Deterministic Archives
Thu Jan 31 09:44:06 UTC 2013
Hello,
the GNU AR program as a 'D' option
(http://sourceware.org/binutils/docs-2.23.1/binutils/ar-cmdline.html#ar-cmdline):
`D'
     Operate in deterministic mode. When adding files and the archive index use
zero for UIDs, GIDs, timestamps, and use consistent file modes for all files.
When this option is used, if ar is used with identical options and identical
input files, multiple runs will create identical output files regardless of the
input files' owners, groups, file modes, or modification times.
     If binutils was configured with --enable-deterministic-archives, then this
mode is on by default. It can be disabled with the `U' modifier, below.
We should consider to add this configure option to the standard tool chain
build.  This helps to avoid artificial differences in library files.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
