[PATCH v2 1/3] Add Moxie CPU support
Gedare Bloom
gedare at rtems.org
Wed Feb 27 17:22:53 UTC 2013
On Wed, Feb 27, 2013 at 9:11 AM, Anthony Green <green at moxielogic.com> wrote:
> Signed-off-by: Anthony Green <green at moxielogic.com>
> cpukit/score/cpu/moxie/.cvsignore | 2 +
> cpukit/score/cpu/moxie/ChangeLog | 9 +
As mentioned, you can get rid of the .cvsignore and ChangeLog
modifications/additions.
> cpukit/score/cpu/moxie/Makefile.am | 19 +
> cpukit/score/cpu/moxie/cpu.c | 152 +++
> cpukit/score/cpu/moxie/cpu_asm.S | 119 +++
> .../score/cpu/moxie/moxie-exception-frame-print.c | 18 +
> cpukit/score/cpu/moxie/preinstall.am | 41 +
> cpukit/score/cpu/moxie/rtems/asm.h | 116 +++
> cpukit/score/cpu/moxie/rtems/score/cpu.h | 1092 ++++++++++++++++++++
> cpukit/score/cpu/moxie/rtems/score/moxie.h | 45 +
> cpukit/score/cpu/moxie/rtems/score/types.h | 55 +
> 11 files changed, 1668 insertions(+)
> create mode 100644 cpukit/score/cpu/moxie/.cvsignore
> create mode 100644 cpukit/score/cpu/moxie/ChangeLog
> create mode 100644 cpukit/score/cpu/moxie/Makefile.am
> create mode 100644 cpukit/score/cpu/moxie/cpu.c
> create mode 100644 cpukit/score/cpu/moxie/cpu_asm.S
> create mode 100644 cpukit/score/cpu/moxie/moxie-exception-frame-print.c
> create mode 100644 cpukit/score/cpu/moxie/preinstall.am
> create mode 100644 cpukit/score/cpu/moxie/rtems/asm.h
> create mode 100644 cpukit/score/cpu/moxie/rtems/score/cpu.h
> create mode 100644 cpukit/score/cpu/moxie/rtems/score/moxie.h
> create mode 100644 cpukit/score/cpu/moxie/rtems/score/types.h
> diff --git a/cpukit/score/cpu/moxie/.cvsignore b/cpukit/score/cpu/moxie/.cvsignore
> new file mode 100644
> index 0000000..282522d
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/.cvsignore
> @@ -0,0 +1,2 @@
> +Makefile
> +Makefile.in
> diff --git a/cpukit/score/cpu/moxie/ChangeLog b/cpukit/score/cpu/moxie/ChangeLog
> index 0000000..172b5a5
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/ChangeLog
> @@ -0,0 +1,9 @@
> +2013-02-26 Anthony Green <green at moxielogic.com>
> + * moxie-exception-frame-print.c (_CPU_Exception_frame_print): New file.
> + * Makefile.am: Built moxie-exception-frame-print.c.
> + * cpu_asm.S, cpu.c, Makefile.am, preinstall.am,
> + rtems/score/moxie.h, rtems/score/types.h, rtems/asm.h: New files.
> diff --git a/cpukit/score/cpu/moxie/Makefile.am b/cpukit/score/cpu/moxie/Makefile.am
> index 0000000..931ca06
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/Makefile.am
> @@ -0,0 +1,19 @@
> +## $Id: Makefile.am,v 1.35 2006/01/12 09:57:43 ralf Exp $
> +include $(top_srcdir)/automake/compile.am
> +include_rtemsdir = $(includedir)/rtems
> +include_rtems_HEADERS = rtems/asm.h
> +include_rtems_scoredir = $(includedir)/rtems/score
> +include_rtems_score_HEADERS = rtems/score/cpu.h rtems/score/moxie.h \
> + rtems/score/types.h
> +noinst_LIBRARIES = libscorecpu.a
> +libscorecpu_a_SOURCES = cpu.c moxie-exception-frame-print.c cpu_asm.S
> +libscorecpu_a_CPPFLAGS = $(AM_CPPFLAGS)
> +include $(srcdir)/preinstall.am
> +include $(top_srcdir)/automake/local.am
> diff --git a/cpukit/score/cpu/moxie/cpu.c b/cpukit/score/cpu/moxie/cpu.c
> index 0000000..7f24a31
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/cpu.c
> @@ -0,0 +1,152 @@
> + * Moxie CPU Dependent Source
> + * COPYRIGHT (c) 2011 Anthony Green
> + * Based on example code and other ports with this copyright:
> + * COPYRIGHT (c) 1989-1999, 2010.
> + * On-Line Applications Research Corporation (OAR).
> + * The license and distribution terms for this file may be
> + * found in the file LICENSE in this distribution or at
> + * http://www.rtems.com/license/LICENSE.
> + * $Id: cpu.c,v 1.11 2010/03/27 15:01:35 joel Exp $
And get rid of any of these $Id$
> +#ifdef HAVE_CONFIG_H
> +#include "config.h"
> +#endif
> +#include <rtems/system.h>
> +#include <rtems/score/isr.h>
> +#include <rtems/score/wkspace.h>
> +/* _CPU_Initialize
> + * This routine performs processor dependent initialization.
> + * INPUT PARAMETERS: NONE
Please no blank lines between comments and function header, and no
more than one blank line at a time.
> +void _CPU_Initialize(void)
> + * If there is not an easy way to initialize the FP context
> + * during Context_Initialize, then it is usually easier to
> + * save an "uninitialized" FP context here and copy it to
> + * the task's during Context_Initialize.
> + /* FP context initialization support goes here */
> +/*PAGE
Get rid of this PAGE.
> + * _CPU_ISR_Get_level
> + * This routine returns the current interrupt level.
> +uint32_t _CPU_ISR_Get_level( void )
> + return 0;
> +/*PAGE
> + * _CPU_ISR_install_raw_handler
> +void _CPU_ISR_install_raw_handler(
> + uint32_t vector,
> + proc_ptr new_handler,
> + proc_ptr *old_handler
> + * This is where we install the interrupt handler into the "raw" interrupt
> + * table used by the CPU to dispatch interrupt handlers.
