[PATCH 1/2] posix: Reimplement POSIX Key manager to use a red-black tree.
Ashi ashi08104 at gmail.com
Wed Feb 27 16:30:21 UTC 2013
I have some issue when patch psxkey01.scn, keycreate.c to the latest source
tree, but can't find which part lead to patch rejection. Finally, I just
manualy modify those 2 files(psxkey01.scn and keycreate.c) accordding to
the patch.
And I get some errors due to TAB and space when building (e.g. line20 and
line21 in Makefile.am of psxkey04)
gmake[6]: Entering directory
`/home/ashi/projects/b-sis/sparc-rtems4.11/c/sis/testsuites/psxtests/psxkey04'
Makefile:619: *** missing separator (did you mean TAB instead of 8
spaces?).  Stop.
Shall I change those Spaces back to TAB?
And the patch is updated accordding to Joel's comments.
On Mon, Feb 25, 2013 at 10:31 PM, Gedare Bloom <gedare at rtems.org> wrote:
> On Sun, Feb 24, 2013 at 8:46 PM, Ashi <ashi08104 at gmail.com> wrote:
> > Yeah, of course!
> > On Feb 23, 2013, at 10:52 PM, Joel Sherrill <joel.sherrill at oarcorp.com>
> > wrote:
> >> Some quick comments. Reviewing on my Nexus 7 and I would love a client
> >> that let's you respond inline.
> >> Object field in the data structure should be named with capitalisation.
> > OK
> >> Look for "DESCRIPTION". convert this and similar blocks to Doxygen.
> > Sorry, I don't quite understand it, does it mean add a @brief … line
> above
> > "DESCRIPTION"?
> Convert the comments into doxygen comments. See
> http://wiki.rtems.org/wiki/index.php/Doxygen_Recommendations
> >> Why was the manager initialization method renamed keys manager
> >> initialization? Others are singular.
> > I see, I'll change it back to singular.
> >> New files should follow style with @file comment block.
> > Does this apply to file in test cases? I find other files under
> > testsuites/psxtests/ has no such block.
> I don't think so. Right now we don't use doxygen in the test cases.
> >> No need for comment about disable dispatching above call to Get to
> convert
> >> from Id to pointer.
> > OK
> Please also be sure to use the updated patches I sent that include the
> whitespace fixes. (No extra white space at the end of lines, no extra
> blank lines at the end of files.)
> > thanks,
> > Zhongwei Yao
> > On Mon, Feb 25, 2013 at 12:28 AM, Joel Sherrill <
> > wrote:
> >> I appear to have deleted the message I meant to reply to. :(
> >> It may have been to me directly since I can't find it in the archive.
> >> Can it be resent?  Thanks.
> >> --joel
> >>> Object field in the data structure should be named with capitalization.
> >>> convert from Id to pointer.
> >>> From: Zhongwei Yao <ashi08104 at gmail.com>
> >>> The POSIX Key manager is reimplemented with a red-black tree to store
> >>> the keys and values. This code was contributed as part of GSOC 2012.
> >>>   cpukit/posix/include/rtems/posix/key.h       |   54
> >>>   cpukit/posix/include/rtems/posix/threadsup.h |   10 ++++
> >>>   cpukit/posix/inline/rtems/posix/key.inl      |    2 +-
> >>>   cpukit/posix/src/key.c                       |   59
> >>>   cpukit/posix/src/keycreate.c                 |   52
> >>>   cpukit/posix/src/keydelete.c                 |    3 +-
> >>>   cpukit/posix/src/keyfreememory.c             |   35 ++++++++++++-
> >>>   cpukit/posix/src/keygetspecific.c            |   20 +++++---
> >>>   cpukit/posix/src/keyrundestructors.c         |   67
> >>>   cpukit/posix/src/keysetspecific.c            |   34 ++++++++++---
> >>>   cpukit/posix/src/pthread.c                   |    3 +
> >>>   cpukit/sapi/src/posixapi.c                   |    2 +-
> >>>   12 files changed, 229 insertions(+), 112 deletions(-)
> >>> diff --git a/cpukit/posix/include/rtems/posix/key.h
> >>> b/cpukit/posix/include/rtems/posix/key.h
> >>> index 0bb1dbe..f045dad 100644
> >>> --- a/cpukit/posix/include/rtems/posix/key.h
> >>> +++ b/cpukit/posix/include/rtems/posix/key.h
> >>> @@ -8,6 +8,7 @@
> >>> + *  Copyright (c) 2012 Zhongwei Yao.
