[PATCH 1/2] Add Moxie CPU support
Anthony Green green at moxielogic.com
Tue Feb 26 21:22:09 UTC 2013
Signed-off-by: Anthony Green <green at moxielogic.com>
 cpukit/score/cpu/moxie/.cvsignore          |    2 +
 cpukit/score/cpu/moxie/ChangeLog           |    4 +
 cpukit/score/cpu/moxie/Makefile.am         |   19 +
 cpukit/score/cpu/moxie/cpu.c               |  152 ++++
 cpukit/score/cpu/moxie/cpu_asm.S           |  119 ++++
 cpukit/score/cpu/moxie/preinstall.am       |   41 ++
 cpukit/score/cpu/moxie/rtems/asm.h         |  116 +++
 cpukit/score/cpu/moxie/rtems/score/cpu.h   | 1059 ++++++++++++++++++++++++++++
 cpukit/score/cpu/moxie/rtems/score/moxie.h |   45 ++
 cpukit/score/cpu/moxie/rtems/score/types.h |   55 ++
 10 files changed, 1612 insertions(+)
 create mode 100644 cpukit/score/cpu/moxie/.cvsignore
 create mode 100644 cpukit/score/cpu/moxie/ChangeLog
 create mode 100644 cpukit/score/cpu/moxie/Makefile.am
 create mode 100644 cpukit/score/cpu/moxie/cpu.c
 create mode 100644 cpukit/score/cpu/moxie/cpu_asm.S
 create mode 100644 cpukit/score/cpu/moxie/preinstall.am
 create mode 100644 cpukit/score/cpu/moxie/rtems/asm.h
 create mode 100644 cpukit/score/cpu/moxie/rtems/score/cpu.h
 create mode 100644 cpukit/score/cpu/moxie/rtems/score/moxie.h
 create mode 100644 cpukit/score/cpu/moxie/rtems/score/types.h
diff --git a/cpukit/score/cpu/moxie/.cvsignore b/cpukit/score/cpu/moxie/.cvsignore
new file mode 100644
index 0000000..282522d
--- /dev/null
+++ b/cpukit/score/cpu/moxie/.cvsignore
@@ -0,0 +1,2 @@
+Makefile
+Makefile.in
diff --git a/cpukit/score/cpu/moxie/ChangeLog b/cpukit/score/cpu/moxie/ChangeLog
index 0000000..8ff4a37
--- /dev/null
+++ b/cpukit/score/cpu/moxie/ChangeLog
@@ -0,0 +1,4 @@
+2013-02-26  Anthony Green <green at moxielogic.com>
+	* cpu_asm.S, cpu.c, Makefile.am, preinstall.am,
+	rtems/score/moxie.h, rtems/score/types.h, rtems/asm.h: New files.
diff --git a/cpukit/score/cpu/moxie/Makefile.am b/cpukit/score/cpu/moxie/Makefile.am
index 0000000..16c8af7
--- /dev/null
+++ b/cpukit/score/cpu/moxie/Makefile.am
@@ -0,0 +1,19 @@
+## $Id: Makefile.am,v 1.35 2006/01/12 09:57:43 ralf Exp $
+include $(top_srcdir)/automake/compile.am
+include_rtemsdir = $(includedir)/rtems
+include_rtems_HEADERS = rtems/asm.h
+include_rtems_scoredir = $(includedir)/rtems/score
+include_rtems_score_HEADERS = rtems/score/cpu.h rtems/score/moxie.h \
+    rtems/score/types.h
+noinst_LIBRARIES = libscorecpu.a
+libscorecpu_a_SOURCES = cpu.c cpu_asm.S
+libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
+include $(srcdir)/preinstall.am
+include $(top_srcdir)/automake/local.am
diff --git a/cpukit/score/cpu/moxie/cpu.c b/cpukit/score/cpu/moxie/cpu.c
index 0000000..7f24a31
--- /dev/null
+++ b/cpukit/score/cpu/moxie/cpu.c
@@ -0,0 +1,152 @@
+ *  Moxie CPU Dependent Source
+ *  COPYRIGHT (c) 2011 Anthony Green
+ *  Based on example code and other ports with this copyright:
+ *  COPYRIGHT (c) 1989-1999, 2010.
+ *  On-Line Applications Research Corporation (OAR).
+ *  The license and distribution terms for this file may be
+ *  found in the file LICENSE in this distribution or at
+ *  http://www.rtems.com/license/LICENSE.
+ *  $Id: cpu.c,v 1.11 2010/03/27 15:01:35 joel Exp $
+#ifdef HAVE_CONFIG_H
+#include "config.h"
+#endif
+#include <rtems/system.h>
+#include <rtems/score/isr.h>
+#include <rtems/score/wkspace.h>
+/*  _CPU_Initialize
+ *  This routine performs processor dependent initialization.
+ *  INPUT PARAMETERS: NONE
+void _CPU_Initialize(void)
+   *  If there is not an easy way to initialize the FP context
+   *  during Context_Initialize, then it is usually easier to
+   *  save an "uninitialized" FP context here and copy it to
+   *  the task's during Context_Initialize.
+  /* FP context initialization support goes here */
+/*PAGE
+ *  _CPU_ISR_Get_level
+ *  This routine returns the current interrupt level.
