[PATCH 2/5] rtems: Critical fix for events
Wed Jan 2 17:56:35 UTC 2013
Commit 4b45c1393ce4ee3e1c2762ef3145d2bd6b5b38da marked a test in
_Event_Timeout() as debug only.  This test is need in non-debug
configurations too since otherwise state corruption can happen.  A
revised test sptests/spintrcritical10 checks the relevant sequences.
 cpukit/rtems/src/eventtimeout.c                    |   19 +-
 testsuites/sptests/spintrcritical10/init.c         |  307 ++++++++++++++++++--
 .../sptests/spintrcritical10/spintrcritical10.scn  |    5 +-
 3 files changed, 301 insertions(+), 30 deletions(-)
diff --git a/cpukit/rtems/src/eventtimeout.c b/cpukit/rtems/src/eventtimeout.c
index 58dee84..31eb043 100644
--- a/cpukit/rtems/src/eventtimeout.c
+++ b/cpukit/rtems/src/eventtimeout.c
@@ -49,13 +49,18 @@ void _Event_Timeout(
        *  a timeout is not allowed to occur.
       _ISR_Disable( level );
-        #if defined(RTEMS_DEBUG)
-          if ( !the_thread->Wait.count ) {  /* verify thread is waiting */
-            _Thread_Unnest_dispatch();
-            _ISR_Enable( level );
-            return;
-        #endif
+         * Verify that the thread is still waiting for the event condition.
+         * This test is necessary to avoid state corruption if the timeout
+         * happens after the event condition is satisfied in
+         * _Event_Surrender().  A satisfied event condition is indicated with
+         * count set to zero.
+        if ( !the_thread->Wait.count ) {
+          _Thread_Unnest_dispatch();
+          _ISR_Enable( level );
+          return;
         the_thread->Wait.count = 0;
         if ( _Thread_Is_executing( the_thread ) ) {
diff --git a/testsuites/sptests/spintrcritical10/init.c b/testsuites/sptests/spintrcritical10/init.c
index 66306cd..f284780 100644
--- a/testsuites/sptests/spintrcritical10/init.c
+++ b/testsuites/sptests/spintrcritical10/init.c
@@ -2,49 +2,316 @@
  *  COPYRIGHT (c) 1989-2012.
  *  On-Line Applications Research Corporation (OAR).
+ *  Copyright (c) 2013 embedded brains GmbH.
  *  The license and distribution terms for this file may be
  *  found in the file LICENSE in this distribution or at
  *  http://www.rtems.com/license/LICENSE.
 #ifdef HAVE_CONFIG_H
-#include "config.h"
+  #include "config.h"
 #endif
 #define __RTEMS_VIOLATE_KERNEL_VISIBILITY__ 1
 #include <tmacros.h>
 #include <intrcritical.h>
-/* forward declarations to avoid warnings */
-rtems_task Init(rtems_task_argument argument);
+#define GREEN RTEMS_EVENT_0
-rtems_id Main_task;
+#define RED RTEMS_EVENT_1
-rtems_task Init(
-  rtems_task_argument ignored
+#define EVENTS (GREEN | RED)
+#define DEADBEEF 0xdeadbeef
+typedef struct {
+  rtems_id timer;
+  Thread_Control *thread;
+  bool hit;
+} test_context;
+static void any_satisfy_before_timeout(rtems_id timer, void *arg)
-  rtems_status_code     sc;
-  rtems_event_set       out;
-  int                   resets;
+  rtems_status_code sc;
+  test_context *ctx = arg;
+  const Thread_Control *thread = ctx->thread;
-  puts( "\n\n*** TEST INTERRUPT CRITICAL SECTION 10 ***" );
+  if (thread->Wait.count != 0) {
+    ctx->hit = _Event_Sync_state == THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED;
+    rtems_test_assert(thread->Wait.count == EVENTS);
+      *(rtems_event_set *) thread->Wait.return_argument == DEADBEEF
+    rtems_test_assert(thread->Wait.return_code == RTEMS_SUCCESSFUL);
+    sc = rtems_event_send(thread->Object.id, GREEN);
+    rtems_test_assert(sc == RTEMS_SUCCESSFUL);
+    rtems_test_assert(thread->Wait.count == 0);
+      *(rtems_event_set *) thread->Wait.return_argument == GREEN
+    sc = rtems_event_send(thread->Object.id, RED);
+    _Event_Timeout(thread->Object.id, &_Event_Sync_state);
+    if (ctx->hit) {
+        _Event_Sync_state == THREAD_BLOCKING_OPERATION_SATISFIED
+  sc = rtems_timer_reset(timer);
+static void test_any_satisfy_before_timeout(test_context *ctx)
+  int resets = 0;
