[PATCH] mm: Add infrastructure for basic memory management
Sebastian Huber
Wed Feb 20 08:51:22 UTC 2013
On 02/18/2013 06:47 PM, Gedare Bloom wrote:
> + * @brief A managed _Memory_management_Region.
> +typedef struct {
> + char *name;
Why not const char *?
> + uintptr_t base;
> + size_t size;
Why different types for base and size?
> + bool installed;
Do we really need this state? The entry install and uninstall functions should
be idempotent.
> + /* points to structure defining the BSP specific MM entry */
> + void *bsp_mme;
> +} Memory_management_Entry;
Where does this bsp_mme value come from? I would not use the name BSP here.
Do we really need such a context pointer?
> +#ifndef __RTEMS_APPLICATION__
> +#include <rtems/score/mm.inl>
> +#endif
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/score/inline/rtems/score/mm.inl b/cpukit/score/inline/rtems/score/mm.inl
> new file mode 100644
> index 0000000..abe065d
> --- /dev/null
> +++ b/cpukit/score/inline/rtems/score/mm.inl
> @@ -0,0 +1,77 @@
> + * @file
> + * @brief Inlined Routines from the Memory Management Manager
> + * Copyright (c) 2013 Gedare Bloom.
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + *http://www.rtems.com/license/LICENSE.
> +#ifndef _RTEMS_SCORE_MM_H
> +# error "Never use <rtems/score/mm.inl> directly; include <rtems/score/mm.h> instead."
> +#endif
> +#ifndef _RTEMS_SCORE_MM_INL
> +#define _RTEMS_SCORE_MM_INL
> + * @addtogroup SuperCoreMM
> + * @brief Calls _CPU_Memory_management_Initialize.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Initialize( void )
> + _CPU_Memory_management_Initialize();
> + * @brief Calls _CPU_Memory_management_Install_entry.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Install_entry(
> + Memory_management_Entry *mme
> + _CPU_Memory_management_Install_entry(mme);
> + * @brief Calls _CPU_Memory_management_Uninstall_entry.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Uninstall_entry(
> + _CPU_Memory_management_Uninstall_entry(mme);
> + * @brief Calls _CPU_Memory_management_Set_write.
> +RTEMS_INLINE_ROUTINE void _Memory_management_Set_write(
> + _CPU_Memory_management_Set_write(mme);
> + * @brief Calls _CPU_Memory_management_Set_read_only
> +RTEMS_INLINE_ROUTINE void _Memory_management_Set_read_only(
> + _CPU_Memory_management_Set_read_only(mme);
I would not use set methods for attributes. I would use integer flags so we
can initialize an entry completely static in read-only memory.
I miss attributes to determine cache enable/disable, cache strategy, guarded
(non well-behaved memory), cache consistency (MSI, MESI, etc.), and executable
for example.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
