[PATCH 1/5] New atomic API definition based on C11 atomic
WeiY
wei.a.yang at gmail.com
Sun Jul 7 15:52:09 UTC 2013
Signed-off-by: WeiY <wei.a.yang at gmail.com>
cpukit/score/include/rtems/score/atomic.h | 465 ++++++++++++++++-------------
1 file changed, 251 insertions(+), 214 deletions(-)
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index 3b62cb1..3378564 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -8,7 +8,7 @@
- * COPYRIGHT (c) 2012 Deng Hengyi.
+ * COPYRIGHT (c) 2013 Deng Hengyi.
* The license and distribution terms for this file may be
* found in the file LICENSE in this distribution or at
@@ -32,241 +32,278 @@ extern "C" {
- * @brief the enumeration Atomic_Memory_barrier specifies the detailed regular
- * memory synchronization operations used in the atomic operation API
- * definitions.
+ * @brief Atomically load an atomic type value from object @a object with
+ * a type of Atomic_Order @a order. The @a order shall not be
+ * ATOMIC_ORDER_RELEASE.
-typedef enum {
- /** no operation orders memory. */
- ATOMIC_RELAXED_BARRIER,
- /** a load operation performs an acquire operation on the affected memory
- * location. This flag guarantees that the effects of load operation are
- * completed before the effects of any later data accesses.
- ATOMIC_ACQUIRE_BARRIER,
- /** a store operation performs a release operation on the affected memory
- * location. This flag guarantee that all effects of all previous data
- * accesses are completed before the store operation takes place.
- ATOMIC_RELEASE_BARRIER
-} Atomic_Memory_barrier;
+RTEMS_INLINE_ROUTINE uint_fast32_t Atomic_Load_uint(
+ volatile Atomic_Uint *object,
+ Atomic_Order order
+ return _CPU_Atomic_Load_uint(object, order);
+RTEMS_INLINE_ROUTINE uintptr_t Atomic_Load_ptr(
+ volatile Atomic_Pointer *object,
+ return _CPU_Atomic_Load_ptr(object, order);
+RTEMS_INLINE_ROUTINE bool Atomic_Load_flag(
+ volatile Atomic_Flag *object,
+ return _CPU_Atomic_Load_flag(object, order);
- * @brief Atomically load an atomic type value from address @a address with
- * a type of Atomic_Memory_barrier @a memory_barrier. The @a memory_barrier
- * shall not be ATOMIC_RELEASE_BARRIER.
+ * @brief Atomically store an atomic type value @a value into object @a
+ * object with a type of Atomic_Order @a order. The @a
+ * order shall not be ATOMIC_ORDER_ACQUIRE.
-RTEMS_INLINE_ROUTINE Atomic_Int _Atomic_Load_int(
- volatile Atomic_Int *address,
- Atomic_Memory_barrier memory_barrier
-RTEMS_INLINE_ROUTINE Atomic_Long _Atomic_Load_long(
- volatile Atomic_Long *address,
-RTEMS_INLINE_ROUTINE Atomic_Pointer _Atomic_Load_ptr(
- volatile Atomic_Pointer *address,
-RTEMS_INLINE_ROUTINE Atomic_Int32 _Atomic_Load_32(
- volatile Atomic_Int32 *address,
-RTEMS_INLINE_ROUTINE Atomic_Int64 _Atomic_Load_64(
- volatile Atomic_Int64 *address,
+RTEMS_INLINE_ROUTINE void Atomic_Store_uint(
+ uint_fast32_t value,
+ _CPU_Atomic_Store_uint(object, value, order);
+RTEMS_INLINE_ROUTINE void Atomic_Store_ptr(
+ uintptr_t value,
+ _CPU_Atomic_Store_ptr(object, value, order);
+RTEMS_INLINE_ROUTINE void Atomic_Store_flag(
+ bool value,
+ _CPU_Atomic_Store_flag(object, value, order);
- * @brief Atomically store an atomic type value @a value into address @a
- * address with a type of Atomic_Memory_barrier @a memory_barrier. The @a
- * memory_barrier shall not be ATOMIC_ACQUIRE_BARRIER.
+ * @brief Atomically load-add-store an atomic type value @a value into object
+ * @a object with a type of Atomic_Order @a order. Return the value of @a object
+ * before atomic operation.
-RTEMS_INLINE_ROUTINE void _Atomic_Store_int(
- Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_long(
- Atomic_Long value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_ptr(
- Atomic_Pointer value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_32(
- Atomic_Int32 value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_64(
- Atomic_Int64 value,
+RTEMS_INLINE_ROUTINE uint_fast32_t Atomic_Fetch_add_uint(
+ return _CPU_Atomic_Fetch_add_uint(object, value, order);
+RTEMS_INLINE_ROUTINE uintptr_t Atomic_Fetch_add_ptr(
+ uintptr_t value,
+ return _CPU_Atomic_Fetch_add_ptr(object, value, order);
+RTEMS_INLINE_ROUTINE bool Atomic_Fetch_add_flag(
+ bool value,
+ return _CPU_Atomic_Fetch_add_flag(object, value, order);
- * @brief Atomically load-add-store an atomic type value @a value into address
- * @a address with a type of Atomic_Memory_barrier @a memory_barrier.
