[Patch] make/main.cfg: Allow application source subdirectories
Nick Withers nick.withers at anu.edu.au
Fri Jul 5 01:59:19 UTC 2013
Hi guys,
The following patch to make/main.cfg in rtems.git (generated with git
diff) allows me to have an application subdirectory with sources (not a
Makefile; e.g., I can define "SRCS=boom.c bam/baby.c"):
____
diff --git a/make/main.cfg b/make/main.cfg
index 1a712de..e9219b4 100644
--- a/make/main.cfg
+++ b/make/main.cfg
@@ -40,8 +40,15 @@ ARCH_DEBUG_V = o-debug
 ARCH__V = $(ARCH_OPTIMIZE_V)
 ARCH = $(ARCH_$(VARIANT_V)_V)
+ARCH_DIRS = $(filter-out ./, $(dir $(C_FILES)))
 $(ARCH):
        test -d ${ARCH} || mkdir $(ARCH)
+ifneq ($(strip ARCH_DIRS),)
+       mkdir -p ${ARCH_DIRS:%=${ARCH}/%}
+endif
 # Default makefile name
 # May be overridden by command line macro assignment
____
Without that, the linking stage fails because "$(ARCH)/bam" doesn't
exist for GCC to output "baby.o" into
Dunno that it's the most elegant way of doing it though :-P
Would it be possible to merge this (or similar) in for 4.11?
Ta!
Nick Withers
Embedded Systems Programmer
Room 2.26, Building 57
Department of Nuclear Physics
Research School of Physics and Engineering
The Australian National University (CRICOS: 00120C)
eMail: nick.withers at anu.edu.au
Phone: +61 2 6125 2091
Mobile: +61 414 397 446