> >>>    *  COPYRIGHT (c) 1989-2011.
> >>>    *  On-Line Applications Research Corporation (OAR).
> >>> @@ -20,6 +21,8 @@
> >>>   #define _RTEMS_POSIX_KEY_H
> >>>   #include <rtems/score/object.h>
> >>> +#include <rtems/score/rbtree.h>
> >>> +#include <rtems/score/chain.h>
> >>>    * @defgroup POSIX_KEY POSIX Key
> >>> @@ -34,32 +37,57 @@ extern "C" {
> >>>   #endif
> >>> - * This is the data Structure used to manage a POSIX key.
> >>> - * NOTE: The Values is a table indexed by the index portion of the
> >>> - *       ID of the currently executing thread.
> >>> + * @brief The rbtree node used to manage a POSIX key and value.
> >>> +typedef struct {
> >>> +  /** This field is the chain node structure. */
> >>> +  Chain_Node ch_node;
> >>> +  /** This field is the rbtree node structure. */
> >>> +  RBTree_Node rb_node;
> >>> +  /** This field is the POSIX key used as an rbtree key */
> >>> +  pthread_key_t key;
> >>> +  /** This field is the Thread id also used as an rbtree key */
> >>> +  Objects_Id thread_id;
> >>> +  /** This field points to the POSIX key value of specific thread */
> >>> +  void *value;
> >>> + }  POSIX_Keys_Rbtree_node;
> >>> + * @brief The data structure used to manage a POSIX key.
> >>>   typedef struct {
> >>>      /** This field is the Object control structure. */
> >>> -   Objects_Control     Object;
> >>> -   /** This field points to the optional destructor method. */
> >>> -   void              (*destructor)( void * );
> >>> -   /** This field points to the values per thread. */
> >>> -   void              **Values[ OBJECTS_APIS_LAST + 1 ];
> >>> -}  POSIX_Keys_Control;
> >>> +   Objects_Control     object;
> >>> +   /** This field is the data destructor. */
> >>> +   void (*destructor) (void *);
> >>> + }  POSIX_Keys_Control;
> >>> - * The following defines the information control block used to manage
> >>> - * this class of objects.
> >>> + * @brief The information control block used to manage this class of
> >>> objects.
> >>>   POSIX_EXTERN Objects_Information  _POSIX_Keys_Information;
> >>> + * @brief The rbtree control block used to manage all key values
> >>> +POSIX_EXTERN RBTree_Control _POSIX_Keys_Rbtree;
> >>>    * @brief POSIX keys manager initialization.
> >>>    * This routine performs the initialization necessary for this
> manager.
> >>> -void _POSIX_Key_Manager_initialization(void);
> >>> +void _POSIX_Keys_Manager_initialization(void);
> >>> + * @brief POSIX keys Red-Black tree node comparison.
> >>> + * This routine compares the rbtree node
> >>> +int _POSIX_Keys_Rbtree_compare_function(
> >>> +  const RBTree_Node *node1,
> >>> +  const RBTree_Node *node2
> >>>    * @brief Create thread-specific data POSIX key.
