[rtems commit] cpukit: Use Consistent Beginning of Doxygen Group Notation
Joel Sherrill
joel.sherrill at OARcorp.com
Fri Jan 11 15:00:43 UTC 2013
On 01/11/2013 07:49 AM, Sebastian Huber wrote:
> On 01/11/2013 12:02 AM, Joel Sherrill wrote:
>> diff --git a/cpukit/include/rtems/irq-extension.h b/cpukit/include/rtems/irq-extension.h
>> index 644091b..ff2c6da 100644
>> --- a/cpukit/include/rtems/irq-extension.h
>> +++ b/cpukit/include/rtems/irq-extension.h
>> @@ -38,9 +38,8 @@ extern "C" {
>> * In addition to the Classic API interrupt handler with a handle are
>> * supported. You can also install multiple shared handler for one interrupt
>> * vector.
>> * @brief Makes the interrupt handler unique. Prevents other handler from
> I think this change should be reversed. A single @{ without a preceding
> @defgroup or @addtogroup makes no sense. Thus is should be also part of the
> corresponding comment block.
The inclusion of the opening was inconsistent across the files.
I saw three patterns and wasn't sure there were not more:
* TEXT
* TEXT
I thought it got lost in the comment block and that the single
line by itself stood out more. Plus it matches the ending block
marker. Plus it is what is documented in the Doxygen manual
http://www.star.bnl.gov/public/comp/sofi/doxygen/grouping.html
FWIW the extern C, ending block and inclusion prevention
stuff at the bottom of the files is also very inconsistent
in precise formatting.
Joel Sherrill, Ph.D. Director of Research& Development
Ask me about RTEMS: a free RTOS Huntsville AL 35806
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130111/d5d8b4a5/attachment.html>