+uint32_t   _CPU_ISR_Get_level( void )
+  return 0;
+/*PAGE
+ *  _CPU_ISR_install_raw_handler
+void _CPU_ISR_install_raw_handler(
+  uint32_t    vector,
+  proc_ptr    new_handler,
+  proc_ptr   *old_handler
+   *  This is where we install the interrupt handler into the "raw" interrupt
+   *  table used by the CPU to dispatch interrupt handlers.
+   *  Use Debug level IRQ Handlers
+  /* H8BD_Install_IRQ(vector,new_handler,old_handler); */
+/*PAGE
+ *  _CPU_ISR_install_vector
+ *  This kernel routine installs the RTEMS handler for the
+ *  specified vector.
+ *  Input parameters:
+ *    vector      - interrupt vector number
+ *    old_handler - former ISR for this vector number
+ *    new_handler - replacement ISR for this vector number
+ *  Output parameters:  NONE
+void _CPU_ISR_install_vector(
+  uint32_t    vector,
+   *old_handler = _ISR_Vector_table[ vector ];
+    *  If the interrupt vector table is a table of pointer to isr entry
+    *  points, then we need to install the appropriate RTEMS interrupt
+    *  handler for this vector number.
+   _CPU_ISR_install_raw_handler( vector, new_handler, old_handler );
+    *  We put the actual user ISR address in '_ISR_vector_table'.  This will
+    *  be used by the _ISR_Handler so the user gets control.
+    _ISR_Vector_table[ vector ] = new_handler;
+/*PAGE
+ *  _CPU_Install_interrupt_stack
+void _CPU_Install_interrupt_stack( void )
+/*PAGE
+ *  _CPU_Thread_Idle_body
+ *  NOTES:
+ *  1. This is the same as the regular CPU independent algorithm.
+ *  2. If you implement this using a "halt", "idle", or "shutdown"
+ *     instruction, then don't forget to put it in an infinite loop.
+ *  3. Be warned. Some processors with onboard DMA have been known
+ *     to stop the DMA if the CPU were put in IDLE mode.  This might
+ *     also be a problem with other on-chip peripherals.  So use this
+ *     hook with caution.
+#if 0
+void *_CPU_Thread_Idle_body( uintptr_t ignored )
+  for( ; ; )
+    IDLE_Monitor();
+	/*asm("	sleep	\n"); */
+    /* insert your "halt" instruction here */ ;
+#endif
diff --git a/cpukit/score/cpu/moxie/cpu_asm.S b/cpukit/score/cpu/moxie/cpu_asm.S
index 0000000..4fc2706
--- /dev/null
+++ b/cpukit/score/cpu/moxie/cpu_asm.S
@@ -0,0 +1,119 @@
+ * Moxie CPU functions
+ *   Copyright (C) 2011 Anthony Green
+ *  COPYRIGHT (c) 1989-1999.
+ *  $Id: cpu_asm.S,v 1.12 2010/06/29 00:31:09 joel Exp $
+#endif
+#include <rtems/asm.h>
+	.text
+	.align 2
+	.global	SYM(_CPU_Context_switch)
+SYM(_CPU_Context_switch):
+	sto.l	0($r0), $fp
+	sto.l	4($r0), $sp
+	sto.l	8($r0), $r0
+	sto.l	12($r0), $r1
+	sto.l	16($r0), $r2
+	sto.l	20($r0), $r3
+	sto.l	24($r0), $r4
+	sto.l	28($r0), $r5
+	sto.l	32($r0), $r6
+	sto.l	36($r0), $r7
+	sto.l	40($r0), $r8
+	sto.l	44($r0), $r9
+	sto.l	48($r0), $r10
+	sto.l	52($r0), $r11
+	sto.l	56($r0), $r12
+	sto.l	60($r0), $r13
+restore:
+	ldo.l	$fp, 0($r1)
+	ldo.l	$sp, 4($r1)
+	ldo.l	$r0, 8($r1)
+	ldo.l	$r2, 16($r1)
+	ldo.l	$r3, 20($r1)
+	ldo.l	$r4, 24($r1)
+	ldo.l	$r5, 28($r1)
+	ldo.l	$r6, 32($r1)
+	ldo.l	$r7, 36($r1)
+	ldo.l	$r8, 40($r1)
+	ldo.l	$r9, 44($r1)
+	ldo.l	$r10, 48($r1)
+	ldo.l	$r11, 52($r1)
+	ldo.l	$r12, 56($r1)
+	ldo.l	$r13, 60($r1)
+	ldo.l	$r1, 12($r1)
+	ret
+	.align 2
+	.global	SYM(_CPU_Context_restore)
+SYM(_CPU_Context_restore):
+	mov	$r1, $r0
+	jmpa	restore
+	VHandler for Vectored Interrupts
+	All IRQ's are vectored to routine _ISR_#vector_number
+	This routine stacks er0 and loads er0 with vector number
+	before transferring to here
+	.align 2
+	.global	SYM(_ISR_Handler)
+	.extern	SYM(_Vector_table)
+SYM(_ISR_Handler):
+	brk
+	Called from ISR_Handler as a way of ending IRQ
+	but allowing dispatch to another task.
+	Must use RTE as CCR is still on stack but IRQ has been serviced.
+	CCR and PC occupy same word so rte can be used.