> >>> diff --git a/cpukit/posix/include/rtems/posix/threadsup.h
> >>> b/cpukit/posix/include/rtems/posix/threadsup.h
> >>> index 80f64dc..d746ea8 100644
> >>> --- a/cpukit/posix/include/rtems/posix/threadsup.h
> >>> +++ b/cpukit/posix/include/rtems/posix/threadsup.h
> >>> @@ -21,6 +21,7 @@
> >>>   #include <sys/signal.h>
> >>>   #include <rtems/score/coresem.h>
> >>>   #include <rtems/score/tqdata.h>
> >>>    *  @defgroup POSIX_THREAD POSIX Thread API Extension
> >>> @@ -79,6 +80,15 @@ typedef struct {
> >>>     /** This is the set of cancelation handlers. */
> >>>     Chain_Control           Cancellation_Handlers;
> >>> +   * This is the thread key value chain's control, which is used
> >>> +   * to track all key value for specific thread, and when thread
> >>> +   * exits, we can remove all key value for specific thread by
> >>> +   * iterating this chain, or we have to search a whole rbtree,
> >>> +   * which is inefficient.
> >>> +  Chain_Control           Key_Chain;
> >>>   } POSIX_API_Control;
> >>> diff --git a/cpukit/posix/inline/rtems/posix/key.inl
> >>> b/cpukit/posix/inline/rtems/posix/key.inl
> >>> index ce5601b..9469580 100644
> >>> --- a/cpukit/posix/inline/rtems/posix/key.inl
> >>> +++ b/cpukit/posix/inline/rtems/posix/key.inl
> >>> @@ -45,7 +45,7 @@ RTEMS_INLINE_ROUTINE void _POSIX_Keys_Free (
> >>>     POSIX_Keys_Control *the_key
> >>> -  _Objects_Free( &_POSIX_Keys_Information, &the_key->Object );
> >>> +  _Objects_Free( &_POSIX_Keys_Information, &the_key->object );
> >>> diff --git a/cpukit/posix/src/key.c b/cpukit/posix/src/key.c
> >>> index 6eace26..82c11af 100644
> >>> --- a/cpukit/posix/src/key.c
> >>> +++ b/cpukit/posix/src/key.c
> >>> @@ -29,6 +29,57 @@
> >>>   #include <rtems/score/thread.h>
> >>>   #include <rtems/score/wkspace.h>
> >>>   #include <rtems/posix/key.h>
> >>> + * _POSIX_Keys_Rbtree_compare_function
> >>> + * DESCRIPTION:
> >>> + * by comparing POSIX key first and comparing thread id second.
> >>> + * And if either of the input nodes's thread_id member is 0, then
> >>> + * it will only compare the pthread_key_t member. That is when we
> >>> + * pass thread_id = 0 node as a search node, the search is done only
> >>> + * by pthread_key_t.
> >>> + * Input parameters: two rbtree node
> >>> + * Output parameters: return positive if first node
> >>> + * has higher key than second, negative if lower, 0 if equal,
> >>> + * and for all the thread id is unique, then return 0 is impossible
> >>> +  pthread_key_t key1 = _RBTree_Container_of(node1,
> >>> +                                           POSIX_Keys_Rbtree_node,
> >>> +                                           rb_node)->key;
> >>> +  pthread_key_t key2 = _RBTree_Container_of(node2,
> >>> +                                           rb_node)->key;
> >>> +  Objects_Id thread_id1 = _RBTree_Container_of(node1,
> >>> +                                              rb_node)->thread_id;
> >>> +  Objects_Id thread_id2 = _RBTree_Container_of(node2,
> >>> +  int diff = key1 - key2;
> >>> +  if ( diff )
> >>> +    return diff;
> >>> +   * if thread_id1 or thread_id2 equals to 0, only key1 and key2 is
> >>> valued.
> >>> +   * it enables us search node only by pthread_key_t type key.
