[GSOC 2013] - RTEMS Run-Time Oriented projects and Raspberry Pi BSP
Sagara Paranagama
sagara89dev at gmail.com
Wed Feb 27 03:32:51 UTC 2013
> I updated my mentor information. I am in the process of submitting a basic
> Raspberry Pi BSP. Once that is in, there are plenty of improvements and
> additions to be made to it. You can see the patch I submitted on this
> mailing list for my initial BSP. You should be able to build RTEMS 4.11 and
> run some basic tests on the Pi.
Hi Alan,
Thanks for your reply. I found your patch and I'm going through it now. Can
I contact you directly through email (while Cc -ing to the mailing list)
if I come across any problems? (or maybe vice versa)
Thanks
Sagara Paranagama
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130227/f838ad95/attachment-0001.html>