+	now using task stack
+	.align 2
+	.global SYM(_ISR_Dispatch)
+SYM(_ISR_Dispatch):
+	brk
+	.align 2
+	.global SYM(_CPU_Context_save_fp)
+SYM(_CPU_Context_save_fp):
+	brk
+	.align 2
+	.global SYM(_CPU_Context_restore_fp)
+SYM(_CPU_Context_restore_fp):
+	brk
diff --git a/cpukit/score/cpu/moxie/preinstall.am b/cpukit/score/cpu/moxie/preinstall.am
index 0000000..62a2390
--- /dev/null
+++ b/cpukit/score/cpu/moxie/preinstall.am
@@ -0,0 +1,41 @@
+## Automatically generated by ampolish3 - Do not edit
+if AMPOLISH3
+$(srcdir)/preinstall.am: Makefile.am
+	$(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
+endif
+PREINSTALL_DIRS =
+DISTCLEANFILES = $(PREINSTALL_DIRS)
+all-am: $(PREINSTALL_FILES)
+PREINSTALL_FILES =
+CLEANFILES = $(PREINSTALL_FILES)
+$(PROJECT_INCLUDE)/rtems/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
+	@: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
+$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
+	@$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
+	@: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
+$(PROJECT_INCLUDE)/rtems/score/moxie.h: rtems/score/moxie.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/moxie.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/moxie.h
+$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
diff --git a/cpukit/score/cpu/moxie/rtems/asm.h b/cpukit/score/cpu/moxie/rtems/asm.h
index 0000000..e2a54c9
--- /dev/null
+++ b/cpukit/score/cpu/moxie/rtems/asm.h
@@ -0,0 +1,116 @@
+ * @file rtems/asm.h
+ *  This include file attempts to address the problems
+ *  caused by incompatible flavors of assemblers and
+ *  toolsets.  It primarily addresses variations in the
+ *  use of leading underscores on symbols and the requirement
+ *  that register names be preceded by a %.
+ *  NOTE: The spacing in the use of these macros
+ *        is critical to them working as advertised.
+ *  COPYRIGHT:
+ *  This file is based on similar code found in newlib available
+ *  from ftp.cygnus.com.  The file which was used had no copyright
+ *  notice.  This file is freely distributable as long as the source
+ *  of the file is noted.  This file is:
+ *  Anthony Green
+ *  $Id: asm.h,v 1.9 2010/06/29 00:31:09 joel Exp $
+#ifndef _RTEMS_ASM_H
+#define _RTEMS_ASM_H
+ *  Indicate we are in an assembly file and get the basic CPU definitions.
+#include <rtems/score/moxie.h>
+ *  Recent versions of GNU cpp define variables which indicate the
+ *  need for underscores and percents.  If not using GNU cpp or
+ *  the version does not support this, then you will obviously
+ *  have to define these as appropriate.
+#ifndef __USER_LABEL_PREFIX__
+#define __USER_LABEL_PREFIX__
+#endif
+#ifndef __REGISTER_PREFIX__
+#define __REGISTER_PREFIX__ "$"
+#endif
+#include <rtems/concat.h>
+/* Use the right prefix for global labels.  */
+#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
+/* Use the right prefix for registers.  */
+#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
+ *  define macros for all of the registers on this CPU
+ *  EXAMPLE:     #define d0 REG (d0)
+#define fp	REG(fp)
+#define sp	REG(sp)
+#define	r0	REG(r0)
+#define r1	REG(r1)
+#define r2	REG(r2)
+#define r3	REG(r3)
+#define r4	REG(r4)
+#define r5	REG(r5)
+#define r6	REG(r6)
+#define r7	REG(r7)
+#define r8	REG(r8)
+#define r9	REG(r9)
+#define r10	REG(r10)
+#define r11	REG(r11)
+#define r12	REG(r12)
+#define r13	REG(r13)
+ *  Define macros to handle section beginning and ends.
+#define BEGIN_CODE_DCL .text
+#define END_CODE_DCL
+#define BEGIN_DATA_DCL .data
+#define END_DATA_DCL
+#define BEGIN_CODE asm ( ".text
+#define END_CODE ");
+#define BEGIN_DATA
+#define END_DATA
+#define BEGIN_BSS
+#define END_BSS
+#define END
+ *  Following must be tailor for a particular flavor of the C compiler.
+ *  They may need to put underscores in front of the symbols.
+#define PUBLIC(sym) .globl SYM (sym)
+#define EXTERN(sym) .globl SYM (sym)
+#endif
diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
index 0000000..5065ad4
--- /dev/null
+++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
@@ -0,0 +1,1059 @@
+ * @file rtems/score/cpu.h
+ *  This include file contains information pertaining to the Moxie
+ *  processor.
+ *  Copyright (c) 2013  Anthony Green
+ *  Based on code with the following copyright..
+ *  COPYRIGHT (c) 1989-2006, 2010.
+ *  $Id$
+#ifndef _RTEMS_SCORE_CPU_H
+#define _RTEMS_SCORE_CPU_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+#include <rtems/score/types.h>
+#include <rtems/score/moxie.h>  /* pick up machine definitions */
+#include <rtems/bspIo.h>	/* printk */
+/* conditional compilation parameters */
+ *  Should the calls to _Thread_Enable_dispatch be inlined?
+ *  If TRUE, then they are inlined.
+ *  If FALSE, then a subroutine call is made.
+ *  Basically this is an example of the classic trade-off of size
+ *  versus speed.  Inlining the call (TRUE) typically increases the
+ *  size of RTEMS while speeding up the enabling of dispatching.