> >>> +  if ( thread_id1 && thread_id2 )
> >>> +    return thread_id1 - thread_id2;
> >>> +  return 0;
> >>>    *  _POSIX_Key_Manager_initialization
> >>> @@ -42,7 +93,7 @@
> >>>    *  Output parameters:  NONE
> >>>     _Objects_Initialize_information(
> >>>       &_POSIX_Keys_Information,   /* object information table */
> >>> @@ -60,4 +111,10 @@ void _POSIX_Key_Manager_initialization(void)
> >>>       NULL                        /* Proxy extraction support callout
> >>>   #endif
> >>> +  _RBTree_Initialize_empty(
> >>> +    &_POSIX_Keys_Rbtree,
> >>> +    _POSIX_Keys_Rbtree_compare_function,
> >>> +    true
> >>> diff --git a/cpukit/posix/src/keycreate.c
> b/cpukit/posix/src/keycreate.c
> >>> index b41b590..09778c3 100644
> >>> --- a/cpukit/posix/src/keycreate.c
> >>> +++ b/cpukit/posix/src/keycreate.c
> >>> @@ -37,10 +37,6 @@ int pthread_key_create(
> >>>     POSIX_Keys_Control  *the_key;
> >>> -  void                *table;
> >>> -  uint32_t             the_api;
> >>> -  uint32_t             bytes_to_allocate;
> >>>     _Thread_Disable_dispatch();
> >>> @@ -52,52 +48,8 @@ int pthread_key_create(
> >>>     the_key->destructor = destructor;
> >>> -   *  This is a bit more complex than one might initially expect
> because
> >>> -   *  APIs are optional.
> >>> -   *  NOTE: Currently RTEMS Classic API tasks are always enabled.
> >>> -  for ( the_api = 1; the_api <= OBJECTS_APIS_LAST; the_api++ ) {
> >>> -    the_key->Values[ the_api ] = NULL;
> >>> -    #if defined(RTEMS_DEBUG)
> >>> -       *  Since the removal of ITRON, this cannot occur.
> >>> -      if ( !_Objects_Information_table[ the_api ] )
> >>> -       continue;
> >>> -       * Currently all managers are installed if the API is installed.
> >>> -       * This would be a horrible implementation error.
> >>> -      if (_Objects_Information_table[ the_api ][ 1 ] == NULL )
> >>> -       _Internal_error_Occurred(
> >>> -         INTERNAL_ERROR_CORE,
> >>> -         true,
> >>> -         INTERNAL_ERROR_IMPLEMENTATION_KEY_CREATE_INCONSISTENCY
> >>> -    #endif
> >>> -    bytes_to_allocate = sizeof( void * ) *
> >>> -      (_Objects_Information_table[ the_api ][ 1 ]->maximum + 1);
> >>> -    table = _Workspace_Allocate( bytes_to_allocate );
> >>> -    if ( !table ) {
> >>> -      _POSIX_Keys_Free_memory( the_key );
> >>> -      _POSIX_Keys_Free( the_key );
> >>> -      _Thread_Enable_dispatch();
> >>> -      return ENOMEM;
> >>> -    the_key->Values[ the_api ] = table;
> >>> -    memset( table, '\0', bytes_to_allocate );
> >>> -  _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->Object, 0 );
> >>> -  *key = the_key->Object.id;
> >>> +  _Objects_Open_u32( &_POSIX_Keys_Information, &the_key->object, 0 );
> >>> +  *key = the_key->object.id;
> >>>     return 0;
> >>> diff --git a/cpukit/posix/src/keydelete.c
> b/cpukit/posix/src/keydelete.c
> >>> index 5ef6261..3f594bd 100644
> >>> --- a/cpukit/posix/src/keydelete.c
> >>> +++ b/cpukit/posix/src/keydelete.c
> >>> @@ -42,8 +42,6 @@ int pthread_key_delete(
> >>>     switch ( location ) {
> >>>       case OBJECTS_LOCAL:
> >>> -      _Objects_Close( &_POSIX_Keys_Information, &the_key->Object );
> >>> @@ -51,6 +49,7 @@ int pthread_key_delete(
> >>>          *         of the application to free the memory.