> + * Use Debug level IRQ Handlers
> + /* H8BD_Install_IRQ(vector,new_handler,old_handler); */
> +/*PAGE
> + * _CPU_ISR_install_vector
> + * This kernel routine installs the RTEMS handler for the
> + * specified vector.
> + * Input parameters:
> + * vector - interrupt vector number
> + * old_handler - former ISR for this vector number
> + * new_handler - replacement ISR for this vector number
> + * Output parameters: NONE
> +void _CPU_ISR_install_vector(
> + uint32_t vector,
> + *old_handler = _ISR_Vector_table[ vector ];
> + * If the interrupt vector table is a table of pointer to isr entry
> + * points, then we need to install the appropriate RTEMS interrupt
> + * handler for this vector number.
> + _CPU_ISR_install_raw_handler( vector, new_handler, old_handler );
> + * We put the actual user ISR address in '_ISR_vector_table'. This will
> + * be used by the _ISR_Handler so the user gets control.
> + _ISR_Vector_table[ vector ] = new_handler;
> +/*PAGE
> + * _CPU_Install_interrupt_stack
> +void _CPU_Install_interrupt_stack( void )
> +/*PAGE
> + * _CPU_Thread_Idle_body
> + * NOTES:
> + * 1. This is the same as the regular CPU independent algorithm.
> + * 2. If you implement this using a "halt", "idle", or "shutdown"
> + * instruction, then don't forget to put it in an infinite loop.
> + * 3. Be warned. Some processors with onboard DMA have been known
> + * to stop the DMA if the CPU were put in IDLE mode. This might
> + * also be a problem with other on-chip peripherals. So use this
> + * hook with caution.
> +#if 0
> +void *_CPU_Thread_Idle_body( uintptr_t ignored )
> + for( ; ; )
> + IDLE_Monitor();
> + /*asm(" sleep \n"); */
> + /* insert your "halt" instruction here */ ;
> +#endif
Avoid #if 0 ... #endif.
> diff --git a/cpukit/score/cpu/moxie/cpu_asm.S b/cpukit/score/cpu/moxie/cpu_asm.S
> index 0000000..4fc2706
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/cpu_asm.S
> @@ -0,0 +1,119 @@
> + * Moxie CPU functions
> + * Copyright (C) 2011 Anthony Green
> + * COPYRIGHT (c) 1989-1999.
> + * $Id: cpu_asm.S,v 1.12 2010/06/29 00:31:09 joel Exp $
> +#endif
> +#include <rtems/asm.h>
> + .text
> + .align 2
> + .global SYM(_CPU_Context_switch)
There is usually a macro provided, e.g. PUBLIC() to get a global symbol.
> +SYM(_CPU_Context_switch):
> + sto.l 0($r0), $fp
> + sto.l 4($r0), $sp
> + sto.l 8($r0), $r0
> + sto.l 12($r0), $r1
> + sto.l 16($r0), $r2
> + sto.l 20($r0), $r3
> + sto.l 24($r0), $r4
> + sto.l 28($r0), $r5
> + sto.l 32($r0), $r6
> + sto.l 36($r0), $r7
> + sto.l 40($r0), $r8
> + sto.l 44($r0), $r9
> + sto.l 48($r0), $r10
> + sto.l 52($r0), $r11
> + sto.l 56($r0), $r12
> + sto.l 60($r0), $r13
> +restore:
> + ldo.l $fp, 0($r1)
> + ldo.l $sp, 4($r1)
> + ldo.l $r0, 8($r1)
> + ldo.l $r2, 16($r1)
> + ldo.l $r3, 20($r1)
> + ldo.l $r4, 24($r1)
> + ldo.l $r5, 28($r1)
> + ldo.l $r6, 32($r1)
> + ldo.l $r7, 36($r1)
> + ldo.l $r8, 40($r1)
> + ldo.l $r9, 44($r1)
> + ldo.l $r10, 48($r1)
> + ldo.l $r11, 52($r1)
> + ldo.l $r12, 56($r1)
> + ldo.l $r13, 60($r1)
> + ldo.l $r1, 12($r1)
> + ret
> + .align 2
> + .global SYM(_CPU_Context_restore)
> +SYM(_CPU_Context_restore):
> + mov $r1, $r0
> + jmpa restore
> + VHandler for Vectored Interrupts
> + All IRQ's are vectored to routine _ISR_#vector_number
> + This routine stacks er0 and loads er0 with vector number
> + before transferring to here
> + .align 2
> + .global SYM(_ISR_Handler)
> + .extern SYM(_Vector_table)
> +SYM(_ISR_Handler):
> + brk
> + Called from ISR_Handler as a way of ending IRQ
> + but allowing dispatch to another task.
> + Must use RTE as CCR is still on stack but IRQ has been serviced.
> + CCR and PC occupy same word so rte can be used.
