[PATCH] Updated Legacy code in arm csb336
Vipul Nayyar
nayyar_vipul at yahoo.com
Mon Jul 8 16:21:50 UTC 2013
Hello,
Will use rtems_vector_number,an enum for uart_name and assert(0), or assert(!"Message describing error due to invalid value of minor or uart_name"). How do I use two functions ? I don't understand which part of code do you refer by receive and transmit interrupt.
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: rtems-devel at rtems.org
Sent: Monday, 8 July 2013 8:39 PM
Subject: Re: [PATCH] Updated Legacy code in arm csb336
On 07/08/2013 03:43 PM, Vipul Nayyar wrote:
> c/src/lib/libbsp/arm/csb336/console/uart.c | 128 +++++++++++++++-----------
> c/src/lib/libbsp/arm/csb336/network/network.c | 46 +++------
> 2 files changed, 86 insertions(+), 88 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
> index 4dc409b..8156921 100644
> --- a/c/src/lib/libbsp/arm/csb336/console/uart.c
> +++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
> /* Define this to use interrupt driver UART driver */
> #define USE_INTERRUPTS 1
> +#define UART_TX 1
> +#define UART_RX 2
> static ssize_t imx_uart_intr_write(int, const char *, size_t);
> +static rtems_irq_number imx_uart_set_name(int,int);
This rtems_irq_number is defined in <rtems/irq.h>. This it belongs to the legacy API we want to get rid of. Use rtems_vector_number instead.
> +static rtems_irq_number imx_uart_set_name(int minor,int uart_name)
> + if (minor == 0) {
> + if (uart_name == UART_TX) return BSP_INT_UART1_TX;
> + else if (uart_name == UART_RX)return BSP_INT_UART1_RX;
> + } else if (minor == 1) {
> + if (uart_name == UART_TX) return BSP_INT_UART2_TX;
> + else if (uart_name == UART_RX) return BSP_INT_UART2_RX;
> + rtems_panic("%s:%d Unknown UART minor number %d\n",
> + __FUNCTION__, __LINE__, minor);
This function is better than the previous copy and paste approach.
If I naively read imx_uart_set_name() I think this function sets the name of the UART. Instead this function returns an interrupt vector depending on a magic number uart_name.
I would use two functions for this, one for the receive and one for the transmit interrupt or use at least an enum instead of the int uart_name. Since we already use assert(), you can replace the rtems_panic() (which is a very heavy weight function) with an assert(0).
-- Sebastian Huber, embedded brains GmbH
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
rtems-devel mailing list
http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130709/c855adfd/attachment.html>