> >>> +      _Objects_Close( &_POSIX_Keys_Information, &the_key->object );
> >>>         return 0;
> >>> diff --git a/cpukit/posix/src/keyfreememory.c
> >>> b/cpukit/posix/src/keyfreememory.c
> >>> index f71af4f..e01e6e9 100644
> >>> --- a/cpukit/posix/src/keyfreememory.c
> >>> +++ b/cpukit/posix/src/keyfreememory.c
> >>> @@ -21,14 +21,43 @@
> >>>   #include <rtems/system.h>
> >>>   void _POSIX_Keys_Free_memory(
> >>> -  uint32_t            the_api;
> >>> +  POSIX_Keys_Rbtree_node search_node;
> >>> +  POSIX_Keys_Rbtree_node *p;
> >>> +  RBTree_Node *iter, *next;
> >>> -    _Workspace_Free( the_key->Values[ the_api ] );
> >>> +  search_node.key = the_key->object.id;
> >>> +  search_node.thread_id = 0;
> >>> +  iter = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
> >>> &search_node.rb_node);
> >>> +  if ( !iter )
> >>> +    return;
> >>> +   * find the smallest thread_id node in the rbtree.
> >>> +  next = _RBTree_Next_unprotected( iter, RBT_LEFT );
> >>> +  p = _RBTree_Container_of( next, POSIX_Keys_Rbtree_node, rb_node );
> >>> +  while ( p->key == the_key->object.id) {
> >>> +    iter = next;
> >>> +   * delete all nodes belongs to the_key from the rbtree and chain.
> >>> +  p = _RBTree_Container_of( iter, POSIX_Keys_Rbtree_node, rb_node );
> >>> +  while ( p->key == the_key->object.id ) {
> >>> +    next = _RBTree_Next_unprotected( iter, RBT_RIGHT );
> >>> +    _RBTree_Extract_unprotected( &_POSIX_Keys_Rbtree, iter );
> >>> +    _Chain_Extract_unprotected( &p->ch_node );
> >>> +    _Workspace_Free( p );
> >>> +    iter = next;
> >>> diff --git a/cpukit/posix/src/keygetspecific.c
> >>> b/cpukit/posix/src/keygetspecific.c
> >>> index debad83..39c0fcc 100644
> >>> --- a/cpukit/posix/src/keygetspecific.c
> >>> +++ b/cpukit/posix/src/keygetspecific.c
> >>> @@ -26,6 +26,7 @@
> >>> @@ -36,19 +37,24 @@ void *pthread_getspecific(
> >>>     pthread_key_t  key
> >>> -  register POSIX_Keys_Control *the_key;
> >>> -  uint32_t                     api;
> >>> -  uint32_t                     index;
> >>>     Objects_Locations            location;
> >>> +  RBTree_Node                 *p;
> >>>     void                        *key_data;
> >>> -  the_key = _POSIX_Keys_Get( key, &location );
> >>> +  _POSIX_Keys_Get( key, &location );
> >>>       case OBJECTS_LOCAL:
> >>> -      api      = _Objects_Get_API( _Thread_Executing->Object.id );
> >>> -      index    = _Objects_Get_index( _Thread_Executing->Object.id );
> >>> -      key_data = (void *) the_key->Values[ api ][ index ];
> >>> +      search_node.key = key;
> >>> +      search_node.thread_id = _Thread_Executing->Object.id;
> >>> +      p = _RBTree_Find_unprotected( &_POSIX_Keys_Rbtree,
> >>> +      key_data = NULL;
> >>> +      if ( p ) {
> >>> +        key_data = _RBTree_Container_of( p,
> >>> +                                        rb_node )->value;
> >>>         return key_data;
> >>> diff --git a/cpukit/posix/src/keyrundestructors.c
> >>> b/cpukit/posix/src/keyrundestructors.c
> >>> index 9f48888..db31d2b 100644
> >>> --- a/cpukit/posix/src/keyrundestructors.c
