[PATCH 2/2] posix: Reimplement POSIX Key manager to use a red-black tree.
Gedare Bloom
gedare at rtems.org
Sat Feb 23 14:40:32 UTC 2013
Thanks. I fixed some whitespace issues and sent to rtems-devel. I will
review soon and resolve the confdefs.h issue.
-Gedare
On Sat, Feb 23, 2013 at 12:01 AM, Ashi <ashi08104 at gmail.com> wrote:
> On Fri, Feb 22, 2013 at 10:38 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> I pulled this from github using the latest pull request you sent.
>> Maybe you posted an updated patch somewhere? Check to make sure there
>> are no other major issues to deal with and let me know if there are
>> any updates for me to pull. I will be looking to commit this work
>> soon. I will figure out the confdefs.h issue myself.
> I've checked there no other major issues to deal with. And the updated
> patches(without fixing confdefs.h issue) are attached.
>> On Thu, Feb 21, 2013 at 10:19 PM, Ashi <ashi08104 at gmail.com> wrote:
>> > Gedare, I feel this patch is a little old than my actually work, because
>> > some line I have removed before(like the "TODO" line), I haven't figured
>> > out
>> > which commit this patch is based.
>> > Anyway, I've updated according your comments.
>> > On Sat, Feb 9, 2013 at 9:15 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> On Thu, Feb 7, 2013 at 9:20 PM, Gedare Bloom <gedare at rtems.org> wrote:
>> >> > From: Zhongwei Yao <ashi08104 at gmail.com>
>> >> > The POSIX Key manager is reimplemented with a red-black tree to store
>> >> > the keys and values. This code was contributed as part of GSOC 2012.
>> >> > cpukit/posix/include/rtems/posix/key.h | 56
>> >> > cpukit/posix/include/rtems/posix/threadsup.h | 4 ++
>> >> > cpukit/posix/inline/rtems/posix/key.inl | 2 +-
>> >> > cpukit/posix/src/key.c | 52
>> >> > cpukit/posix/src/keycreate.c | 53
>> >> > cpukit/posix/src/keydelete.c | 4 +-
>> >> > cpukit/posix/src/keyfreememory.c | 35 ++++++++++++-
>> >> > cpukit/posix/src/keygetspecific.c | 21 +++++---
>> >> > cpukit/posix/src/keyrundestructors.c | 68
>> >> > cpukit/posix/src/keysetspecific.c | 32 +++++++++---
>> >> > cpukit/posix/src/pthread.c | 3 +
>> >> > cpukit/sapi/src/posixapi.c | 2 +-
>> >> > 12 files changed, 216 insertions(+), 116 deletions(-)
>> >> > diff --git a/cpukit/posix/include/rtems/posix/key.h
>> >> > b/cpukit/posix/include/rtems/posix/key.h
>> >> > index 0bb1dbe..80e534b 100644
>> >> > --- a/cpukit/posix/include/rtems/posix/key.h
>> >> > +++ b/cpukit/posix/include/rtems/posix/key.h
>> >> > @@ -8,6 +8,7 @@
>> >> > + * Copyright (c) 2012 Zhongwei Yao.
>> >> > * COPYRIGHT (c) 1989-2011.
>> >> > * On-Line Applications Research Corporation (OAR).
>> >> > @@ -20,6 +21,8 @@
>> >> > #define _RTEMS_POSIX_KEY_H
>> >> > #include <rtems/score/object.h>
>> >> > +#include <rtems/score/rbtree.h>
>> >> > +#include <rtems/score/chain.h>
>> >> > * @defgroup POSIX_KEY POSIX Key
>> >> > @@ -34,32 +37,57 @@ extern "C" {
>> >> > #endif
>> >> > - * This is the data Structure used to manage a POSIX key.
>> >> > - * NOTE: The Values is a table indexed by the index portion of the
>> >> > - * ID of the currently executing thread.
>> >> > + * @brief The rbtree node used to manage a POSIX key and value.
