[PATCH] score: Add and use rtems_assert_context
Sebastian Huber
Sun Jan 27 13:02:50 UTC 2013
cpukit/libcsupport/src/__assert.c | 9 ++++++++-
cpukit/sapi/include/rtems/fatal.h | 10 ++++++++++
cpukit/score/include/rtems/score/interr.h | 4 +++-
testsuites/sptests/spfatal10/testcase.h | 23 +++++++++++++++++++----
testsuites/sptests/spfatal_support/init.c | 13 ++++++++++++-
5 files changed, 52 insertions(+), 7 deletions(-)
diff --git a/cpukit/libcsupport/src/__assert.c b/cpukit/libcsupport/src/__assert.c
index be0fa6c..d29ea0b 100644
--- a/cpukit/libcsupport/src/__assert.c
+++ b/cpukit/libcsupport/src/__assert.c
@@ -34,6 +34,13 @@ void __assert_func(
const char *failedexpr
+ rtems_assert_context assert_context = {
+ .file = file,
+ .line = line,
+ .function = func,
+ .failed_expression = failedexpr
printk("assertion \"%s\" failed: file \"%s\", line %d%s%s\n",
failedexpr,
file,
@@ -41,7 +48,7 @@ void __assert_func(
(func) ? ", function: " : "",
(func) ? func : ""
- rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, (rtems_fatal_code) func );
+ rtems_fatal( RTEMS_FATAL_SOURCE_ASSERT, (rtems_fatal_code) &assert_context );
#endif
diff --git a/cpukit/sapi/include/rtems/fatal.h b/cpukit/sapi/include/rtems/fatal.h
index 6623646..47bf74f 100644
--- a/cpukit/sapi/include/rtems/fatal.h
+++ b/cpukit/sapi/include/rtems/fatal.h
@@ -34,6 +34,16 @@ extern "C" {
+ * @brief Assert context.
+typedef struct {
+ const char *file;
+ int line;
+ const char *function;
+ const char *failed_expression;
+} rtems_assert_context;
* @brief Exception frame.
typedef CPU_Exception_frame rtems_exception_frame;
diff --git a/cpukit/score/include/rtems/score/interr.h b/cpukit/score/include/rtems/score/interr.h
index 2580c72..a047ca6 100644
--- a/cpukit/score/include/rtems/score/interr.h
+++ b/cpukit/score/include/rtems/score/interr.h
@@ -88,7 +88,9 @@ typedef enum {
* @brief Fatal source of assert().
- * The fatal code is the pointer value of the function string.
+ * The fatal code is the pointer value of the assert context.
+ * @see rtems_assert_context.
diff --git a/testsuites/sptests/spfatal10/testcase.h b/testsuites/sptests/spfatal10/testcase.h
index 9af96d9..895a0c2 100644
--- a/testsuites/sptests/spfatal10/testcase.h
+++ b/testsuites/sptests/spfatal10/testcase.h
@@ -9,18 +9,33 @@
#include <assert.h>
-static const char func [] = "Init";
+#include <string.h>
#define FATAL_ERROR_TEST_NAME "10"
#define FATAL_ERROR_DESCRIPTION "asserting with non-NULL strings..."
#define FATAL_ERROR_EXPECTED_SOURCE RTEMS_FATAL_SOURCE_ASSERT
#define FATAL_ERROR_EXPECTED_IS_INTERNAL FALSE
-#define FATAL_ERROR_EXPECTED_ERROR ((rtems_fatal_code) func)
+#define FATAL_ERROR_EXPECTED_ERROR_CHECK spfatal10_is_expected_error
+#define ASSERT_FILE "testcase.h"
+#define ASSERT_LINE 38
+#define ASSERT_FUNC "Init"
+#define ASSERT_FEXP "forced"
+static inline bool spfatal10_is_expected_error( rtems_fatal_code error )
+ const rtems_assert_context *assert_context =
+ (const rtems_assert_context *) error;
+ return strcmp( assert_context->file, ASSERT_FILE ) == 0
+ && assert_context->line == ASSERT_LINE
+ && strcmp( assert_context->function, ASSERT_FUNC ) == 0
+ && strcmp( assert_context->failed_expression, ASSERT_FEXP ) == 0;
void force_error()
- __assert_func( __FILE__, __LINE__, func, "forced" );
+ __assert_func( ASSERT_FILE, ASSERT_LINE, ASSERT_FUNC, ASSERT_FEXP );
/* we will not run this far */
diff --git a/testsuites/sptests/spfatal_support/init.c b/testsuites/sptests/spfatal_support/init.c
index eb7a167..216c766 100644
--- a/testsuites/sptests/spfatal_support/init.c
+++ b/testsuites/sptests/spfatal_support/init.c
@@ -80,6 +80,15 @@ void Put_Source( rtems_fatal_source source )
printk( "%s", rtems_fatal_source_description( source ) );
+static bool is_expected_error( rtems_fatal_code error )
+#ifdef FATAL_ERROR_EXPECTED_ERROR
+ return error == FATAL_ERROR_EXPECTED_ERROR;
+#else /* FATAL_ERROR_EXPECTED_ERROR */
+ return FATAL_ERROR_EXPECTED_ERROR_CHECK( error );
+#endif /* FATAL_ERROR_EXPECTED_ERROR */
void Fatal_extension(
rtems_fatal_source source,
bool is_internal,
@@ -109,6 +118,7 @@ void Fatal_extension(
if ( error != FATAL_ERROR_EXPECTED_ERROR ) {
printk( "ERROR==> Fatal Error Expected (");
Put_Error( source, FATAL_ERROR_EXPECTED_ERROR );
@@ -116,11 +126,12 @@ void Fatal_extension(
Put_Error( source, error );
printk( ")\n" );
if (
source == FATAL_ERROR_EXPECTED_SOURCE
&& is_internal == FATAL_ERROR_EXPECTED_IS_INTERNAL
- && error == FATAL_ERROR_EXPECTED_ERROR
+ && is_expected_error( error )
printk( "*** END OF TEST FATAL " FATAL_ERROR_TEST_NAME " ***\n" );
1.7.10.4