> + now using task stack
> + .align 2
> + .global SYM(_ISR_Dispatch)
> +SYM(_ISR_Dispatch):
> + brk
> + .align 2
> + .global SYM(_CPU_Context_save_fp)
> +SYM(_CPU_Context_save_fp):
> + brk
> + .align 2
> + .global SYM(_CPU_Context_restore_fp)
> +SYM(_CPU_Context_restore_fp):
> + brk
> diff --git a/cpukit/score/cpu/moxie/moxie-exception-frame-print.c b/cpukit/score/cpu/moxie/moxie-exception-frame-print.c
> index 0000000..3882fb6
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/moxie-exception-frame-print.c
> @@ -0,0 +1,18 @@
> + * Copyright (c) 2013 Anthony Green
> + #include "config.h"
> +#endif
> +#include <rtems/score/cpu.h>
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame )
> + /* TODO */
> diff --git a/cpukit/score/cpu/moxie/preinstall.am b/cpukit/score/cpu/moxie/preinstall.am
> index 0000000..62a2390
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/preinstall.am
> @@ -0,0 +1,41 @@
> +## Automatically generated by ampolish3 - Do not edit
> +if AMPOLISH3
> +$(srcdir)/preinstall.am: Makefile.am
> + $(AMPOLISH3) $(srcdir)/Makefile.am > $(srcdir)/preinstall.am
> +endif
> +PREINSTALL_DIRS =
> +DISTCLEANFILES = $(PREINSTALL_DIRS)
> +all-am: $(PREINSTALL_FILES)
> +PREINSTALL_FILES =
> +CLEANFILES = $(PREINSTALL_FILES)
> +$(PROJECT_INCLUDE)/rtems/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems
> + @: > $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> +$(PROJECT_INCLUDE)/rtems/asm.h: rtems/asm.h $(PROJECT_INCLUDE)/rtems/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/asm.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/asm.h
> +$(PROJECT_INCLUDE)/rtems/score/$(dirstamp):
> + @$(MKDIR_P) $(PROJECT_INCLUDE)/rtems/score
> + @: > $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +PREINSTALL_DIRS += $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> +$(PROJECT_INCLUDE)/rtems/score/cpu.h: rtems/score/cpu.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpu.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpu.h
> +$(PROJECT_INCLUDE)/rtems/score/moxie.h: rtems/score/moxie.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/moxie.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/moxie.h
> +$(PROJECT_INCLUDE)/rtems/score/types.h: rtems/score/types.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
> + $(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/types.h
> +PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/types.h
> diff --git a/cpukit/score/cpu/moxie/rtems/asm.h b/cpukit/score/cpu/moxie/rtems/asm.h
> index 0000000..e2a54c9
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/rtems/asm.h
> @@ -0,0 +1,116 @@
> + * @file rtems/asm.h
> + * This include file attempts to address the problems
> + * caused by incompatible flavors of assemblers and
> + * toolsets. It primarily addresses variations in the
> + * use of leading underscores on symbols and the requirement
> + * that register names be preceded by a %.
> + * NOTE: The spacing in the use of these macros
> + * is critical to them working as advertised.
> + * COPYRIGHT:
> + * This file is based on similar code found in newlib available
> + * from ftp.cygnus.com. The file which was used had no copyright
> + * notice. This file is freely distributable as long as the source
> + * of the file is noted. This file is:
> + * Anthony Green
> + * $Id: asm.h,v 1.9 2010/06/29 00:31:09 joel Exp $
> +#ifndef _RTEMS_ASM_H
> +#define _RTEMS_ASM_H
> + * Indicate we are in an assembly file and get the basic CPU definitions.
> +#include <rtems/score/moxie.h>
> + * Recent versions of GNU cpp define variables which indicate the
> + * need for underscores and percents. If not using GNU cpp or
> + * the version does not support this, then you will obviously
> + * have to define these as appropriate.
> +#ifndef __USER_LABEL_PREFIX__
> +#define __USER_LABEL_PREFIX__
> +#endif
> +#ifndef __REGISTER_PREFIX__
> +#define __REGISTER_PREFIX__ "$"
> +#endif
> +#include <rtems/concat.h>
> +/* Use the right prefix for global labels. */
> +#define SYM(x) CONCAT1 (__USER_LABEL_PREFIX__, x)
> +/* Use the right prefix for registers. */
> +#define REG(x) CONCAT1 (__REGISTER_PREFIX__, x)
> + * define macros for all of the registers on this CPU
> + * EXAMPLE: #define d0 REG (d0)
> +#define fp REG(fp)
> +#define sp REG(sp)
> +#define r0 REG(r0)
> +#define r1 REG(r1)
> +#define r2 REG(r2)
> +#define r3 REG(r3)
> +#define r4 REG(r4)
> +#define r5 REG(r5)
> +#define r6 REG(r6)
> +#define r7 REG(r7)
> +#define r8 REG(r8)
> +#define r9 REG(r9)
> +#define r10 REG(r10)
> +#define r11 REG(r11)
> +#define r12 REG(r12)
> +#define r13 REG(r13)
> + * Define macros to handle section beginning and ends.
> +#define BEGIN_CODE_DCL .text
> +#define END_CODE_DCL
> +#define BEGIN_DATA_DCL .data
> +#define END_DATA_DCL
> +#define BEGIN_CODE asm ( ".text
> +#define END_CODE ");
> +#define BEGIN_DATA
> +#define END_DATA
> +#define BEGIN_BSS
> +#define END_BSS
> +#define END
> + * Following must be tailor for a particular flavor of the C compiler.
> + * They may need to put underscores in front of the symbols.
> +#define PUBLIC(sym) .globl SYM (sym)
> +#define EXTERN(sym) .globl SYM (sym)
Here you can define these to .global SYM(sym)
> +#endif
> diff --git a/cpukit/score/cpu/moxie/rtems/score/cpu.h b/cpukit/score/cpu/moxie/rtems/score/cpu.h
> index 0000000..caeea6a
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/rtems/score/cpu.h
> @@ -0,0 +1,1092 @@
> + * @file rtems/score/cpu.h
> + * This include file contains information pertaining to the Moxie
> + * processor.
> + * Based on code with the following copyright..
> + * COPYRIGHT (c) 1989-2006, 2010.
> + * $Id$
> +#ifndef _RTEMS_SCORE_CPU_H
> +#define _RTEMS_SCORE_CPU_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> +#include <rtems/score/types.h>
> +#include <rtems/score/moxie.h> /* pick up machine definitions */
> +#include <rtems/bspIo.h> /* printk */
> +/* conditional compilation parameters */
> + * Should the calls to _Thread_Enable_dispatch be inlined?
> + * If TRUE, then they are inlined.
> + * If FALSE, then a subroutine call is made.
> + * Basically this is an example of the classic trade-off of size
> + * versus speed. Inlining the call (TRUE) typically increases the
> + * size of RTEMS while speeding up the enabling of dispatching.