>> >> > typedef struct {
>> >> > - /** This field is the Object control structure. */
>> >> > - Objects_Control Object;
>> >> > - /** This field points to the optional destructor method. */
>> >> > - void (*destructor)( void * );
>> >> > - /** This field points to the values per thread. */
>> >> > - void **Values[ OBJECTS_APIS_LAST + 1 ];
>> >> > -} POSIX_Keys_Control;
>> >> > + /** This field is the chain node structure. */
>> >> > + Chain_Node ch_node;
>> >> > + /** This field is the rbtree node structure. */
>> >> > + RBTree_Node rb_node;
>> >> > + /** This field is the POSIX key used as an rbtree key */
>> >> > + pthread_key_t key;
>> >> > + /** This field is the Thread id also used as an rbtree key */
>> >> > + Objects_Id thread_id;
>> >> > + /** This field points to the POSIX key value of specific thread */
>> >> > + void *value;
>> >> > + } POSIX_Keys_Rbtree_node;
>> >> > - * The following defines the information control block used to
>> >> > manage
>> >> > - * this class of objects.
>> >> > + * @brief The data structure used to manage a POSIX key.
>> >> > +typedef struct {
>> >> > + /** This field is the Object control structure. */
>> >> > + Objects_Control object;
>> >> > + /** This field is the data destructor. */
>> >> > + void (*destructor) (void *);
>> >> > + } POSIX_Keys_Control;
>> >> > + * @brief The information control block used to manage this class of
>> >> > objects.
>> >> > POSIX_EXTERN Objects_Information _POSIX_Keys_Information;
>> >> > + * @brief The rbtree control block used to manage all key values
>> >> > +POSIX_EXTERN RBTree_Control _POSIX_Keys_Rbtree;
>> >> > * @brief POSIX keys manager initialization.
>> >> > * This routine performs the initialization necessary for this
>> >> > manager.
>> >> > -void _POSIX_Key_Manager_initialization(void);
>> >> > +void _POSIX_Keys_Manager_initialization(void);
>> >> > + * @brief POSIX keys Red-Black tree node comparison.
>> >> > + * This routine compares the rbtree node
>> >> > +int _POSIX_Keys_Rbtree_compare_function(
>> >> > + const RBTree_Node *node1,
>> >> > + const RBTree_Node *node2
>> >> > * @brief Create thread-specific data POSIX key.
>> >> > diff --git a/cpukit/posix/include/rtems/posix/threadsup.h
>> >> > b/cpukit/posix/include/rtems/posix/threadsup.h
>> >> > index 80f64dc..f47a7d4 100644
>> >> > --- a/cpukit/posix/include/rtems/posix/threadsup.h
>> >> > +++ b/cpukit/posix/include/rtems/posix/threadsup.h
>> >> > @@ -21,6 +21,7 @@
>> >> > #include <sys/signal.h>
>> >> > #include <rtems/score/coresem.h>
>> >> > #include <rtems/score/tqdata.h>
>> >> > * @defgroup POSIX_THREAD POSIX Thread API Extension
>> >> > @@ -78,6 +79,9 @@ typedef struct {
>> >> > int cancelation_requested;
>> >> > /** This is the set of cancelation handlers. */
>> >> > Chain_Control Cancellation_Handlers;
>> >> > + /** This is the thread key value chain's control */
>> >> > + Chain_Control the_chain;
>> >> Perhaps a more descriptive variable name? Also the name the_chain
>> >> should be in initial capitals because it is an aggregate structure.
>> >> Finally, we should make a note of why this chain exists. it is
>> >> needed to iterate through the keys of a given thread when destroying
>> >> the thread.
>> > Yeah, that's the point. I've add a little more detail in comment.
>> >> > } POSIX_API_Control;
>> >> > diff --git a/cpukit/posix/inline/rtems/posix/key.inl
>> >> > b/cpukit/posix/inline/rtems/posix/key.inl
>> >> > index ce5601b..9469580 100644
>> >> > --- a/cpukit/posix/inline/rtems/posix/key.inl
>> >> > +++ b/cpukit/posix/inline/rtems/posix/key.inl
>> >> > @@ -45,7 +45,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free (
>> >> > POSIX_Keys_Control *the_key
>> >> > - _Objects_Free( &_POSIX_Keys_Information, &the_key->Object );
>> >> > + _Objects_Free( &_POSIX_Keys_Information, &the_key->object );
>> >> > diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
>> >> > index 6eace26..b0a1f86 100644
>> >> > --- a/cpukit/posix/src/key.c
>> >> > +++ b/cpukit/posix/src/key.c
>> >> > @@ -29,6 +29,49 @@
>> >> > #include <rtems/score/thread.h>
>> >> > #include <rtems/score/wkspace.h>
>> >> > #include <rtems/posix/key.h>
>> >> > + * _POSIX_Keys_Rbtree_compare_function
>> >> > + * DESCRIPTION:
>> >> > + * by comparing POSIX key first and comparing thread id second.
