Deterministic Archives
Ralf Corsepius ralf.corsepius at rtems.org
Thu Jan 31 11:58:55 UTC 2013
On 01/31/2013 10:44 AM, Sebastian Huber wrote:
> Hello,
> the GNU AR program as a 'D' option
> (http://sourceware.org/binutils/docs-2.23.1/binutils/ar-cmdline.html#ar-cmdline):
> `D'
>      Operate in deterministic mode. When adding files and the archive
> index use zero for UIDs, GIDs, timestamps, and use consistent file modes
> for all files. When this option is used, if ar is used with identical
> options and identical input files, multiple runs will create identical
> output files regardless of the input files' owners, groups, file modes,
> or modification times.
>      If binutils was configured with --enable-deterministic-archives,
> then this mode is on by default. It can be disabled with the `U'
> modifier, below.
> We should consider to add this configure option to the standard tool
> chain build.  This helps to avoid artificial differences in library files.
If you're serously interested in this, bring this to the attention of
upstream binutils, newlib, GCC and automake and have all these tools
changed.
I for one do not see much sense in this (All it does it to add
complexity and non-portability) and therefore am opposed to doing this.
Ralf
