On 2/26/2013 7:04 AM, Ralf Corsepius wrote:
> On 02/26/2013 01:18 PM, Joel Sherrill wrote:
>> I appreciate you fixing these but I have a local branch I am about to push which fixes this and about a dozen other things. Save your effort until I push it.
> OK, I can stop investigating texinfo-5.0 and your doc build issues.
I just didn't want you to waste time investigating texinfo 5.0 when I had
texiany support in a local branch and multiple fixes to texinfo files. I
have
pushed it now so there won't be any duplicate work.
I just pushed my branch. The summary is:
+ If texi2any (e.g. texinfo 5.0) is in PATH, use it instead of texi2html.
This includes a handful of fairly small and tedious changes:
- added texi2any init file
- added some autoconf logic
- added texi2any invocation
+ I switched us to an html file naming convention recommended by
the texinfo maintainers for stable URLs. This means generated html
files are based on section names rather than $(PROJECT)_nnn.html.
This is based on a standard from around 2004 per them. This is
the preferred way of doing things now and the old way isn't supported
by texi2any.
- This required modification of the html dependency rules. I don't
know
if they are 100% correct but they work.
+ I updated two figures which were rotated 90% incorrectly in the manual.
+ I did a fair amount of rework on the master document files $(PROJECT).texi
because we apparently got away with some incorrect texinfo with the
older tools.
+ Many PDFs included a page with nothing but the title page. This was
the @top node incorrectly being included in the PDF and other printable
formats.
+ Multiple minor issues I spotted while reviewing:
- I updated the preface to add a couple of architectures.
- I fixed the overview since it didn't list all the chapters and
those that it
did list were not always in the right order.
- I fixed a few places where the lines were too long and ran into the
gutter.
- I corrected at least one code example which was clearly out of date.
- Copyright and modified dates touched
Since updating to texi2any is going to eventually be faced by others, I
wrote a
blog entry this weekend:
http://rtemsramblings.blogspot.com/2013/02/rtems-texinfo-tools-update.html
At this point, I think it at least builds with old or new texinfo and
the PDF output is
improved.
At this point, I don't have any more outstanding patches but I do think
we are
due for a "group documentation review sprint". With a bit of group
participation,
maybe we can split up documents by chapter and get a reviewer per chapter.
Now we won't duplicate work. I was just trying to safe you some work
Thanks.
> rtems-devel mailing list
> rtems-devel at rtems.org