>> >> > + * And if either of the input nodes's thread_id member is 0, then
>> >> > + * it will only compare the pthread_key_t member. That is when we
>> >> > + * pass thread_id = 0 node as a search node, the search is done only
>> >> > + * by pthread_key_t.
>> >> > + * Input parameters: two rbtree node
>> >> > + * Output parameters: return positive if first node
>> >> > + * has higher key than second, negative if lower, 0 if equal,
>> >> > + * and for all the thread id is unique, then return 0 is impossible
>> >> > + pthread_key_t key1 = _RBTree_Container_of(node1,
>> >> > POSIX_Keys_Rbtree_node, rb_node)->key;
>> >> > + pthread_key_t key2 = _RBTree_Container_of(node2,
>> >> > + Objects_Id thread_id1 = _RBTree_Container_of(node1,
>> >> > POSIX_Keys_Rbtree_node, rb_node)->thread_id;
>> >> > + Objects_Id thread_id2 = _RBTree_Container_of(node2,
>> >> These lines are too long (>80 char) and need to be broken. I think
>> >> there are a few others in this patch too.
>> > I remember there is a format check script, which I also have run it my
>> > code...
>> >> > + int diff = key1 - key2;
>> >> > + if ( diff )
>> >> > + return diff;
>> >> > + * if thread_id1 or thread_id2 equals to 0, only key1 and key2 is
>> >> > valued.
>> >> > + * it enables us search node only by pthread_key_t type key.
>> >> > + if ( thread_id1 && thread_id2 )
>> >> > + return thread_id1 - thread_id2;
>> >> > + return 0;
>> >> > * _POSIX_Key_Manager_initialization
>> >> > @@ -42,7 +85,7 @@
>> >> > * Output parameters: NONE
>> >> > _Objects_Initialize_information(
>> >> > &_POSIX_Keys_Information, /* object information table */
>> >> > @@ -60,4 +103,11 @@ void _POSIX_Key_Manager_initialization(void)
>> >> > NULL /* Proxy extraction support callout
>> >> > #endif
>> >> > + _RBTree_Initialize_empty(
>> >> > + &_POSIX_Keys_Rbtree, /* the rbtree control block */
>> >> > + _POSIX_Keys_Rbtree_compare_function,
>> >> > + /* the rbtree compare function */
>> >> > + true /* true if each rbtree node is unique */
>> >> I don't think the parameter comments here are necessary.
>> >> > diff --git a/cpukit/posix/src/keycreate.c
>> >> > b/cpukit/posix/src/keycreate.c
>> >> > index b41b590..84a4d9c 100644
>> >> > --- a/cpukit/posix/src/keycreate.c
>> >> > +++ b/cpukit/posix/src/keycreate.c
>> >> > @@ -37,10 +37,6 @@ int pthread_key_create(
>> >> > POSIX_Keys_Control *the_key;
>> >> > - void *table;
>> >> > - uint32_t the_api;
>> >> > - uint32_t bytes_to_allocate;
>> >> > _Thread_Disable_dispatch();
>> >> > @@ -52,52 +48,9 @@ int pthread_key_create(
>> >> > the_key->destructor = destructor;
>> >> > - * This is a bit more complex than one might initially expect
>> >> > because
>> >> > - * APIs are optional.
>> >> > - * NOTE: Currently RTEMS Classic API tasks are always enabled.
>> >> > - for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
>> >> > - the_key->Values[ the_api ] = NULL;
>> >> > - #if defined(RTEMS_DEBUG)
>> >> > - * Since the removal of ITRON, this cannot occur.
>> >> > - if ( !_Objects_Information_table[ the_api ] )
>> >> > - continue;
>> >> > - * Currently all managers are installed if the API is
>> >> > installed.
>> >> > - * This would be a horrible implementation error.