+ *  [NOTE: In general, the _Thread_Dispatch_disable_level will
+ *  only be 0 or 1 unless you are in an interrupt handler and that
+ *  interrupt handler invokes the executive.]  When not inlined
+ *  something calls _Thread_Enable_dispatch which in turns calls
+ *  _Thread_Dispatch.  If the enable dispatch is inlined, then
+ *  one subroutine call is avoided entirely.]
+ *  MOXIE Specific Information:
+ *  XXX
+#define CPU_INLINE_ENABLE_DISPATCH       FALSE
+ *  Should the body of the search loops in _Thread_queue_Enqueue_priority
+ *  be unrolled one time?  In unrolled each iteration of the loop examines
+ *  two "nodes" on the chain being searched.  Otherwise, only one node
+ *  is examined per iteration.
+ *  If TRUE, then the loops are unrolled.
+ *  If FALSE, then the loops are not unrolled.
+ *  The primary factor in making this decision is the cost of disabling
+ *  and enabling interrupts (_ISR_Flash) versus the cost of rest of the
+ *  body of the loop.  On some CPUs, the flash is more expensive than
+ *  one iteration of the loop body.  In this case, it might be desirable
+ *  to unroll the loop.  It is important to note that on some CPUs, this
+ *  code is the longest interrupt disable period in RTEMS.  So it is
+ *  necessary to strike a balance when setting this parameter.
+ *  XXX
+#define CPU_UNROLL_ENQUEUE_PRIORITY      FALSE
+ *  Should this target use 16 or 32 bit object Ids?
+#define RTEMS_USE_32_BIT_OBJECT
+ *  Does RTEMS manage a dedicated interrupt stack in software?
+ *  If TRUE, then a stack is allocated in _ISR_Handler_initialization.
+ *  If FALSE, nothing is done.
+ *  If the CPU supports a dedicated interrupt stack in hardware,
+ *  then it is generally the responsibility of the BSP to allocate it
+ *  and set it up.
+ *  If the CPU does not support a dedicated interrupt stack, then
+ *  the porter has two options: (1) execute interrupts on the
+ *  stack of the interrupted task, and (2) have RTEMS manage a dedicated
+ *  interrupt stack.
+ *  If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
+ *  Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
+ *  CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE.  It is
+ *  possible that both are FALSE for a particular CPU.  Although it
+ *  is unclear what that would imply about the interrupt processing
+ *  procedure on that CPU.
+ *  XXX
+#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
+ *  Does the CPU follow the simple vectored interrupt model?
+ *  If TRUE, then RTEMS allocates the vector table it internally manages.
+ *  If FALSE, then the BSP is assumed to allocate and manage the vector
+ *  table
+ *  XXX document implementation including references if appropriate
+#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
+ *  Does this CPU have hardware support for a dedicated interrupt stack?
+ *  If TRUE, then it must be installed during initialization.
+ *  If FALSE, then no installation is performed.
+ *  XXX
+#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
+ *  Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
+ *  If TRUE, then the memory is allocated during initialization.
+ *  If FALSE, then the memory is allocated during initialization.
+ *  This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
+ *  XXX
+#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
+ *  Does the CPU have hardware floating point?
+ *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
+ *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
+ *  If there is a FP coprocessor such as the i387 or mc68881, then
+ *  the answer is TRUE.
+ *  The macro name "MOXIE_HAS_FPU" should be made CPU specific.
+ *  It indicates whether or not this CPU model has FP support.  For
+ *  example, it would be possible to have an i386_nofp CPU model
+ *  which set this to false to indicate that you have an i386 without
+ *  an i387 and wish to leave floating point support out of RTEMS.
+ *  XXX
+#define CPU_HARDWARE_FP     FALSE
+ *  Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
+ *  If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
+ *  If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
+ *  If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
+ *  XXX
+#define CPU_ALL_TASKS_ARE_FP     FALSE
+ *  Should the IDLE task have a floating point context?
+ *  If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
+ *  and it has a floating point context which is switched in and out.
+ *  If FALSE, then the IDLE task does not have a floating point context.
+ *  Setting this to TRUE negatively impacts the time required to preempt
+ *  the IDLE task from an interrupt because the floating point context
+ *  must be saved as part of the preemption.
+ *  XXX
+#define CPU_IDLE_TASK_IS_FP      FALSE
+ *  Should the saving of the floating point registers be deferred
+ *  until a context switch is made to another different floating point
+ *  task?
+ *  If TRUE, then the floating point context will not be stored until
+ *  necessary.  It will remain in the floating point registers and not
+ *  disturned until another floating point task is switched to.
+ *  If FALSE, then the floating point context is saved when a floating
+ *  point task is switched out and restored when the next floating point
+ *  task is restored.  The state of the floating point registers between
+ *  those two operations is not specified.
+ *  If the floating point context does NOT have to be saved as part of
+ *  interrupt dispatching, then it should be safe to set this to TRUE.
+ *  Setting this flag to TRUE results in using a different algorithm
+ *  for deciding when to save and restore the floating point context.
+ *  The deferred FP switch algorithm minimizes the number of times
+ *  the FP context is saved and restored.  The FP context is not saved
+ *  until a context switch is made to another, different FP task.
+ *  Thus in a system with only one FP task, the FP context will never
+ *  be saved or restored.
+ *  XXX
+#define CPU_USE_DEFERRED_FP_SWITCH       TRUE
+ *  Does this port provide a CPU dependent IDLE task implementation?
+ *  If TRUE, then the routine _CPU_Internal_threads_Idle_thread_body
+ *  must be provided and is the default IDLE thread body instead of
+ *  _Internal_threads_Idle_thread_body.
