Thread-Local Storage, C++ Support and SMP
Gedare Bloom
gedare at gwmail.gwu.edu
Fri Jul 5 01:10:44 UTC 2013
Sebastian,
I have been working with the student to get the keys code mergeable. We
have one last problem which maybe we can fix later. We need a generic
freelist implementation for some unlimited mode allocations. This is a
boundary case and can be ignored for now. I will push for code we can merge
soon. It should fix #3 (not sure if cancellation was tested) and 4, and #5
when we get freelist merged. The code all exists just needs review, fix,
and merge.
-Gedare
On Jul 4, 2013 3:27 AM, "Sebastian Huber" <
> Hello,
> we added support for thread-local storage on PowerPC for C11 and GCC
> __thread. The work on C++11 support revealed a couple of problems.
> 1. The general C++ support code is not SMP safe. It uses task variables
> and disables preemption to ensure mutual exclusion.
> 2. The implementation of thread keys in the C++ support is not standard
> conform. The destructors must be called during thread exit and
> cancellation.
> 3. The implementation of POSIX keys is not standard conform. The
> destructors must be called during thread exit and cancellation.
> 4. The workspace estimate for POSIX keys is wrong. It depends on the
> maximum thread count in the system times the maximum key count.
> 5. The POSIX keys are broken if someone uses unlimited thread objects.
> To address the C++ problems we propose:
> 1. Move the POSIX keys to the Classic API.
> 2. Implement the POSIX keys with the red-black tree instead of the fixed
> table lookup.
> 3. Fix the configuration issues.
> There was a GSoC project in 2012 for this which addressed parts of the
> above issues. Where can I find the latest status of this project?
> Phone : +49 89 189 47 41-16
> Fax : +49 89 189 47 41-09
> E-Mail : sebastian.huber at embedded-**brains.de<sebastian.huber at embedded-brains.de>
> ______________________________**_________________
> rtems-devel mailing list
> rtems-devel at rtems.org
> http://www.rtems.org/mailman/**listinfo/rtems-devel<http://www.rtems.org/mailman/listinfo/rtems-devel>
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130704/719b922a/attachment.html>