>> >> > - if (_Objects_Information_table[ the_api ][ 1 ] == NULL )
>> >> > - _Internal_error_Occurred(
>> >> > - INTERNAL_ERROR_CORE,
>> >> > - true,
>> >> > - INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
>> >> > - #endif
>> >> > - bytes_to_allocate = sizeof( void * ) *
>> >> > - (_Objects_Information_table[ the_api ][ 1 ]->maximum + 1);
>> >> > - table = _Workspace_Allocate( bytes_to_allocate );
>> >> > - if ( !table ) {
>> >> > - _POSIX_Keys_Free_memory( the_key );
>> >> > - _POSIX_Keys_Free( the_key );
>> >> > - _Thread_Enable_dispatch();
>> >> > - return ENOMEM;
>> >> > - the_key->Values[ the_api ] = table;
>> >> > - memset( table, '\0', bytes_to_allocate );
>> >> > - _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0
>> >> > - *key = the_key->Object.id;
>> >> > + /*problem: not clear about _Objects_Open_u32() */
>> >> > + _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->object, 0
>> >> I believe you need to "open" the object for RTEMS object
>> >> tracking..like reference counting. Not sure though.
>> > OK.
>> >> > + *key = the_key->object.id;
>> >> > return 0;
>> >> > diff --git a/cpukit/posix/src/keydelete.c
>> >> > b/cpukit/posix/src/keydelete.c
>> >> > index 5ef6261..f45e264 100644
>> >> > --- a/cpukit/posix/src/keydelete.c
>> >> > +++ b/cpukit/posix/src/keydelete.c
>> >> > @@ -42,9 +42,9 @@ int pthread_key_delete(
>> >> > switch ( location ) {
>> >> > case OBJECTS_LOCAL:
>> >> > - _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
>> >> > + /* problem: should it done before _POSIX_Keys_Free_memory? */
>> >> > + _Objects_Close( &_POSIX_Keys_Information, &the_key->object );
>> >> I think you need to be finished with the_key before closing it.
>> > I see.
>> >> > * NOTE: The destructor is not called and it is the
>> >> > responsibility
>> >> > diff --git a/cpukit/posix/src/keyfreememory.c
>> >> > b/cpukit/posix/src/keyfreememory.c
>> >> > index f71af4f..50f560e 100644
>> >> > --- a/cpukit/posix/src/keyfreememory.c
>> >> > +++ b/cpukit/posix/src/keyfreememory.c
>> >> > @@ -21,14 +21,43 @@
>> >> > #include <rtems/system.h>
>> >> > void _POSIX_Keys_Free_memory(
>> >> > - uint32_t the_api;
>> >> > + POSIX_Keys_Rbtree_node search_node;
>> >> > + POSIX_Keys_Rbtree_node *p;
>> >> > + RBTree_Node *iter, *next;
>> >> > - _Workspace_Free( the_key->Values[ the_api ] );
>> >> > + search_node.key = the_key->object.id;
>> >> > + search_node.thread_id = 0;
>> >> > + iter = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
>> >> > &search_node.rb_node);
>> >> > + if ( !iter )
>> >> > + return;
>> >> > + * find the smallest thread_id node in the rbtree.
>> >> > + next = _RBTree_Next_unprotected( iter, RBT_LEFT );
>> >> > + p = _RBTree_Container_of( next, POSIX_Keys_Rbtree_node, rb_node );
>> >> > + while ( p->key == the_key->object.id) {
>> >> > + iter = next;
>> >> > + * delete all nodes belongs to the_key from the rbtree and chain.
>> >> > + p = _RBTree_Container_of( iter, POSIX_Keys_Rbtree_node, rb_node );
>> >> > + while ( p->key == the_key->object.id ) {
>> >> > + next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
>> >> > + _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree, iter );
>> >> > + _Chain_Extract_unprotected( &p->ch_node );
>> >> > + _Workspace_Free( p );
>> >> > + iter = next;
>> >> > diff --git a/cpukit/posix/src/keygetspecific.c
>> >> > b/cpukit/posix/src/keygetspecific.c
>> >> > index debad83..61adea6 100644
>> >> > --- a/cpukit/posix/src/keygetspecific.c
>> >> > +++ b/cpukit/posix/src/keygetspecific.c
>> >> > @@ -26,6 +26,7 @@
>> >> > @@ -36,19 +37,23 @@ void *pthread_getspecific(
>> >> > pthread_key_t key
>> >> > - register POSIX_Keys_Control *the_key;
>> >> > - uint32_t api;
>> >> > - uint32_t index;
>> >> > Objects_Locations location;
>> >> > + RBTree_Node *p;
>> >> > void *key_data;
>> >> > - the_key = _POSIX_Keys_Get( key, &location );
>> >> > + _POSIX_Keys_Get( key, &location );
>> >> > case OBJECTS_LOCAL:
>> >> > - api = _Objects_Get_API( _Thread_Executing->Object.id );
>> >> > - index = _Objects_Get_index( _Thread_Executing->Object.id );
>> >> > - key_data = (void *) the_key->Values[ api ][ index ];
>> >> > + /** TODO: search the node in TCB's chain(maybe the rbtree) to
>> >> > speed up the search */
>> >> Is this TODO still relevant? I don't quite understand it.