+ *  If FALSE, then use the generic IDLE thread body if the BSP does
+ *  not provide one.
+ *  This is intended to allow for supporting processors which have
+ *  a low power or idle mode.  When the IDLE thread is executed, then
+ *  the CPU can be powered down.
+ *  The order of precedence for selecting the IDLE thread body is:
+ *    1.  BSP provided
+ *    2.  CPU dependent (if provided)
+ *    3.  generic (if no BSP and no CPU dependent)
+ *  XXX
+ *  The port initially called a BSP dependent routine called
+ *  IDLE_Monitor.  The idle task body can be overridden by
+ *  the BSP in newer versions of RTEMS.
+#define CPU_PROVIDES_IDLE_THREAD_BODY    FALSE
+ *  Does the stack grow up (toward higher addresses) or down
+ *  (toward lower addresses)?
+ *  If TRUE, then the grows upward.
+ *  If FALSE, then the grows toward smaller addresses.
+ *  XXX
+#define CPU_STACK_GROWS_UP               FALSE
+ *  The following is the variable attribute used to force alignment
+ *  of critical RTEMS structures.  On some processors it may make
+ *  sense to have these aligned on tighter boundaries than
+ *  the minimum requirements of the compiler in order to have as
+ *  much of the critical data area as possible in a cache line.
+ *  The placement of this macro in the declaration of the variables
+ *  is based on the syntactically requirements of the GNU C
+ *  "__attribute__" extension.  For example with GNU C, use
+ *  the following to force a structures to a 32 byte boundary.
+ *      __attribute__ ((aligned (32)))
+ *  NOTE:  Currently only the Priority Bit Map table uses this feature.
+ *         To benefit from using this, the data must be heavily
+ *         used so it will stay in the cache and used frequently enough
+ *         in the executive to justify turning this on.
+ *  XXX
+#define CPU_STRUCTURE_ALIGNMENT
+ *  Define what is required to specify how the network to host conversion
+ *  routines are handled.
+#define CPU_BIG_ENDIAN                           TRUE
+#define CPU_LITTLE_ENDIAN                        FALSE
+ *  The following defines the number of bits actually used in the
+ *  interrupt field of the task mode.  How those bits map to the
+ *  CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
+ *  XXX
+#define CPU_MODES_INTERRUPT_MASK   0x00000001
+ *  Processor defined structures required for cpukit/score.
+ *  XXX
+/* may need to put some structures here.  */
+ * Contexts
+ *  Generally there are 2 types of context to save.
+ *     1. Interrupt registers to save
+ *     2. Task level registers to save
+ *  This means we have the following 3 context items:
+ *     1. task level context stuff::  Context_Control
+ *     2. floating point task stuff:: Context_Control_fp
+ *     3. special interrupt level context :: Context_Control_interrupt
+ *  On some processors, it is cost-effective to save only the callee
+ *  preserved registers during a task context switch.  This means
+ *  that the ISR code needs to save those registers which do not
+ *  persist across function calls.  It is not mandatory to make this
+ *  distinctions between the caller/callee saves registers for the
+ *  purpose of minimizing context saved during task switch and on interrupts.
+ *  If the cost of saving extra registers is minimal, simplicity is the
+ *  choice.  Save the same context on interrupt entry as for tasks in
+ *  this case.
+ *  Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
+ *  care should be used in designing the context area.
+ *  On some CPUs with hardware floating point support, the Context_Control_fp
+ *  structure will not be used or it simply consist of an array of a
+ *  fixed number of bytes.   This is done when the floating point context
+ *  is dumped by a "FP save context" type instruction and the format
+ *  is not really defined by the CPU.  In this case, there is no need
+ *  to figure out the exact format -- only the size.  Of course, although
+ *  this is enough information for RTEMS, it is probably not enough for
+ *  a debugger such as gdb.  But that is another problem.
+ *  XXX
+#define nogap __attribute__ ((packed))
+typedef struct {
+    void	*fp nogap;
+    void 	*sp nogap;
+    uint32_t    r0 nogap;
+    uint32_t  	r1 nogap;
+    uint32_t  	r2 nogap;
+    uint32_t  	r3 nogap;
+    uint32_t  	r4 nogap;
+    uint32_t  	r5 nogap;
+    uint32_t  	r6 nogap;
+    uint32_t  	r7 nogap;
+    uint32_t  	r8 nogap;
+    uint32_t  	r9 nogap;
+    uint32_t  	r10 nogap;
+    uint32_t  	r11 nogap;
+    uint32_t  	r12 nogap;
+    uint32_t  	r13 nogap;
+} Context_Control;
+#define _CPU_Context_Get_SP( _context ) \
+  (_context)->sp
+typedef struct {
+    double      some_float_register[2];
+} Context_Control_fp;
+typedef struct {
+    uint32_t   special_interrupt_register;
+} CPU_Interrupt_frame;
+ *  This variable is optional.  It is used on CPUs on which it is difficult
+ *  to generate an "uninitialized" FP context.  It is filled in by
+ *  _CPU_Initialize and copied into the task's FP context area during
+ *  _CPU_Context_Initialize.
+ *  XXX
+SCORE_EXTERN Context_Control_fp  _CPU_Null_fp_context;
+ *  Nothing prevents the porter from declaring more CPU specific variables.
