[Patch] Removing legacy method from arm csb336
Vipul Nayyar
nayyar_vipul at yahoo.com
Sun Jul 7 11:33:34 UTC 2013
Hello,
Worked again on csb336 patch. Following points I've kept in mind while doing this :
1) Update legacy install and remove methods to the new generic ones
2)Removed all uses of tems_irq_connect_data type
3) Inserted protoypes for functions which didn't had one
4) Made functions static that are only used in that file
Hoping to get reviews, so that I can move on with other BSPs.
commit e22d51a1f9d2efeba77e97ff0c81a9a5800af20c
Author: Vipul Nayyar <nayyar_vipul at yahoo.com>
Date: Sun Jul 7 16:51:07 2013 +0530
Updated Legacy code in arm csb336
diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
index 4dc409b..96126fa 100644
--- a/c/src/lib/libbsp/arm/csb336/console/uart.c
+++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
@@ -13,6 +13,7 @@
#include <libchip/sersupp.h>
#include <rtems/error.h>
#include <rtems/bspIo.h>
+#include <assert.h>
#include <termios.h>
#include <rtems/irq.h>
#include <bsp/irq.h>
@@ -34,13 +35,17 @@ static int imx_uart_set_attrs(int, const struct termios *);
static void imx_uart_init(int minor);
static void imx_uart_set_baud(int, int);
static ssize_t imx_uart_poll_write(int, const char *, size_t);
+static int imx_uart_poll_read_char(int minor);
+static void imx_uart_poll_write_char(int minor, char c);
+static void _BSP_output_char(char c);
+static int _BSP_poll_char(void);
#if defined(USE_INTERRUPTS)
static void imx_uart_tx_isr(rtems_irq_hdl_param);
static void imx_uart_rx_isr(rtems_irq_hdl_param);
-static void imx_uart_isr_on(const rtems_irq_connect_data *irq);
-static void imx_uart_isr_off(const rtems_irq_connect_data *irq);
-static int imx_uart_isr_is_on(const rtems_irq_connect_data *irq);
+static void imx_uart_isr_on(const rtems_irq_number);
+static void imx_uart_isr_off(const rtems_irq_number);
static ssize_t imx_uart_intr_write(int, const char *, size_t);
#endif
@@ -71,11 +76,6 @@ rtems_termios_callbacks imx_uart_cbacks = {
#endif
-#if defined(USE_INTERRUPTS)
-static rtems_irq_connect_data imx_uart_tx_isr_data[NUM_DEVS];
-static rtems_irq_connect_data imx_uart_rx_isr_data[NUM_DEVS];
-#endif
typedef struct {
int minor;
mc9328mxl_uart_regs_t * regs;
@@ -184,17 +184,9 @@ static void imx_uart_init(int minor)
imx_uart_data[minor].idx = 0;
if (minor == 0) {
- imx_uart_tx_isr_data[minor].name = BSP_INT_UART1_TX;
- imx_uart_rx_isr_data[minor].name = BSP_INT_UART1_RX;
-#endif
imx_uart_data[minor].regs =
(mc9328mxl_uart_regs_t *) MC9328MXL_UART1_BASE;
} else if (minor == 1) {
- imx_uart_tx_isr_data[minor].name = BSP_INT_UART2_TX;
- imx_uart_rx_isr_data[minor].name = BSP_INT_UART2_RX;
-#endif
(mc9328mxl_uart_regs_t *) MC9328MXL_UART2_BASE;
} else {
@@ -202,20 +194,6 @@ static void imx_uart_init(int minor)
__FUNCTION__, __LINE__, minor);
- imx_uart_tx_isr_data[minor].hdl = imx_uart_tx_isr;
- imx_uart_tx_isr_data[minor].handle = &imx_uart_data[minor];
- imx_uart_tx_isr_data[minor].on = imx_uart_isr_on;
- imx_uart_tx_isr_data[minor].off = imx_uart_isr_off;
- imx_uart_tx_isr_data[minor].isOn = imx_uart_isr_is_on;
- imx_uart_rx_isr_data[minor].hdl = imx_uart_rx_isr;
- imx_uart_rx_isr_data[minor].handle = &imx_uart_data[minor];
- imx_uart_rx_isr_data[minor].on = imx_uart_isr_on;
- imx_uart_rx_isr_data[minor].off = imx_uart_isr_off;
- imx_uart_rx_isr_data[minor].isOn = imx_uart_isr_is_on;
-#endif
imx_uart_data[minor].regs->cr1 = (
MC9328MXL_UART_CR1_UARTCLKEN |
MC9328MXL_UART_CR1_UARTEN);
@@ -243,13 +221,43 @@ static void imx_uart_init(int minor)
static int imx_uart_first_open(int major, int minor, void *arg)
rtems_libio_open_close_args_t *args = arg;
+ rtems_status_code status = RTEMS_SUCCESSFUL;
+ rtems_irq_number name_uart_tx, name_uart_rx;
imx_uart_data[minor].tty = args->iop->data1;
- BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
- BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+ if (minor == 0) {
+ name_uart_tx = BSP_INT_UART1_TX;
+ name_uart_rx = BSP_INT_UART1_RX;
+ } else if (minor == 1) {
+ name_uart_tx = BSP_INT_UART2_TX;
+ name_uart_rx = BSP_INT_UART2_RX;
+ } else {
+ rtems_panic("%s:%d Unknown UART minor number %d\n",
+ __FUNCTION__, __LINE__, minor);
+#if defined(USE_INTERRUPTS)