> + * [NOTE: In general, the _Thread_Dispatch_disable_level will
> + * only be 0 or 1 unless you are in an interrupt handler and that
> + * interrupt handler invokes the executive.] When not inlined
> + * something calls _Thread_Enable_dispatch which in turns calls
> + * _Thread_Dispatch. If the enable dispatch is inlined, then
> + * one subroutine call is avoided entirely.]
> + * MOXIE Specific Information:
> + * XXX
> +#define CPU_INLINE_ENABLE_DISPATCH FALSE
> + * Should the body of the search loops in _Thread_queue_Enqueue_priority
> + * be unrolled one time? In unrolled each iteration of the loop examines
> + * two "nodes" on the chain being searched. Otherwise, only one node
> + * is examined per iteration.
> + * If TRUE, then the loops are unrolled.
> + * If FALSE, then the loops are not unrolled.
> + * The primary factor in making this decision is the cost of disabling
> + * and enabling interrupts (_ISR_Flash) versus the cost of rest of the
> + * body of the loop. On some CPUs, the flash is more expensive than
> + * one iteration of the loop body. In this case, it might be desirable
> + * to unroll the loop. It is important to note that on some CPUs, this
> + * code is the longest interrupt disable period in RTEMS. So it is
> + * necessary to strike a balance when setting this parameter.
> + * XXX
> +#define CPU_UNROLL_ENQUEUE_PRIORITY FALSE
> + * Should this target use 16 or 32 bit object Ids?
> +#define RTEMS_USE_32_BIT_OBJECT
> + * Does RTEMS manage a dedicated interrupt stack in software?
> + * If TRUE, then a stack is allocated in _ISR_Handler_initialization.
> + * If FALSE, nothing is done.
> + * If the CPU supports a dedicated interrupt stack in hardware,
> + * then it is generally the responsibility of the BSP to allocate it
> + * and set it up.
> + * If the CPU does not support a dedicated interrupt stack, then
> + * the porter has two options: (1) execute interrupts on the
> + * stack of the interrupted task, and (2) have RTEMS manage a dedicated
> + * interrupt stack.
> + * If this is TRUE, CPU_ALLOCATE_INTERRUPT_STACK should also be TRUE.
> + * Only one of CPU_HAS_SOFTWARE_INTERRUPT_STACK and
> + * CPU_HAS_HARDWARE_INTERRUPT_STACK should be set to TRUE. It is
> + * possible that both are FALSE for a particular CPU. Although it
> + * is unclear what that would imply about the interrupt processing
> + * procedure on that CPU.
> + * XXX
> +#define CPU_HAS_SOFTWARE_INTERRUPT_STACK TRUE
> + * Does the CPU follow the simple vectored interrupt model?
> + * If TRUE, then RTEMS allocates the vector table it internally manages.
> + * If FALSE, then the BSP is assumed to allocate and manage the vector
> + * table
> + * XXX document implementation including references if appropriate
> +#define CPU_SIMPLE_VECTORED_INTERRUPTS TRUE
> + * Does this CPU have hardware support for a dedicated interrupt stack?
> + * If TRUE, then it must be installed during initialization.
> + * If FALSE, then no installation is performed.
> + * XXX
> +#define CPU_HAS_HARDWARE_INTERRUPT_STACK FALSE
> + * Does RTEMS allocate a dedicated interrupt stack in the Interrupt Manager?
> + * If TRUE, then the memory is allocated during initialization.
> + * If FALSE, then the memory is allocated during initialization.
> + * This should be TRUE is CPU_HAS_SOFTWARE_INTERRUPT_STACK is TRUE.
> + * XXX
> +#define CPU_ALLOCATE_INTERRUPT_STACK TRUE
> + * Does the CPU have hardware floating point?
> + * If TRUE, then the RTEMS_FLOATING_POINT task attribute is supported.
> + * If FALSE, then the RTEMS_FLOATING_POINT task attribute is ignored.
> + * If there is a FP coprocessor such as the i387 or mc68881, then
> + * the answer is TRUE.
> + * The macro name "MOXIE_HAS_FPU" should be made CPU specific.
> + * It indicates whether or not this CPU model has FP support. For
> + * example, it would be possible to have an i386_nofp CPU model
> + * which set this to false to indicate that you have an i386 without
> + * an i387 and wish to leave floating point support out of RTEMS.
> + * XXX
> +#define CPU_HARDWARE_FP FALSE
> + * Are all tasks RTEMS_FLOATING_POINT tasks implicitly?
> + * If TRUE, then the RTEMS_FLOATING_POINT task attribute is assumed.
> + * If FALSE, then the RTEMS_FLOATING_POINT task attribute is followed.
> + * If CPU_HARDWARE_FP is FALSE, then this should be FALSE as well.
> + * XXX
> +#define CPU_ALL_TASKS_ARE_FP FALSE
> + * Should the IDLE task have a floating point context?
> + * If TRUE, then the IDLE task is created as a RTEMS_FLOATING_POINT task
> + * and it has a floating point context which is switched in and out.
> + * If FALSE, then the IDLE task does not have a floating point context.
> + * Setting this to TRUE negatively impacts the time required to preempt
> + * the IDLE task from an interrupt because the floating point context
> + * must be saved as part of the preemption.
> + * XXX
> +#define CPU_IDLE_TASK_IS_FP FALSE
> + * Should the saving of the floating point registers be deferred
> + * until a context switch is made to another different floating point
> + * task?
> + * If TRUE, then the floating point context will not be stored until
> + * necessary. It will remain in the floating point registers and not
> + * disturned until another floating point task is switched to.
> + * If FALSE, then the floating point context is saved when a floating
> + * point task is switched out and restored when the next floating point
> + * task is restored. The state of the floating point registers between
> + * those two operations is not specified.
> + * If the floating point context does NOT have to be saved as part of
> + * interrupt dispatching, then it should be safe to set this to TRUE.
> + * Setting this flag to TRUE results in using a different algorithm
> + * for deciding when to save and restore the floating point context.
> + * The deferred FP switch algorithm minimizes the number of times
> + * the FP context is saved and restored. The FP context is not saved
> + * until a context switch is made to another, different FP task.
> + * Thus in a system with only one FP task, the FP context will never
> + * be saved or restored.
