[PATCH] add __ARM_ARCH_6ZK__ to cpukit/score/cpu/arm/rtems/score/arm.h
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Feb 22 21:53:35 UTC 2013
On 2/20/2013 11:58 AM, Cudmore, Alan P. (GSFC-5820) wrote:
> This is the only non-bsp file I needed to change to support the Rasberry Pi.
> The Pi uses the Broadcom 2835, which in turn has the ARM1176jzf-s core. When I use the -mcpu=arm1176jzf-s option to build the BSP, the compiler defines __ARM_ARCH_6ZK__
> I don't know if GCC uses __ARM_ARCH_6ZK__ for other ARM models, or if we should select a different value for CPU_MODEL_NAME.
> Whatever you think is best.
I am happy with that definition. I just wanted something on
the mailing list record about what it corresponded to as
real silicon and gcc flags.
Thanks.
--joel
> Alan
> On Feb 20, 2013, at 12:44 PM, Joel <joel.sherrill at oarcorp.com> wrote:
>> Not that I see anything wrong with this but which CPU models
>> does this cover? :)
>> On 2/20/2013 11:41 AM, Cudmore, Alan P. (GSFC-5820) wrote:
>>> diff --git a/cpukit/score/cpu/arm/rtems/score/arm.h b/cpukit/score/cpu/arm/rtems/score/arm.h
>>> index 8f8c837..8471bb4 100644
>>> --- a/cpukit/score/cpu/arm/rtems/score/arm.h
>>> +++ b/cpukit/score/cpu/arm/rtems/score/arm.h
>>> @@ -69,6 +69,10 @@ extern "C" {
>>> # define CPU_MODEL_NAME "ARMv6J"
>>> # define ARM_MULTILIB_ARCH_V4
>>> +#elif defined(__ARM_ARCH_6ZK__)
>>> +# define CPU_MODEL_NAME "ARMv6ZK"
>>> +# define ARM_MULTILIB_ARCH_V4
>>> #elif defined(__ARM_ARCH_6M__)
>>> # define CPU_MODEL_NAME "ARMv6M"
>>> rtems-devel mailing list
>>> rtems-devel at rtems.org
>>> http://www.rtems.org/mailman/listinfo/rtems-devel
