRS += speventtransient01
>   SUBDIRS += speventsystem01
>   SUBDIRS += spinternalerror01
>   SUBDIRS += spinternalerror02
> +if HAS_RTEMS_ATOMIC
> +SUBDIRS += spatomic01
> +SUBDIRS += spatomic02
> +SUBDIRS += spatomic03
> +SUBDIRS += spatomic04
> +SUBDIRS += spatomic05
> +SUBDIRS += spatomic06
> +SUBDIRS += spatomic07
> +endif
>   include $(top_srcdir)/../automake/subdirs.am
>   include $(top_srcdir)/../automake/local.am
> diff --git a/testsuites/sptests/configure.ac b/testsuites/sptests/configure.ac
> index a43a1ad..7687901 100644
> --- a/testsuites/sptests/configure.ac
> +++ b/testsuites/sptests/configure.ac
> @@ -22,6 +22,9 @@ RTEMS_CANONICALIZE_TOOLS
>   RTEMS_CHECK_CUSTOM_BSP(RTEMS_BSP)
> +AC_CHECK_HEADER([rtems/rtems/atomic.h])
> +AM_CONDITIONAL(HAS_RTEMS_ATOMIC,[test x"$ac_cv_header_rtems_rtems_atomic_h" = x"yes"])
>   # FIXME: We should get rid of this. It's a cludge.
>   AC_CHECK_SIZEOF([time_t])
Ralf