> + * XXX
> +#define CPU_USE_DEFERRED_FP_SWITCH TRUE
> + * Does this port provide a CPU dependent IDLE task implementation?
> + * If TRUE, then the routine _CPU_Internal_threads_Idle_thread_body
> + * must be provided and is the default IDLE thread body instead of
> + * _Internal_threads_Idle_thread_body.
> + * If FALSE, then use the generic IDLE thread body if the BSP does
> + * not provide one.
> + * This is intended to allow for supporting processors which have
> + * a low power or idle mode. When the IDLE thread is executed, then
> + * the CPU can be powered down.
> + * The order of precedence for selecting the IDLE thread body is:
> + * 1. BSP provided
> + * 2. CPU dependent (if provided)
> + * 3. generic (if no BSP and no CPU dependent)
> + * XXX
> + * The port initially called a BSP dependent routine called
> + * IDLE_Monitor. The idle task body can be overridden by
> + * the BSP in newer versions of RTEMS.
> +#define CPU_PROVIDES_IDLE_THREAD_BODY FALSE
> + * Does the stack grow up (toward higher addresses) or down
> + * (toward lower addresses)?
> + * If TRUE, then the grows upward.
> + * If FALSE, then the grows toward smaller addresses.
> + * XXX
> +#define CPU_STACK_GROWS_UP FALSE
> + * The following is the variable attribute used to force alignment
> + * of critical RTEMS structures. On some processors it may make
> + * sense to have these aligned on tighter boundaries than
> + * the minimum requirements of the compiler in order to have as
> + * much of the critical data area as possible in a cache line.
> + * The placement of this macro in the declaration of the variables
> + * is based on the syntactically requirements of the GNU C
> + * "__attribute__" extension. For example with GNU C, use
> + * the following to force a structures to a 32 byte boundary.
> + * __attribute__ ((aligned (32)))
> + * NOTE: Currently only the Priority Bit Map table uses this feature.
> + * To benefit from using this, the data must be heavily
> + * used so it will stay in the cache and used frequently enough
> + * in the executive to justify turning this on.
> + * XXX
> +#define CPU_STRUCTURE_ALIGNMENT
> +#define CPU_TIMESTAMP_USE_STRUCT_TIMESPEC TRUE
> +#define CPU_TIMESTAMP_USE_INT64 FALSE
> +#define CPU_TIMESTAMP_USE_INT64_INLINE FALSE
> + * Define what is required to specify how the network to host conversion
> + * routines are handled.
> +#define CPU_BIG_ENDIAN TRUE
> +#define CPU_LITTLE_ENDIAN FALSE
> + * The following defines the number of bits actually used in the
> + * interrupt field of the task mode. How those bits map to the
> + * CPU interrupt levels is defined by the routine _CPU_ISR_Set_level().
> + * XXX
> +#define CPU_MODES_INTERRUPT_MASK 0x00000001
> + * Processor defined structures required for cpukit/score.
> + * XXX
> +/* may need to put some structures here. */
> + * Contexts
> + * Generally there are 2 types of context to save.
> + * 1. Interrupt registers to save
> + * 2. Task level registers to save
> + * This means we have the following 3 context items:
> + * 1. task level context stuff:: Context_Control
> + * 2. floating point task stuff:: Context_Control_fp
> + * 3. special interrupt level context :: Context_Control_interrupt
> + * On some processors, it is cost-effective to save only the callee
> + * preserved registers during a task context switch. This means
> + * that the ISR code needs to save those registers which do not
> + * persist across function calls. It is not mandatory to make this
> + * distinctions between the caller/callee saves registers for the
> + * purpose of minimizing context saved during task switch and on interrupts.
> + * If the cost of saving extra registers is minimal, simplicity is the
> + * choice. Save the same context on interrupt entry as for tasks in
> + * this case.
> + * Additionally, if gdb is to be made aware of RTEMS tasks for this CPU, then
> + * care should be used in designing the context area.
> + * On some CPUs with hardware floating point support, the Context_Control_fp
> + * structure will not be used or it simply consist of an array of a
> + * fixed number of bytes. This is done when the floating point context
> + * is dumped by a "FP save context" type instruction and the format
> + * is not really defined by the CPU. In this case, there is no need
> + * to figure out the exact format -- only the size. Of course, although
> + * this is enough information for RTEMS, it is probably not enough for
> + * a debugger such as gdb. But that is another problem.
> + * XXX
> +#define nogap __attribute__ ((packed))
Do you need this attribute? It is better to avoid attributes if possible.
> +typedef struct {
> + void *fp nogap;
> + void *sp nogap;
> + uint32_t r0 nogap;
> + uint32_t r1 nogap;
> + uint32_t r2 nogap;
> + uint32_t r3 nogap;
> + uint32_t r4 nogap;
> + uint32_t r5 nogap;
> + uint32_t r6 nogap;
> + uint32_t r7 nogap;
> + uint32_t r8 nogap;
> + uint32_t r9 nogap;
> + uint32_t r10 nogap;
> + uint32_t r11 nogap;
> + uint32_t r12 nogap;
> + uint32_t r13 nogap;
> +} Context_Control;
> +#define _CPU_Context_Get_SP( _context ) \
> + (_context)->sp
This macro is not consistent with score naming, but also, is it
necessary for something?
> +typedef struct {
> + double some_float_register[2];
> +} Context_Control_fp;
> +typedef struct {
> + uint32_t special_interrupt_register;
> +} CPU_Interrupt_frame;
> + * This variable is optional. It is used on CPUs on which it is difficult
> + * to generate an "uninitialized" FP context. It is filled in by
> + * _CPU_Initialize and copied into the task's FP context area during
> + * _CPU_Context_Initialize.
> + * XXX
> +SCORE_EXTERN Context_Control_fp _CPU_Null_fp_context;
> + * Nothing prevents the porter from declaring more CPU specific variables.
> + * XXX
> +/* XXX: if needed, put more variables here */
> + * The size of the floating point context area. On some CPUs this
> + * will not be a "sizeof" because the format of the floating point
> + * area is not defined -- only the size is. This is usually on
> + * CPUs with a "floating point save context" instruction.
