[PATCH] Removing legacy method from arm csb336
Vipul Nayyar
nayyar_vipul at yahoo.com
Sun Jul 7 17:00:20 UTC 2013
Hello,
The patch I submitted through git send-email is updated. Have a look.
1)I've tried to minimize the empty lines.
2) The variables used are defined only if USE_INTERRUPTS is defined. Hence There are no warnings in both cases when USE_INTERRUPTS is defined or not.
3)I've used the same pattern to check the value of minor. Can you explain why you feel this is not right ?
Regards
Vipul Nayyar
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130708/0721be05/attachment.html>