+ *  XXX
+/* XXX: if needed, put more variables here */
+ *  The size of the floating point context area.  On some CPUs this
+ *  will not be a "sizeof" because the format of the floating point
+ *  area is not defined -- only the size is.  This is usually on
+ *  CPUs with a "floating point save context" instruction.
+ *  XXX
+#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
+ *  Amount of extra stack (above minimum stack size) required by
+ *  system initialization thread.  Remember that in a multiprocessor
+ *  system the system intialization thread becomes the MP server thread.
+ *  It is highly unlikely the MOXIE will get used in a multiprocessor system.
+#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
+ *  This defines the number of entries in the ISR_Vector_table managed
+ *  by RTEMS.
+ *  XXX
+#define CPU_INTERRUPT_NUMBER_OF_VECTORS      64
+#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER  (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
+ *  This is defined if the port has a special way to report the ISR nesting
+ *  level.  Most ports maintain the variable _ISR_Nest_level.
+#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
+ *  Should be large enough to run all RTEMS tests.  This ensures
+ *  that a "reasonable" small application should not have any problems.
+ *  XXX
+#define CPU_STACK_MINIMUM_SIZE          (1536)
+ *  CPU's worst alignment requirement for data types on a byte boundary.  This
+ *  alignment does not take into account the requirements for the stack.
+ *  XXX
+#define CPU_ALIGNMENT              8
+ *  This number corresponds to the byte alignment requirement for the
+ *  heap handler.  This alignment requirement may be stricter than that
+ *  for the data types alignment specified by CPU_ALIGNMENT.  It is
+ *  common for the heap to follow the same alignment requirement as
+ *  CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict enough for the heap,
+ *  then this should be set to CPU_ALIGNMENT.
+ *  NOTE:  This does not have to be a power of 2.  It does have to
+ *         be greater or equal to than CPU_ALIGNMENT.
+ *  XXX
+#define CPU_HEAP_ALIGNMENT         CPU_ALIGNMENT
+ *  This number corresponds to the byte alignment requirement for memory
+ *  buffers allocated by the partition manager.  This alignment requirement
+ *  may be stricter than that for the data types alignment specified by
+ *  CPU_ALIGNMENT.  It is common for the partition to follow the same
+ *  alignment requirement as CPU_ALIGNMENT.  If the CPU_ALIGNMENT is strict
+ *  enough for the partition, then this should be set to CPU_ALIGNMENT.
+ *  XXX
+#define CPU_PARTITION_ALIGNMENT    CPU_ALIGNMENT
+ *  stack.  This alignment requirement may be stricter than that for the
+ *  data types alignment specified by CPU_ALIGNMENT.  If the CPU_ALIGNMENT
+ *  is strict enough for the stack, then this should be set to 0.
+ *  NOTE:  This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
+ *  XXX
+#define CPU_STACK_ALIGNMENT        0
+ *  ISR handler macros
+ *  Support routine to initialize the RTEMS vector table after it is allocated.
+#define _CPU_Initialize_vectors()
+ *  Disable all interrupts for an RTEMS critical section.  The previous
+ *  level is returned in _level.
+ *  XXX
+#define _CPU_ISR_Disable( _isr_cookie ) (_isr_cookie) = 0
+ *  Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
+ *  This indicates the end of an RTEMS critical section.  The parameter
+ *  _level is not modified.
+ *  XXX
+#define _CPU_ISR_Enable( _isr_cookie )
+ *  This temporarily restores the interrupt to _level before immediately
+ *  disabling them again.  This is used to divide long RTEMS critical
+ *  sections into two or more parts.  The parameter _level is not
+ *  modified.
+ *  XXX
+#define _CPU_ISR_Flash( _isr_cookie )
+ *  Map interrupt level in task mode onto the hardware that the CPU
+ *  actually provides.  Currently, interrupt levels which do not
+ *  map onto the CPU in a generic fashion are undefined.  Someday,
+ *  it would be nice if these were "mapped" by the application
+ *  via a callout.  For example, m68k has 8 levels 0 - 7, levels
+ *  8 - 255 would be available for bsp/application specific meaning.
+ *  This could be used to manage a programmable interrupt controller
+ *  via the rtems_task_mode directive.
+ *  XXX
+#define _CPU_ISR_Set_level( _new_level )	\
+    if (_new_level)   asm volatile ( "nop\n" );		\
+    else              asm volatile ( "nop\n" );		\
+uint32_t   _CPU_ISR_Get_level( void );
+/* end of ISR handler macros */
+/* Context handler macros */
+ *  Initialize the context to a state suitable for starting a
+ *  task after a context restore operation.  Generally, this
+ *  involves:
+ *     - setting a starting address
+ *     - preparing the stack
+ *     - preparing the stack and frame pointers
+ *     - setting the proper interrupt level in the context
+ *     - initializing the floating point context
+ *  This routine generally does not set any unnecessary register
+ *  in the context.  The state of the "general data" registers is
+ *  undefined at task start time.
+ *  NOTE: This is_fp parameter is TRUE if the thread is to be a floating
+ *        point thread.  This is typically only used on CPUs where the
+ *        FPU may be easily disabled by software such as on the SPARC
+ *        where the PSR contains an enable FPU bit.