> + * XXX
> +#define CPU_CONTEXT_FP_SIZE sizeof( Context_Control_fp )
> + * Amount of extra stack (above minimum stack size) required by
> + * system initialization thread. Remember that in a multiprocessor
> + * system the system intialization thread becomes the MP server thread.
> + * It is highly unlikely the MOXIE will get used in a multiprocessor system.
> +#define CPU_MPCI_RECEIVE_SERVER_EXTRA_STACK 0
> + * This defines the number of entries in the ISR_Vector_table managed
> + * by RTEMS.
> + * XXX
> +#define CPU_INTERRUPT_NUMBER_OF_VECTORS 64
> +#define CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER (CPU_INTERRUPT_NUMBER_OF_VECTORS - 1)
> + * This is defined if the port has a special way to report the ISR nesting
> + * level. Most ports maintain the variable _ISR_Nest_level.
> +#define CPU_PROVIDES_ISR_IS_IN_PROGRESS FALSE
> + * Should be large enough to run all RTEMS tests. This ensures
> + * that a "reasonable" small application should not have any problems.
> + * XXX
> +#define CPU_STACK_MINIMUM_SIZE (1536)
> + * Size of a pointer.
> + * This must be an integer literal that can be used by the assembler. This
> + * value will be used to calculate offsets of structure members. These
> + * offsets will be used in assembler code.
> +#define CPU_SIZEOF_POINTER 4
> + * CPU's worst alignment requirement for data types on a byte boundary. This
> + * alignment does not take into account the requirements for the stack.
> + * XXX
> +#define CPU_ALIGNMENT 8
> + * This number corresponds to the byte alignment requirement for the
> + * heap handler. This alignment requirement may be stricter than that
> + * for the data types alignment specified by CPU_ALIGNMENT. It is
> + * common for the heap to follow the same alignment requirement as
> + * CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict enough for the heap,
> + * then this should be set to CPU_ALIGNMENT.
> + * NOTE: This does not have to be a power of 2. It does have to
> + * be greater or equal to than CPU_ALIGNMENT.
> + * XXX
> +#define CPU_HEAP_ALIGNMENT CPU_ALIGNMENT
> + * This number corresponds to the byte alignment requirement for memory
> + * buffers allocated by the partition manager. This alignment requirement
> + * may be stricter than that for the data types alignment specified by
> + * CPU_ALIGNMENT. It is common for the partition to follow the same
> + * alignment requirement as CPU_ALIGNMENT. If the CPU_ALIGNMENT is strict
> + * enough for the partition, then this should be set to CPU_ALIGNMENT.
> + * XXX
> +#define CPU_PARTITION_ALIGNMENT CPU_ALIGNMENT
> + * stack. This alignment requirement may be stricter than that for the
> + * data types alignment specified by CPU_ALIGNMENT. If the CPU_ALIGNMENT
> + * is strict enough for the stack, then this should be set to 0.
> + * NOTE: This must be a power of 2 either 0 or greater than CPU_ALIGNMENT.
> + * XXX
> +#define CPU_STACK_ALIGNMENT 0
I think we decided 0 is a bug. This is a recent issue though. Can you
change this to 1, or CPU_ALIGNMENT?
> + * ISR handler macros
> + * Support routine to initialize the RTEMS vector table after it is allocated.
> +#define _CPU_Initialize_vectors()
> + * Disable all interrupts for an RTEMS critical section. The previous
> + * level is returned in _level.
> + * XXX
> +#define _CPU_ISR_Disable( _isr_cookie ) (_isr_cookie) = 0
> + * Enable interrupts to the previous level (returned by _CPU_ISR_Disable).
> + * This indicates the end of an RTEMS critical section. The parameter
> + * _level is not modified.
> + * XXX
> +#define _CPU_ISR_Enable( _isr_cookie )
> + * This temporarily restores the interrupt to _level before immediately
> + * disabling them again. This is used to divide long RTEMS critical
> + * sections into two or more parts. The parameter _level is not
> + * modified.
> + * XXX
> +#define _CPU_ISR_Flash( _isr_cookie )
> + * Map interrupt level in task mode onto the hardware that the CPU
> + * actually provides. Currently, interrupt levels which do not
> + * map onto the CPU in a generic fashion are undefined. Someday,
> + * it would be nice if these were "mapped" by the application
> + * via a callout. For example, m68k has 8 levels 0 - 7, levels
> + * 8 - 255 would be available for bsp/application specific meaning.
> + * This could be used to manage a programmable interrupt controller
> + * via the rtems_task_mode directive.
> + * XXX
> +#define _CPU_ISR_Set_level( _new_level ) \
> + if (_new_level) asm volatile ( "nop\n" ); \
> + else asm volatile ( "nop\n" ); \
> +uint32_t _CPU_ISR_Get_level( void );
> +/* end of ISR handler macros */
> +/* Context handler macros */
> + * Initialize the context to a state suitable for starting a
> + * task after a context restore operation. Generally, this
> + * involves:
> + * - setting a starting address
> + * - preparing the stack
> + * - preparing the stack and frame pointers
> + * - setting the proper interrupt level in the context
> + * - initializing the floating point context
> + * This routine generally does not set any unnecessary register
> + * in the context. The state of the "general data" registers is
> + * undefined at task start time.
> + * NOTE: This is_fp parameter is TRUE if the thread is to be a floating
> + * point thread. This is typically only used on CPUs where the
> + * FPU may be easily disabled by software such as on the SPARC
> + * where the PSR contains an enable FPU bit.
