SMP/MMU updating page tables on realview BSP
    Joel Sherrill
    Joel.Sherrill at OARcorp.com
    Fri Jul  5 16:24:28 UTC 2013
There is a feature called thread affinity which can be used to specify the set of one it more cores a thread can run on. This is not implemented but I'd in the hoped for near term wish list.
Hesham Moustafa <heshamelmatary at gmail.com> wrote:
Hi,
I am working on a use case for cortex-a9/realview BSP that deals with page tables and MMU. I need your help in gathering the required API and calls and any other details to implement the following case (if applicable) :
1- A thread running on a core that updates the page table.
2- On another core another thread is running and trying to update the page table.
Is that use case possible, or disabling dispatches, MMU, and interrupts avoids that situation ?
Is it possible to force a thread to run on a specific core ? or the current SMP scheduler handles that ?
I am thinking of applying a SHARED_MEMORY attribute on page tables itself and implement the mentioned use case.
Regards,
Hesham
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130705/532936e3/attachment.html>