+  puts(
+    "Init - Trying to generate any satisfied before timeout "
+    "while blocking on event"
+  ctx->hit = false;
+  interrupt_critical_section_test_support_initialize(NULL);
+  sc = rtems_timer_fire_after(ctx->timer, 1, any_satisfy_before_timeout, ctx);
+  while (!ctx->hit && resets < 2) {
+    rtems_event_set out;
+    if (interrupt_critical_section_test_support_delay())
+      resets++;
+    out = DEADBEEF;
+    sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ANY | RTEMS_WAIT, 1, &out);
+    rtems_test_assert(out == GREEN);
+    out = DEADBEEF;
+    sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ANY | RTEMS_NO_WAIT, 0, &out);
+    rtems_test_assert(out == RED);
+  sc = rtems_timer_cancel(ctx->timer);
+  rtems_test_assert(ctx->hit);
+static void all_satisfy_before_timeout(rtems_id timer, void *arg)
+      *(rtems_event_set *) thread->Wait.return_argument == EVENTS
+    if (ctx->hit) {
-  puts( "Init - Test may not be able to detect case is hit reliably" );
-  puts( "Init - Trying to generate timeout while blocking on event" );
+static void test_all_satisfy_before_timeout(test_context *ctx)
+  int resets = 0;
+  puts(
+    "Init - Trying to generate all satisfied before timeout "
+  ctx->hit = false;
-  Main_task = rtems_task_self();
+  sc = rtems_timer_fire_after(ctx->timer, 1, all_satisfy_before_timeout, ctx);
-  interrupt_critical_section_test_support_initialize( NULL );
-  for (resets=0 ; resets< 2 ;) {
-    if ( interrupt_critical_section_test_support_delay() )
       resets++;
-    sc = rtems_event_receive( 0x01, RTEMS_DEFAULT_OPTIONS, 1, &out );
-    fatal_directive_status( sc, RTEMS_TIMEOUT, "event_receive timeout" );
+    out = DEADBEEF;
+    sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ALL | RTEMS_WAIT, 1, &out);
+    rtems_test_assert(out == EVENTS);
+static void timeout_before_satisfied(rtems_id timer, void *arg)
+    ctx->hit =
+      _Event_Sync_state == THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED;
+    rtems_test_assert(thread->Wait.return_code == RTEMS_TIMEOUT);
+    sc = rtems_event_send(thread->Object.id, EVENTS);
+    if (ctx->hit) {
+        _Event_Sync_state == THREAD_BLOCKING_OPERATION_TIMEOUT
+static void test_timeout_before_all_satisfy(test_context *ctx)
+  int resets = 0;
+  puts(
+    "Init - Trying to generate timeout before all satisfied "
+  ctx->hit = false;
+  sc = rtems_timer_fire_after(ctx->timer, 1, timeout_before_satisfied, ctx);
+      resets++;
+    out = DEADBEEF;
+    rtems_test_assert(sc == RTEMS_TIMEOUT);
+    rtems_test_assert(out == DEADBEEF);
+    out = DEADBEEF;
+    sc = rtems_event_receive(EVENTS, RTEMS_EVENT_ALL | RTEMS_NO_WAIT, 0, &out);
+static rtems_task Init(
+  rtems_task_argument ignored
+  test_context ctx = {
+    .thread = _Thread_Executing
+  puts( "\n\n*** TEST INTERRUPT CRITICAL SECTION 10 ***" );
+  sc = rtems_timer_create(rtems_build_name('T', 'I', 'M', 'R'), &ctx.timer);
+  test_any_satisfy_before_timeout(&ctx);
+  test_all_satisfy_before_timeout(&ctx);
+  test_timeout_before_all_satisfy(&ctx);
   puts( "*** END OF TEST INTERRUPT CRITICAL SECTION 10 ***" );
   rtems_test_exit(0);
@@ -61,5 +328,3 @@ rtems_task Init(
 #define CONFIGURE_INIT
 #include <rtems/confdefs.h>
-/* global variables */
diff --git a/testsuites/sptests/spintrcritical10/spintrcritical10.scn b/testsuites/sptests/spintrcritical10/spintrcritical10.scn
index 9f59c0e..e8db0c5 100644
--- a/testsuites/sptests/spintrcritical10/spintrcritical10.scn
+++ b/testsuites/sptests/spintrcritical10/spintrcritical10.scn
@@ -1,4 +1,5 @@
-Init - Test may not be able to detect case is hit reliably
-Init - Trying to generate timeout while blocking on event
+Init - Trying to generate any satisfied before timeout while blocking on event
+Init - Trying to generate all satisfied before timeout while blocking on event
+Init - Trying to generate timeout before all satisfied while blocking on event
1.7.10.4
