[PATCH 5/5] rtems: Simplify _Event_Surrender()
Wed Jan 2 17:56:38 UTC 2013
Check for a satisfied event condition only once.
 cpukit/rtems/src/eventsurrender.c |   42 +++++++++++++------------------------
 1 file changed, 14 insertions(+), 28 deletions(-)
diff --git a/cpukit/rtems/src/eventsurrender.c b/cpukit/rtems/src/eventsurrender.c
index 6e8dbbd..bfa29c4 100644
--- a/cpukit/rtems/src/eventsurrender.c
+++ b/cpukit/rtems/src/eventsurrender.c
@@ -48,24 +48,19 @@ void _Event_Surrender(
   seized_events = _Event_sets_Get( pending_events, event_condition );
-   *  No events were seized in this operation
-  if ( _Event_sets_Is_empty( seized_events ) ) {
-    _ISR_Enable( level );
-    return;
-   *  If we are sending to the executing thread, then we have a critical
-   *  section issue to deal with.  The entity sending to the executing thread
-   *  can be either the executing thread or an ISR.  In case it is the
-   *  executing thread, then the blocking operation state is not equal to
-   *  THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED.
-  if ( _Thread_Is_executing( the_thread ) &&
-       *sync_state == THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED ) {
-    if ( seized_events == event_condition || _Options_Is_any(option_set) ) {
+  if (
+    !_Event_sets_Is_empty( seized_events )
+      && ( seized_events == event_condition || _Options_Is_any( option_set ) )
+     *  If we are sending to the executing thread, then we have a critical
+     *  section issue to deal with.  The entity sending to the executing thread
+     *  can be either the executing thread or an ISR.  In case it is the
+     *  executing thread, then the blocking operation state is not equal to
+     *  THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED.
+    if ( _Thread_Is_executing( the_thread ) &&
+         *sync_state == THREAD_BLOCKING_OPERATION_NOTHING_HAPPENED ) {
       event->pending_events = _Event_sets_Clear(
         pending_events,
         seized_events
@@ -73,16 +68,7 @@ void _Event_Surrender(
       the_thread->Wait.count = 0;
       *(rtems_event_set *)the_thread->Wait.return_argument = seized_events;
       *sync_state = THREAD_BLOCKING_OPERATION_SATISFIED;
-    return;
-   *  Otherwise, this is a normal send to another thread
-  if ( _States_Are_set( the_thread->current_state, wait_state ) ) {
-    if ( seized_events == event_condition || _Options_Is_any( option_set ) ) {
+    } else if ( _States_Are_set( the_thread->current_state, wait_state ) ) {
         pending_events,
         seized_events
1.7.10.4