+ *  XXX
+#define CPU_CCR_INTERRUPTS_ON  0x80
+#define CPU_CCR_INTERRUPTS_OFF 0x00
+#define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
+				 _isr, _entry_point, _is_fp )	   \
+  /* Locate Me */						   \
+  do {								   \
+    uintptr_t   _stack;						   \
+    _stack = ((uintptr_t)(_stack_base)) + (_size) - 8;		   \
+    *((proc_ptr *)(_stack)) = (_entry_point);			   \
+    _stack -= 4;						   \
+    (_the_context)->fp = (void *)_stack;			   \
+    (_the_context)->sp = (void *)_stack;			   \
+  } while (0)
+ *  This routine is responsible for somehow restarting the currently
+ *  executing task.  If you are lucky, then all that is necessary
+ *  is restoring the context.  Otherwise, there will need to be
+ *  a special assembly routine which does something special in this
+ *  case.  Context_Restore should work most of the time.  It will
+ *  not work if restarting self conflicts with the stack frame
+ *  assumptions of restoring a context.
+ *  XXX
+#define _CPU_Context_Restart_self( _the_context ) \
+   _CPU_Context_restore( (_the_context) );
+ *  The purpose of this macro is to allow the initial pointer into
+ *  a floating point context area (used to save the floating point
+ *  context) to be at an arbitrary place in the floating point
+ *  context area.
+ *  This is necessary because some FP units are designed to have
+ *  their context saved as a stack which grows into lower addresses.
+ *  Other FP units can be saved by simply moving registers into offsets
+ *  from the base of the context area.  Finally some FP units provide
+ *  a "dump context" instruction which could fill in from high to low
+ *  or low to high based on the whim of the CPU designers.
+ *  XXX
+#define _CPU_Context_Fp_start( _base, _offset ) \
+   ( (void *) (_base) + (_offset) )
+ *  This routine initializes the FP context area passed to it to.
+ *  There are a few standard ways in which to initialize the
+ *  floating point context.  The code included for this macro assumes
+ *  that this is a CPU in which a "initial" FP context was saved into
+ *  _CPU_Null_fp_context and it simply copies it to the destination
+ *  context passed to it.
+ *  Other models include (1) not doing anything, and (2) putting
+ *  a "null FP status word" in the correct place in the FP context.
+ *  XXX
+#define _CPU_Context_Initialize_fp( _destination ) \
+   *(*(_destination)) = _CPU_Null_fp_context; \
+/* end of Context handler macros */
+/* Fatal Error manager macros */
+ *  This routine copies _error into a known place -- typically a stack
+ *  location or a register, optionally disables interrupts, and
+ *  halts/stops the CPU.
+ *  XXX
+#define _CPU_Fatal_halt( _error ) \
+ 	printk("Fatal Error %d Halted\n",_error); \
+	for(;;)
+/* end of Fatal Error manager macros */
+/* Bitfield handler macros */
+ *  This routine sets _output to the bit number of the first bit
+ *  set in _value.  _value is of CPU dependent type Priority_Bit_map_control.
+ *  This type may be either 16 or 32 bits wide although only the 16
+ *  least significant bits will be used.
+ *  There are a number of variables in using a "find first bit" type
+ *  instruction.
+ *    (1) What happens when run on a value of zero?
+ *    (2) Bits may be numbered from MSB to LSB or vice-versa.
+ *    (3) The numbering may be zero or one based.
+ *    (4) The "find first bit" instruction may search from MSB or LSB.
+ *  RTEMS guarantees that (1) will never happen so it is not a concern.
+ *  (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
+ *  _CPU_Priority_bits_index().  These three form a set of routines
+ *  which must logically operate together.  Bits in the _value are
+ *  set and cleared based on masks built by _CPU_Priority_mask().
+ *  The basic major and minor values calculated by _Priority_Major()
+ *  and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
+ *  to properly range between the values returned by the "find first bit"
+ *  instruction.  This makes it possible for _Priority_Get_highest() to
+ *  calculate the major and directly index into the minor table.
+ *  This mapping is necessary to ensure that 0 (a high priority major/minor)
+ *  is the first bit found.
+ *  This entire "find first bit" and mapping process depends heavily
+ *  on the manner in which a priority is broken into a major and minor
+ *  components with the major being the 4 MSB of a priority and minor
+ *  the 4 LSB.  Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
+ *  priority.  And (15 << 4) + 14 corresponds to priority 254 -- the next
+ *  to the lowest priority.
+ *  If your CPU does not have a "find first bit" instruction, then
+ *  there are ways to make do without it.  Here are a handful of ways
+ *  to implement this in software:
+ *    - a series of 16 bit test instructions
+ *    - a "binary search using if's"
+ *    - _number = 0
+ *      if _value > 0x00ff
+ *        _value >>=8
+ *        _number = 8;
+ *      if _value > 0x0000f
+ *        _value >=8
+ *        _number += 4
+ *      _number += bit_set_table[ _value ]
+ *    where bit_set_table[ 16 ] has values which indicate the first
+ *      bit set
+ *  XXX
+#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
+#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
+#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
+#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
+    (_output) = 0;   /* do something to prevent warnings */ \
+#endif
+/* end of Bitfield handler macros */
+ *  This routine builds the mask which corresponds to the bit fields
+ *  as searched by _CPU_Bitfield_Find_first_bit().  See the discussion
+ *  for that routine.
+ *  XXX
+#define _CPU_Priority_Mask( _bit_number ) \
+  ( 1 << (_bit_number) )
+#endif
+ *  This routine translates the bit numbers returned by
+ *  _CPU_Bitfield_Find_first_bit() into something suitable for use as
+ *  a major or minor component of a priority.  See the discussion
+ *  XXX
+#define _CPU_Priority_bits_index( _priority ) \
+  (_priority)
+#endif
+/* end of Priority handler macros */
+/* functions */
+ *  _CPU_Initialize
+ *  This routine performs CPU dependent initialization.