>> > I thought search a node in chain's runtime is O(n1) and in rbtree is
>> > O(log(n2), where n2 is bigger than n1,
>> > so I think there is no big difference between these two and this TODO
>> > can be
>> > removed.
>> >> > + search_node.key = key;
>> >> > + search_node.thread_id = _Thread_Executing->Object.id;
>> >> > + p = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
>> >> > + key_data = NULL;
>> >> > + if ( p ) {
>> >> > + key_data = _RBTree_Container_of( p, POSIX_Keys_Rbtree_node,
>> >> > rb_node )->value;
>> >> > return key_data;
>> >> > diff --git a/cpukit/posix/src/keyrundestructors.c
>> >> > b/cpukit/posix/src/keyrundestructors.c
>> >> > index 9f48888..687217c 100644
>> >> > --- a/cpukit/posix/src/keyrundestructors.c
>> >> > +++ b/cpukit/posix/src/keyrundestructors.c
>> >> > @@ -23,7 +23,10 @@
>> >> > +#include <rtems/score/wkspace.h>
>> >> > +#include <rtems/posix/threadsup.h>
>> >> > * _POSIX_Keys_Run_destructors
>> >> > @@ -38,36 +41,43 @@ void _POSIX_Keys_Run_destructors(
>> >> > Thread_Control *thread
>> >> > - Objects_Maximum thread_index = _Objects_Get_index(
>> >> > thread->Object.id
>> >> > - Objects_APIs thread_api = _Objects_Get_API( thread->Object.id );
>> >> > - bool done = false;
>> >> > + Chain_Control *chain;
>> >> > + Chain_Node *iter, *next;
>> >> > + void *value;
>> >> > + POSIX_Keys_Control *the_key;
>> >> > + Objects_Locations location;
>> >> > - * The standard allows one to avoid a potential infinite loop and
>> >> > limit the
>> >> > - * number of iterations. An infinite loop may happen if
>> >> > destructors
>> >> > set
>> >> > - * thread specific data. This can be considered dubious.
>> >> > - * Reference: 17.1.1.2 P1003.1c/Draft 10, p. 163, line 99.
>> >> > - while ( !done ) {
>> >> > - Objects_Maximum index = 0;
>> >> > - Objects_Maximum max = _POSIX_Keys_Information.maximum;
>> >> > + _Thread_Disable_dispatch();
>> >> > + chain = &((POSIX_API_Control *)thread->API_Extensions[
>> >> > THREAD_API_POSIX ])->the_chain;
>> >> > + iter = _Chain_First( chain );
>> >> > + while ( !_Chain_Is_tail( chain, iter ) ) {
>> >> > + next = _Chain_Next( iter );
>> >> > + * remove key from rbtree and chain.
>> >> > + * here Chain_Node *iter can be convert to
>> >> > + * because Chain_Node is the first member of
>> >> > structure.
>> >> > &((POSIX_Keys_Rbtree_node *)iter)->rb_node );
>> >> > + _Chain_Extract_unprotected( iter );
>> >> > - done = true;
>> >> > - for ( index = 1 ; index <= max ; ++index ) {
>> >> > - POSIX_Keys_Control *key = (POSIX_Keys_Control *)
>> >> > - _POSIX_Keys_Information.local_table [ index ];
>> >> > - if ( key != NULL && key->destructor != NULL ) {
>> >> > - void *value = key->Values [ thread_api ][ thread_index ];
>> >> > - if ( value != NULL ) {
>> >> > - key->Values [ thread_api ][ thread_index ] = NULL;
>> >> > - (*key->destructor)( value );
>> >> > - done = false;
>> >> > + * run key value's destructor if destructor and value are both
>> >> > non-null.