+ status = rtems_interrupt_handler_install(
+ name_uart_tx,
+ "Network",
+ RTEMS_INTERRUPT_UNIQUE,
+ imx_uart_tx_isr,
+ &imx_uart_data[minor]
+ assert(status == RTEMS_SUCCESSFUL);
+ imx_uart_isr_on(name_uart_tx);
+ name_uart_rx,
+ "Network",
+ imx_uart_rx_isr,
+ imx_uart_isr_on(name_uart_rx);
imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
#endif
@@ -258,9 +266,35 @@ static int imx_uart_first_open(int major, int minor, void *arg)
static int imx_uart_last_close(int major, int minor, void *arg)
+ if (minor == 0) {
+ } else {
- BSP_remove_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
- BSP_remove_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
+ imx_uart_isr_off(name_uart_tx);
+ status = rtems_interrupt_handler_remove(
+ name_uart_tx,
+ imx_uart_tx_isr,
+ imx_uart_isr_off(name_uart_rx);
+ name_uart_rx,
+ imx_uart_rx_isr,
#endif
return 0;
@@ -317,22 +351,13 @@ static int imx_uart_set_attrs(int minor, const struct termios *t)
+static void imx_uart_isr_on(const rtems_irq_number name)
- MC9328MXL_AITC_INTENNUM = irq->name;
+ MC9328MXL_AITC_INTENNUM = name;
+static void imx_uart_isr_off(const rtems_irq_number name)
- MC9328MXL_AITC_INTDISNUM = irq->name;
- int irq_num = (int)irq->name;
- if (irq_num < 32) {
- return MC9328MXL_AITC_INTENABLEL & (1 << irq_num);
- } else {
- return MC9328MXL_AITC_INTENABLEH & (1 << (irq_num - 32));
+ MC9328MXL_AITC_INTDISNUM = name;
static void imx_uart_rx_isr(rtems_irq_hdl_param param)
@@ -417,7 +442,7 @@ static void imx_uart_set_baud(int minor, int baud)
* Polled, non-blocking read from UART
-int imx_uart_poll_read_char(int minor)
return imx_uart_poll_read(minor);
@@ -425,7 +450,7 @@ int imx_uart_poll_read_char(int minor)
* Polled, blocking write from UART
-void imx_uart_poll_write_char(int minor, char c)
imx_uart_poll_write(minor, &c, 1);
@@ -433,7 +458,7 @@ void imx_uart_poll_write_char(int minor, char c)
* Functions for printk() and friends.
-void _BSP_output_char(char c)
poll_write(c);
if (c == '\n') {
@@ -443,7 +468,7 @@ void _BSP_output_char(char c)
BSP_output_char_function_type BSP_output_char = _BSP_output_char;
-int _BSP_poll_char(void)
return poll_read();
diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c b/c/src/lib/libbsp/arm/csb336/network/network.c
index e513595..1367a8f 100644
--- a/c/src/lib/libbsp/arm/csb336/network/network.c
+++ b/c/src/lib/libbsp/arm/csb336/network/network.c
@@ -19,6 +19,7 @@
#include <sys/param.h>
#include <sys/mbuf.h>
@@ -39,19 +40,8 @@
#define START_TRANSMIT_EVENT RTEMS_EVENT_2
static void enet_isr(rtems_irq_hdl_param);
-static void enet_isr_on(const rtems_irq_connect_data *unused);
-static void enet_isr_off(const rtems_irq_connect_data *unused);
-static int enet_isr_is_on(const rtems_irq_connect_data *irq);
-/* Replace the first value with the clock's interrupt name. */
-rtems_irq_connect_data mc9328mxl_enet_isr_data = {
- .name = BSP_INT_GPIO_PORTA,
- .hdl = enet_isr,
- .handle = (void *)BSP_INT_GPIO_PORTA,
- .on = enet_isr_on,
- .off = enet_isr_off,
- .isOn = enet_isr_is_on,
+static void enet_isr_on(void);
typedef struct {
unsigned long rx_packets; /* total packets received */
unsigned long tx_packets; /* total packets transmitted */
@@ -238,6 +228,7 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
uint16_t stat;
uint16_t my = 0;
lan91c11x_write_reg(LAN91C11X_RCR, LAN91C11X_RCR_RST);
lan91c11x_write_reg(LAN91C11X_RCR, 0);
@@ -334,7 +325,15 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
MC9328MXL_GPIOA_IMR |= bit(3);
/* Install the interrupt handler */
- BSP_install_rtems_irq_handler(&mc9328mxl_enet_isr_data);
+ BSP_INT_GPIO_PORTA,
+ "Network",
+ enet_isr,
+ (void *)BSP_INT_GPIO_PORTA
+ enet_isr_on();
} /* mc9328mxl_enet_init_hw() */
@@ -602,7 +601,7 @@ void mc9328mxl_enet_stats (mc9328mxl_enet_softc_t *sc)
/* Enables mc9328mxl_enet interrupts. */
+static void enet_isr_on()
/* Enable interrupts */
MC9328MXL_AITC_INTENNUM = MC9328MXL_INT_GPIO_PORTA;
@@ -610,23 +609,6 @@ static void enet_isr_on(const rtems_irq_connect_data *unused)
return;
-/* Disables enet interrupts */
- /* disable all various TX/RX interrupts */
- MC9328MXL_AITC_INTDISNUM = MC9328MXL_INT_GPIO_PORTA;
- return;
-/* Tests to see if mc9328mxl_enet interrupts are enabled, and returns non-0 if so.