> >>> +++ b/cpukit/posix/src/keyrundestructors.c
> >>> @@ -23,7 +23,10 @@
> >>> +#include <rtems/score/wkspace.h>
> >>> +#include <rtems/posix/threadsup.h>
> >>>    *  _POSIX_Keys_Run_destructors
> >>> @@ -38,36 +41,46 @@ void _POSIX_Keys_Run_destructors(
> >>>     Thread_Control *thread
> >>> -  Objects_Maximum thread_index = _Objects_Get_index( thread->Object.id
> >>> -  Objects_APIs thread_api = _Objects_Get_API( thread->Object.id );
> >>> -  bool done = false;
> >>> +  Chain_Control *chain;
> >>> +  Chain_Node *iter, *next;
> >>> +  void *value;
> >>> +  POSIX_Keys_Control *the_key;
> >>> +  Objects_Locations location;
> >>> -   *  The standard allows one to avoid a potential infinite loop and
> >>> limit the
> >>> -   *  number of iterations.  An infinite loop may happen if
> destructors
> >>> set
> >>> -   *  thread specific data.  This can be considered dubious.
> >>> -   *  Reference: 17.1.1.2 P1003.1c/Draft 10, p. 163, line 99.
> >>> -  while ( !done ) {
> >>> -    Objects_Maximum index = 0;
> >>> -    Objects_Maximum max = _POSIX_Keys_Information.maximum;
> >>> +  _Thread_Disable_dispatch();
> >>> -    done = true;
> >>> +  chain = &((POSIX_API_Control *)\
> >>> +           thread->API_Extensions[ THREAD_API_POSIX ])->Key_Chain;
> >>> +  iter = _Chain_First( chain );
> >>> +  while ( !_Chain_Is_tail( chain, iter ) ) {
> >>> +    next = _Chain_Next( iter );
> >>> +     * remove key from rbtree and chain.
> >>> +     * here Chain_Node *iter can be convert to POSIX_Keys_Rbtree_node
> >>> +     * because Chain_Node is the first member of
> >>> +     * structure.
> >>> +                                &((POSIX_Keys_Rbtree_node
> >>> *)iter)->rb_node );
> >>> +    _Chain_Extract_unprotected( iter );
> >>> -    for ( index = 1 ; index <= max ; ++index ) {
> >>> -      POSIX_Keys_Control *key = (POSIX_Keys_Control *)
> >>> -        _POSIX_Keys_Information.local_table [ index ];
> >>> +     * run key value's destructor if destructor and value are both
> >>> non-null.
> >>> +    the_key = _POSIX_Keys_Get( ((POSIX_Keys_Rbtree_node *)iter)->key,
> >>> +                              &location);
> >>> +    destructor = the_key->destructor;
> >>> +    value = ((POSIX_Keys_Rbtree_node *)iter)->value;
> >>> +    if ( destructor != NULL && value != NULL )
> >>> +      (*destructor)( value );
> >>> +     * disable dispatch is nested here
> >>> +    _Thread_Enable_dispatch();
> >>> -      if ( key != NULL && key->destructor != NULL ) {
> >>> -        void *value = key->Values [ thread_api ][ thread_index ];
> >>> -        if ( value != NULL ) {
> >>> -          key->Values [ thread_api ][ thread_index ] = NULL;
> >>> -          (*key->destructor)( value );
> >>> -          done = false;
> >>> +    _Workspace_Free( (POSIX_Keys_Rbtree_node *)iter );
> >>> +    iter = next;
> >>> diff --git a/cpukit/posix/src/keysetspecific.c
> >>> b/cpukit/posix/src/keysetspecific.c
> >>> index b25e44c..132061a 100644
> >>> --- a/cpukit/posix/src/keysetspecific.c
> >>> +++ b/cpukit/posix/src/keysetspecific.c
> >>> @@ -26,7 +26,9 @@