>> >> > + the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node
>> >> > *)iter)->key,
>> >> > &location);
>> >> > + destructor = the_key->destructor;
>> >> > + value = ((POSIX_Keys_Rbtree_node *)iter)->value;
>> >> > + if ( destructor != NULL && value != NULL )
>> >> > + (*destructor)( value );
>> >> > + * disable dispatch is nested here
>> >> > + _Thread_Enable_dispatch();
>> >> > + _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
>> >> > + iter = next;
>> >> > diff --git a/cpukit/posix/src/keysetspecific.c
>> >> > b/cpukit/posix/src/keysetspecific.c
>> >> > index b25e44c..eeb4d84 100644
>> >> > --- a/cpukit/posix/src/keysetspecific.c
>> >> > +++ b/cpukit/posix/src/keysetspecific.c
>> >> > @@ -26,7 +26,9 @@
>> >> > * 17.1.2 Thread-Specific Data Management, P1003.1c/Draft 10, p.
>> >> > 165
>> >> > @@ -37,18 +39,34 @@ int pthread_setspecific(
>> >> > const void *value
>> >> > - uint32_t api;
>> >> > - uint32_t index;
>> >> > + POSIX_Keys_Rbtree_node *rb_node;
>> >> > + POSIX_API_Control *api;
>> >> > + /** _POSIX_Keys_Get() would call _Thread_Disable_dispatch()
>> >> > implicitly*/
>> >> > case OBJECTS_LOCAL:
>> >> > - the_key->Values[ api ][ index ] = (void *) value;
>> >> > + rb_node = _Workspace_Allocate( sizeof( POSIX_Keys_Rbtree_node
>> >> This allocation needs to be accounted for in confdefs.h
>> > I remember we have discussed this before, the exactly post
>> > is:http://www.rtems.org/pipermail/rtems-devel/2012-August/001712.html,
>> > but seem there is no conclusion yet.
>> >> > + if ( !rb_node ) {
>> >> > + return ENOMEM;
>> >> > + rb_node->key = key;
>> >> > + rb_node->thread_id = _Thread_Executing->Object.id;
>> >> > + rb_node->value = value;
>> >> > + if (_RBTree_Insert_unprotected( &_POSIX_Keys_Rbtree,
>> >> > &(rb_node->rb_node) ) ) {
>> >> > + _Workspace_Free( rb_node );
>> >> > + return EAGAIN;
>> >> > + /** append rb_node to the thread API extension's chain */
>> >> > + api = (POSIX_API_Control
>> >> > *)(_Thread_Executing->API_Extensions[THREAD_API_POSIX]);
>> >> > + _Chain_Append_unprotected( &api->the_chain, &rb_node->ch_node
>> >> > return 0;
>> >> > diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
>> >> > index 873449a..22c835f 100644
>> >> > --- a/cpukit/posix/src/pthread.c
>> >> > +++ b/cpukit/posix/src/pthread.c
>> >> > @@ -234,6 +234,9 @@ static bool _POSIX_Threads_Create_extension(
>> >> > created
>> >> > + /** initialize thread's key vaule node chain */
>> >> > + _Chain_Initialize_empty( &api->the_chain );
>> >> > return true;
>> >> > diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
>> >> > index 3f65442..b5e62c2 100644
>> >> > --- a/cpukit/sapi/src/posixapi.c
>> >> > +++ b/cpukit/sapi/src/posixapi.c
>> >> > @@ -64,7 +64,7 @@ void _POSIX_API_Initialize(void)
>> >> > _POSIX_signals_Manager_Initialization();
>> >> > _POSIX_Threads_Manager_initialization();
>> >> > _POSIX_Condition_variables_Manager_initialization();
>> >> > - _POSIX_Key_Manager_initialization();
>> >> > + _POSIX_Keys_Manager_initialization();
>> >> > _POSIX_Mutex_Manager_initialization();
>> >> > _POSIX_Message_queue_Manager_initialization();
>> >> > _POSIX_Semaphore_Manager_initialization();
>> >> > 1.7.1
> Thanks,
> Zhongwei Yao