+ * @brief Atomically load-sub-store an atomic type value @a value into object
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_int(
- Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_64(
+RTEMS_INLINE_ROUTINE uint_fast32_t Atomic_Fetch_sub_uint(
+ return _CPU_Atomic_Fetch_sub_uint(object, value, order);
+RTEMS_INLINE_ROUTINE uintptr_t Atomic_Fetch_sub_ptr(
+ uintptr_t value,
+ return _CPU_Atomic_Fetch_sub_ptr(object, value, order);
+RTEMS_INLINE_ROUTINE bool Atomic_Fetch_sub_flag(
+ bool value,
+ return _CPU_Atomic_Fetch_sub_flag(object, value, order);
- * @brief Atomically load-sub-store an atomic type value @a value into address
+ * @brief Atomically load-or-store an atomic type value @a value into object
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_int(
- Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_64(
+RTEMS_INLINE_ROUTINE uint_fast32_t Atomic_Fetch_or_uint(
+ return _CPU_Atomic_Fetch_or_uint(object, value, order);
+RTEMS_INLINE_ROUTINE uintptr_t Atomic_Fetch_or_ptr(
+ uintptr_t value,
+ return _CPU_Atomic_Fetch_or_ptr(object, value, order);
+RTEMS_INLINE_ROUTINE bool Atomic_Fetch_or_flag(
+ bool value,
+ return _CPU_Atomic_Fetch_or_flag(object, value, order);
- * @brief Atomically load-or-store an atomic type value @a value into address
+ * @brief Atomically load-and-store an atomic type value @a value into object
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_int(
- Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_64(
+ RTEMS_INLINE_ROUTINE uint_fast32_t Atomic_Fetch_and_uint(
+ return _CPU_Atomic_Fetch_and_uint(object, value, order);
+RTEMS_INLINE_ROUTINE uintptr_t Atomic_Fetch_and_ptr(
+ uintptr_t value,
+ return _CPU_Atomic_Fetch_and_ptr(object, value, order);
+RTEMS_INLINE_ROUTINE bool Atomic_Fetch_and_flag(
+ bool value,
+ return _CPU_Atomic_Fetch_and_flag(object, value, order);
- * @brief Atomically load-and-store an atomic type value @a value into address
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_int(
- Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_64(
+* @brief Atomically exchange the value of @a
+* object with @a value. Returns the value before exchange.
+* The operation uses a type of Atomic_Order @a order.
+RTEMS_INLINE_ROUTINE uint_fast32_t Atomic_Exchange_uint(
+ return _CPU_Atomic_Exchange_uint(object, value, order);
+RTEMS_INLINE_ROUTINE uintptr_t Atomic_Exchange_ptr(
+ uintptr_t value,
+ return _CPU_Atomic_Exchange_ptr(object, value, order);
+RTEMS_INLINE_ROUTINE bool Atomic_Exchange_flag(
+ bool value,
+ return _CPU_Atomic_Exchange_flag(object, value, order);
- * @brief Atomically compare the value stored at @a address with @a
- * old_value and if the two values are equal, update the value of @a
- * address with @a new_value. Returns zero if the compare failed,
- * nonzero otherwise. The operation uses a type of Atomic_Memory_barrier
- * @a memory_barrier.
+ * @brief Atomically compare the value stored at @a object with @a
+ * old_value and if the two values are equal, update the value of @a
+ * address with @a new_value. Returns zero if the compare failed,
+ * nonzero otherwise. The operation uses a type of Atomic_Order
+ * @a order_succ for successful order and a type of Atomic_Order
+ * @a order_fail for failled order.
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_int(
- Atomic_Int old_value,
- Atomic_Int new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_long(
- Atomic_Long old_value,
- Atomic_Long new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_ptr(
- Atomic_Pointer old_value,
- Atomic_Pointer new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_32(
- Atomic_Int32 old_value,
- Atomic_Int32 new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_64(
- Atomic_Int64 old_value,
- Atomic_Int64 new_value,
+RTEMS_INLINE_ROUTINE bool Atomic_Compare_exchange_uint(
+ uint_fast32_t *old_value,
+ uint_fast32_t new_value,
+ Atomic_Order order_succ,
+ Atomic_Order order_fail
+ return _CPU_Atomic_Compare_exchange_uint(object, old_value, new_value,
+ order_succ, order_fail);
+RTEMS_INLINE_ROUTINE bool Atomic_Compare_exchange_ptr(
+ uintptr_t *old_value,
+ uintptr_t new_value,
+ return _CPU_Atomic_Compare_exchange_ptr(object, old_value, new_value,
+RTEMS_INLINE_ROUTINE bool Atomic_Compare_exchange_flag(
+ bool *old_value,
+ bool new_value,
+ return _CPU_Atomic_Compare_exchange_flag(object, old_value, new_value,
-#include <rtems/score/atomic.inl>
+* @brief Atomically clear the value of an atomic flag type object @a
+* with a type of Atomic_Order @a order.
+RTEMS_INLINE_ROUTINE void Atomic_Clear_flag(
+ _CPU_Atomic_Clear_flag(object, order);
+* @brief Atomically test and clear the value of an atomic flag type
+* object @a with a type of Atomic_Order @a order.
+* if it is successful it will reture ture otherwise false.
+RTEMS_INLINE_ROUTINE bool Atomic_Test_set_flag(
+ return _CPU_Atomic_Test_set_flag(object, order);
#ifdef __cplusplus
1.7.9.5