> >>>    *  17.1.2 Thread-Specific Data Management, P1003.1c/Draft 10, p. 165
> >>> @@ -37,18 +39,36 @@ int pthread_setspecific(
> >>>     const void    *value
> >>> -  uint32_t                     api;
> >>> -  uint32_t                     index;
> >>> +  POSIX_Keys_Rbtree_node      *rb_node;
> >>> +  POSIX_API_Control           *api;
> >>> +  /** _POSIX_Keys_Get() would call _Thread_Disable_dispatch()
> >>> implicitly*/
> >>>       case OBJECTS_LOCAL:
> >>> -      the_key->Values[ api ][ index ] = (void *) value;
> >>> +      rb_node = _Workspace_Allocate( sizeof( POSIX_Keys_Rbtree_node )
> >>> +      if ( !rb_node ) {
> >>> +        return ENOMEM;
> >>> +      rb_node->key = key;
> >>> +      rb_node->thread_id = _Thread_Executing->Object.id;
> >>> +      rb_node->value = value;
> >>> +      if (_RBTree_Insert_unprotected( &_POSIX_Keys_Rbtree,
> >>> +                                     &(rb_node->rb_node) ) ) {
> >>> +          _Workspace_Free( rb_node );
> >>> +          return EAGAIN;
> >>> +      /** append rb_node to the thread API extension's chain */
> >>> +      api = (POSIX_API_Control *)\
> >>> +       (_Thread_Executing->API_Extensions[THREAD_API_POSIX]);
> >>> +      _Chain_Append_unprotected( &api->Key_Chain, &rb_node->ch_node );
> >>>         return 0;
> >>> diff --git a/cpukit/posix/src/pthread.c b/cpukit/posix/src/pthread.c
> >>> index 873449a..0ea44f1 100644
> >>> --- a/cpukit/posix/src/pthread.c
> >>> +++ b/cpukit/posix/src/pthread.c
> >>> @@ -234,6 +234,9 @@ static bool _POSIX_Threads_Create_extension(
> >>>       created
> >>> +  /** initialize thread's key vaule node chain */
> >>> +  _Chain_Initialize_empty( &api->Key_Chain );
> >>>     return true;
> >>> diff --git a/cpukit/sapi/src/posixapi.c b/cpukit/sapi/src/posixapi.c
> >>> index 3f65442..b5e62c2 100644
> >>> --- a/cpukit/sapi/src/posixapi.c
> >>> +++ b/cpukit/sapi/src/posixapi.c
> >>> @@ -64,7 +64,7 @@ void _POSIX_API_Initialize(void)
> >>>     _POSIX_signals_Manager_Initialization();
> >>>     _POSIX_Threads_Manager_initialization();
> >>>     _POSIX_Condition_variables_Manager_initialization();
> >>> -  _POSIX_Key_Manager_initialization();
> >>> +  _POSIX_Keys_Manager_initialization();
> >>>     _POSIX_Mutex_Manager_initialization();
> >>>     _POSIX_Message_queue_Manager_initialization();
> >>>     _POSIX_Semaphore_Manager_initialization();
> >>> 1.7.1
> >>> _______________________________________________
> >>> rtems-devel mailing list
> >>> rtems-devel at rtems.org
> >>> http://www.rtems.org/mailman/listinfo/rtems-devel
> >> Joel Sherrill, Ph.D.             Director of Research & Development
> >> joel.sherrill at OARcorp.com        On-Line Applications Research
> >> Ask me about RTEMS: a free RTOS  Huntsville AL 35805
> >> Support Available                (256) 722-9985
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130228/d911716b/attachment-0001.html>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130228/d911716b/attachment-0002.obj>
Desc: not available
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130228/d911716b/attachment-0003.obj>