- * If interrupt is not enabled, returns 0.
- return MC9328MXL_AITC_INTENABLEL & (1 << MC9328MXL_INT_GPIO_PORTA);
/* Driver ioctl handler */
static int
mc9328mxl_enet_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
Regards
Vipul Nayyar
________________________________
To: Joel Sherrill <Joel.Sherrill at oarcorp.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Sunday, 30 June 2013 4:17 PM
Subject: Re: [Patch] Removing legacy method from arm csb336
Hello,
Trying once gain with the arm csb336 patch. I'm explicitly checking the status code returned now, but am I doing the right thing if the status code returned is not RTEMS_SUCCESSFUL ? For now I'm doing the same what happens in BSP_install_rtems_irq_handler & BSP_remove_rtems_irq_handler ?
commit 1887514fd17d17c089c4305f34963c244324eba3
Date: Sun Jun 30 16:08:43 2013 +0530
index 4dc409b..758f103 100644
@@ -246,9 +246,36 @@ static int imx_uart_first_open(int major, int minor, void *arg)
+ rtems_status_code sc = RTEMS_SUCCESSFUL;
+ sc = rtems_interrupt_handler_install(
+ imx_uart_tx_isr_data[minor].name,
+ "Console",
+ imx_uart_tx_isr_data[minor].hdl,
+ imx_uart_tx_isr_data[minor].handle
+ if (sc != RTEMS_SUCCESSFUL) {
+ return 0;
+ if (imx_uart_tx_isr_data[minor].on != NULL) {
+ imx_uart_tx_isr_data[minor].on(&imx_uart_tx_isr_data[minor]);
+ imx_uart_rx_isr_data[minor].name,
+ "Console",
+ imx_uart_rx_isr_data[minor].hdl,
+ imx_uart_rx_isr_data[minor].handle
+ return 0;
+ if (imx_uart_rx_isr_data[minor].on != NULL) {
+ imx_uart_rx_isr_data[minor].on(&imx_uart_rx_isr_data[minor]);
#endif
@@ -258,9 +285,32 @@ static int imx_uart_first_open(int major, int minor, void *arg)
+ if (imx_uart_tx_isr_data[minor].off != NULL) {
+ imx_uart_tx_isr_data[minor].off(&imx_uart_tx_isr_data[minor]);
+ sc = rtems_interrupt_handler_remove(
+ return 0;
+ if (imx_uart_rx_isr_data[minor].off != NULL) {
+ imx_uart_rx_isr_data[minor].off(&imx_uart_rx_isr_data[minor]);
+ return 0;
#endif
return 0;
index e513595..2441c01 100644
@@ -238,6 +238,7 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
uint16_t stat;
uint16_t my = 0;
@@ -334,7 +335,19 @@ void mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
+ mc9328mxl_enet_isr_data.name,
+ "Network",
+ mc9328mxl_enet_isr_data.hdl,
+ mc9328mxl_enet_isr_data.handle
+ return 0;
+ if (mc9328mxl_enet_isr_data.on != NULL) {
+ mc9328mxl_enet_isr_data.on(&mc9328mxl_enet_isr_data);
Regards
Vipul Nayyar
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>; Sebastian Huber <sebastian.huber at embedded-brains.de>; "gedare at rtems.org" <gedare at rtems.org>
Sent: Sunday, 30 June 2013 2:04 AM
Please return the status code into a variable and test it separately in the assert. I will defer to Sebastian on whether assert should be used. I tend to think it should be a fatal error call with an explicit test. Using assert increases the code size. Plus this first one gives you a pattern for the rest.
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130707/d568942e/attachment.html>