> + * XXX
> +#define CPU_CCR_INTERRUPTS_ON 0x80
> +#define CPU_CCR_INTERRUPTS_OFF 0x00
> +#define _CPU_Context_Initialize( _the_context, _stack_base, _size, \
> + _isr, _entry_point, _is_fp ) \
> + /* Locate Me */ \
> + do { \
> + uintptr_t _stack; \
> + _stack = ((uintptr_t)(_stack_base)) + (_size) - 8; \
> + *((proc_ptr *)(_stack)) = (_entry_point); \
> + _stack -= 4; \
> + (_the_context)->fp = (void *)_stack; \
> + (_the_context)->sp = (void *)_stack; \
> + } while (0)
> + * This routine is responsible for somehow restarting the currently
> + * executing task. If you are lucky, then all that is necessary
> + * is restoring the context. Otherwise, there will need to be
> + * a special assembly routine which does something special in this
> + * case. Context_Restore should work most of the time. It will
> + * not work if restarting self conflicts with the stack frame
> + * assumptions of restoring a context.
> + * XXX
> +#define _CPU_Context_Restart_self( _the_context ) \
> + _CPU_Context_restore( (_the_context) );
> + * The purpose of this macro is to allow the initial pointer into
> + * a floating point context area (used to save the floating point
> + * context) to be at an arbitrary place in the floating point
> + * context area.
> + * This is necessary because some FP units are designed to have
> + * their context saved as a stack which grows into lower addresses.
> + * Other FP units can be saved by simply moving registers into offsets
> + * from the base of the context area. Finally some FP units provide
> + * a "dump context" instruction which could fill in from high to low
> + * or low to high based on the whim of the CPU designers.
> + * XXX
> +#define _CPU_Context_Fp_start( _base, _offset ) \
> + ( (void *) (_base) + (_offset) )
> + * This routine initializes the FP context area passed to it to.
> + * There are a few standard ways in which to initialize the
> + * floating point context. The code included for this macro assumes
> + * that this is a CPU in which a "initial" FP context was saved into
> + * _CPU_Null_fp_context and it simply copies it to the destination
> + * context passed to it.
> + * Other models include (1) not doing anything, and (2) putting
> + * a "null FP status word" in the correct place in the FP context.
> + * XXX
> +#define _CPU_Context_Initialize_fp( _destination ) \
> + *(*(_destination)) = _CPU_Null_fp_context; \
> +/* end of Context handler macros */
> +/* Fatal Error manager macros */
> + * This routine copies _error into a known place -- typically a stack
> + * location or a register, optionally disables interrupts, and
> + * halts/stops the CPU.
> + * XXX
> +#define _CPU_Fatal_halt( _error ) \
> + printk("Fatal Error %d Halted\n",_error); \
> + for(;;)
I don't know if you can count on printing to work when you have a fatal error.
> +/* end of Fatal Error manager macros */
> +/* Bitfield handler macros */
> + * This routine sets _output to the bit number of the first bit
> + * set in _value. _value is of CPU dependent type Priority_Bit_map_control.
> + * This type may be either 16 or 32 bits wide although only the 16
> + * least significant bits will be used.
> + * There are a number of variables in using a "find first bit" type
> + * instruction.
> + * (1) What happens when run on a value of zero?
> + * (2) Bits may be numbered from MSB to LSB or vice-versa.
> + * (3) The numbering may be zero or one based.
> + * (4) The "find first bit" instruction may search from MSB or LSB.
> + * RTEMS guarantees that (1) will never happen so it is not a concern.
> + * (2),(3), (4) are handled by the macros _CPU_Priority_mask() and
> + * _CPU_Priority_bits_index(). These three form a set of routines
> + * which must logically operate together. Bits in the _value are
> + * set and cleared based on masks built by _CPU_Priority_mask().
> + * The basic major and minor values calculated by _Priority_Major()
> + * and _Priority_Minor() are "massaged" by _CPU_Priority_bits_index()
> + * to properly range between the values returned by the "find first bit"
> + * instruction. This makes it possible for _Priority_Get_highest() to
> + * calculate the major and directly index into the minor table.
> + * This mapping is necessary to ensure that 0 (a high priority major/minor)
> + * is the first bit found.
> + * This entire "find first bit" and mapping process depends heavily
> + * on the manner in which a priority is broken into a major and minor
> + * components with the major being the 4 MSB of a priority and minor
> + * the 4 LSB. Thus (0 << 4) + 0 corresponds to priority 0 -- the highest
> + * priority. And (15 << 4) + 14 corresponds to priority 254 -- the next
> + * to the lowest priority.
> + * If your CPU does not have a "find first bit" instruction, then
> + * there are ways to make do without it. Here are a handful of ways
> + * to implement this in software:
> + * - a series of 16 bit test instructions
> + * - a "binary search using if's"
> + * - _number = 0
> + * if _value > 0x00ff
> + * _value >>=8
> + * _number = 8;
> + * if _value > 0x0000f
> + * _value >=8
> + * _number += 4
> + * _number += bit_set_table[ _value ]
> + * where bit_set_table[ 16 ] has values which indicate the first
> + * bit set
> + * XXX
> +#define CPU_USE_GENERIC_BITFIELD_CODE TRUE
> +#define CPU_USE_GENERIC_BITFIELD_DATA TRUE
> +#if (CPU_USE_GENERIC_BITFIELD_CODE == FALSE)
> +#define _CPU_Bitfield_Find_first_bit( _value, _output ) \
> + (_output) = 0; /* do something to prevent warnings */ \
> +#endif
> +/* end of Bitfield handler macros */
> + * This routine builds the mask which corresponds to the bit fields
> + * as searched by _CPU_Bitfield_Find_first_bit(). See the discussion
> + * for that routine.
> + * XXX
> +#define _CPU_Priority_Mask( _bit_number ) \
> + ( 1 << (_bit_number) )
> +#endif
> + * This routine translates the bit numbers returned by
> + * _CPU_Bitfield_Find_first_bit() into something suitable for use as
> + * a major or minor component of a priority. See the discussion
> + * XXX
> +#define _CPU_Priority_bits_index( _priority ) \
> + (_priority)
> +#endif
> +/* end of Priority handler macros */
> +/* functions */
> + * _CPU_Initialize
> + * This routine performs CPU dependent initialization.
> + * XXX
> +void _CPU_Initialize(void);
> + * This routine installs a "raw" interrupt handler directly into the
> + * processor's vector table.