+ *  XXX
+void _CPU_Initialize(void);
+ *  This routine installs a "raw" interrupt handler directly into the
+ *  processor's vector table.
+ *  XXX
+  uint32_t    vector,
+ *  This routine installs an interrupt vector.
+ *  XXX
+  uint32_t    vector,
+ *  This routine installs the hardware interrupt stack pointer.
+ *  NOTE:  It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
+ *         is TRUE.
+ *  XXX
+void _CPU_Install_interrupt_stack( void );
+ *  _CPU_Internal_threads_Idle_thread_body
+ *  This routine is the CPU dependent IDLE thread body.
+ *  NOTE:  It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
+ *         is TRUE.
+ *  XXX
+void *_CPU_Thread_Idle_body( uint32_t );
+ *  _CPU_Context_switch
+ *  This routine switches from the run context to the heir context.
+ *  XXX
+void _CPU_Context_switch(
+  Context_Control  *run,
+  Context_Control  *heir
+ *  _CPU_Context_restore
+ *  This routine is generallu used only to restart self in an
+ *  efficient manner.  It may simply be a label in _CPU_Context_switch.
+ *  NOTE: May be unnecessary to reload some registers.
+ *  XXX
+void _CPU_Context_restore(
+  Context_Control *new_context
+ *  _CPU_Context_save_fp
+ *  This routine saves the floating point context passed to it.
+ *  XXX
+void _CPU_Context_save_fp(
+  Context_Control_fp **fp_context_ptr
+ *  _CPU_Context_restore_fp
+ *  This routine restores the floating point context passed to it.
+ *  XXX
+void _CPU_Context_restore_fp(
+/*  The following routine swaps the endian format of an unsigned int.
+ *  It must be static because it is referenced indirectly.
+ *  This version will work on any processor, but if there is a better
+ *  way for your CPU PLEASE use it.  The most common way to do this is to:
+ *     swap least significant two bytes with 16-bit rotate
+ *     swap upper and lower 16-bits
+ *     swap most significant two bytes with 16-bit rotate
+ *  Some CPUs have special instructions which swap a 32-bit quantity in
+ *  a single instruction (e.g. i486).  It is probably best to avoid
+ *  an "endian swapping control bit" in the CPU.  One good reason is
+ *  that interrupts would probably have to be disabled to ensure that
+ *  an interrupt does not try to access the same "chunk" with the wrong
+ *  endian.  Another good reason is that on some CPUs, the endian bit
+ *  endianness for ALL fetches -- both code and data -- so the code
+ *  will be fetched incorrectly.
+ *  This is the generic implementation.
+static inline uint32_t   CPU_swap_u32(
+  uint32_t   value
+  uint32_t   byte1, byte2, byte3, byte4, swapped;
+  byte4 = (value >> 24) & 0xff;
+  byte3 = (value >> 16) & 0xff;
+  byte2 = (value >> 8)  & 0xff;
+  byte1 =  value        & 0xff;
+  swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
+  return( swapped );
+#define CPU_swap_u16( value ) \
+  (((value&0xff) << 8) | ((value >> 8)&0xff))
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/cpu/moxie/rtems/score/moxie.h b/cpukit/score/cpu/moxie/rtems/score/moxie.h
index 0000000..5cce9e3
--- /dev/null
+++ b/cpukit/score/cpu/moxie/rtems/score/moxie.h
@@ -0,0 +1,45 @@
+ * @file rtems/score/moxie.h
+ *  This file contains information pertaining to the Moxie processor.
+ *  COPYRIGHT (c) 2011, 2013
+ *  Anthony Green
+ *  Based on code with the following copyright...
+ *  $Id$
+#ifndef _RTEMS_SCORE_MOXIE_H
+#define _RTEMS_SCORE_MOXIE_H
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  This file contains the information required to build
+ *  RTEMS for a particular member of the "moxie"
+ *  family when executing in protected mode.  It does
+ *  this by setting variables to indicate which implementation
+ *  dependent features are present in a particular member
+ *  of the family.
+#define CPU_NAME  "Moxie"
+#define CPU_MODEL_NAME  "MoxieLite"
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/cpukit/score/cpu/moxie/rtems/score/types.h b/cpukit/score/cpu/moxie/rtems/score/types.h
index 0000000..b26ba9f
--- /dev/null
+++ b/cpukit/score/cpu/moxie/rtems/score/types.h
@@ -0,0 +1,55 @@
+ * @file rtems/score/types.h
+ *  Anthony Green
+ *  $Id$
+#ifndef _RTEMS_SCORE_TYPES_H
+#define _RTEMS_SCORE_TYPES_H
+#include <rtems/score/basedefs.h>
+#ifndef ASM
+#include <stdbool.h>
+#include <stdint.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ *  This section defines the basic types for this processor.
+typedef uint16_t     Priority_bit_map_Control;
+typedef void moxie_isr;
+typedef void ( *moxie_isr_entry )( void );
+#ifdef RTEMS_DEPRECATED_TYPES
+typedef bool	boolean;     		/* Boolean value   */
+typedef float	single_precision;	/* single precision float */
+typedef double	double_precision;	/* double precision float */
+#endif
+#ifdef __cplusplus
+#endif
+#endif  /* !ASM */
+#endif
1.8.1.4