> + * XXX
> + uint32_t vector,
> + * This routine installs an interrupt vector.
> + * XXX
> + uint32_t vector,
> + * This routine installs the hardware interrupt stack pointer.
> + * NOTE: It need only be provided if CPU_HAS_HARDWARE_INTERRUPT_STACK
> + * is TRUE.
> + * XXX
> +void _CPU_Install_interrupt_stack( void );
> + * _CPU_Internal_threads_Idle_thread_body
> + * This routine is the CPU dependent IDLE thread body.
> + * NOTE: It need only be provided if CPU_PROVIDES_IDLE_THREAD_BODY
> + * is TRUE.
> + * XXX
> +void *_CPU_Thread_Idle_body( uint32_t );
> + * _CPU_Context_switch
> + * This routine switches from the run context to the heir context.
> + * XXX
> +void _CPU_Context_switch(
> + Context_Control *run,
> + Context_Control *heir
> + * _CPU_Context_restore
> + * This routine is generallu used only to restart self in an
> + * efficient manner. It may simply be a label in _CPU_Context_switch.
> + * NOTE: May be unnecessary to reload some registers.
> + * XXX
> +void _CPU_Context_restore(
> + Context_Control *new_context
> + * _CPU_Context_save_fp
> + * This routine saves the floating point context passed to it.
> + * XXX
> +void _CPU_Context_save_fp(
> + Context_Control_fp **fp_context_ptr
> + * _CPU_Context_restore_fp
> + * This routine restores the floating point context passed to it.
> + * XXX
> +void _CPU_Context_restore_fp(
> + * @brief The set of registers that specifies the complete processor state.
> + * The CPU exception frame may be available in fatal error conditions like for
> + * example illegal opcodes, instruction fetch errors, or data access errors.
> + * @see rtems_fatal(), RTEMS_FATAL_SOURCE_EXCEPTION, and
> + * rtems_exception_frame_print().
> +typedef struct {
> + uint32_t integer_registers [16];
> +} CPU_Exception_frame;
> + * @brief Prints the exception frame via printk().
> + * @see rtems_fatal() and RTEMS_FATAL_SOURCE_EXCEPTION.
> +void _CPU_Exception_frame_print( const CPU_Exception_frame *frame );
> +/* The following routine swaps the endian format of an unsigned int.
> + * It must be static because it is referenced indirectly.
> + * This version will work on any processor, but if there is a better
> + * way for your CPU PLEASE use it. The most common way to do this is to:
> + * swap least significant two bytes with 16-bit rotate
> + * swap upper and lower 16-bits
> + * swap most significant two bytes with 16-bit rotate
> + * Some CPUs have special instructions which swap a 32-bit quantity in
> + * a single instruction (e.g. i486). It is probably best to avoid
> + * an "endian swapping control bit" in the CPU. One good reason is
> + * that interrupts would probably have to be disabled to ensure that
> + * an interrupt does not try to access the same "chunk" with the wrong
> + * endian. Another good reason is that on some CPUs, the endian bit
> + * endianness for ALL fetches -- both code and data -- so the code
> + * will be fetched incorrectly.
> + * This is the generic implementation.
> +static inline uint32_t CPU_swap_u32(
> + uint32_t value
> + uint32_t byte1, byte2, byte3, byte4, swapped;
> + byte4 = (value >> 24) & 0xff;
> + byte3 = (value >> 16) & 0xff;
> + byte2 = (value >> 8) & 0xff;
> + byte1 = value & 0xff;
> + swapped = (byte1 << 24) | (byte2 << 16) | (byte3 << 8) | byte4;
> + return( swapped );
> +#define CPU_swap_u16( value ) \
> + (((value&0xff) << 8) | ((value >> 8)&0xff))
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/score/cpu/moxie/rtems/score/moxie.h b/cpukit/score/cpu/moxie/rtems/score/moxie.h
> index 0000000..5cce9e3
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/rtems/score/moxie.h
> @@ -0,0 +1,45 @@
> + * @file rtems/score/moxie.h
> + * This file contains information pertaining to the Moxie processor.
> + * COPYRIGHT (c) 2011, 2013
> + * Anthony Green
> + * Based on code with the following copyright...
> + * $Id$
> +#ifndef _RTEMS_SCORE_MOXIE_H
> +#define _RTEMS_SCORE_MOXIE_H
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * This file contains the information required to build
> + * RTEMS for a particular member of the "moxie"
> + * family when executing in protected mode. It does
> + * this by setting variables to indicate which implementation
> + * dependent features are present in a particular member
> + * of the family.
> +#define CPU_NAME "Moxie"
> +#define CPU_MODEL_NAME "MoxieLite"
> +#ifdef __cplusplus
> +#endif
> +#endif
> diff --git a/cpukit/score/cpu/moxie/rtems/score/types.h b/cpukit/score/cpu/moxie/rtems/score/types.h
> index 0000000..b26ba9f
> --- /dev/null
> +++ b/cpukit/score/cpu/moxie/rtems/score/types.h
> @@ -0,0 +1,55 @@
> + * @file rtems/score/types.h
> + * Anthony Green
> + * $Id$
> +#ifndef _RTEMS_SCORE_TYPES_H
> +#define _RTEMS_SCORE_TYPES_H
> +#include <rtems/score/basedefs.h>
> +#ifndef ASM
> +#include <stdbool.h>
> +#include <stdint.h>
> +#ifdef __cplusplus
> +extern "C" {
> +#endif
> + * This section defines the basic types for this processor.
> +typedef uint16_t Priority_bit_map_Control;
> +typedef void moxie_isr;
> +typedef void ( *moxie_isr_entry )( void );
> +#ifdef RTEMS_DEPRECATED_TYPES
> +typedef bool boolean; /* Boolean value */
> +typedef float single_precision; /* single precision float */
> +typedef double double_precision; /* double precision float */
> +#endif
> +#ifdef __cplusplus
> +#endif
> +#endif /* !ASM */
> +#endif
> 1.8.1.4
> rtems-devel mailing list
> rtems-devel at rtems.org
