[PATCH] Updated Legacy code in arm csb336
Mon Jul 8 17:09:14 UTC 2013
I think you addressed Sebastian's comments.
Sebastian .. anything else?
Vipul.. I hope you are keeping notes. They will get easier
and easier. :)
--joel
On 7/8/2013 12:05 PM, Vipul Nayyar wrote:
>   c/src/lib/libbsp/arm/csb336/console/uart.c    | 134 +++++++++++++++-----------
>   c/src/lib/libbsp/arm/csb336/network/network.c |  46 +++------
>   2 files changed, 92 insertions(+), 88 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/csb336/console/uart.c b/c/src/lib/libbsp/arm/csb336/console/uart.c
> index 4dc409b..d1b4e72 100644
> --- a/c/src/lib/libbsp/arm/csb336/console/uart.c
> +++ b/c/src/lib/libbsp/arm/csb336/console/uart.c
> @@ -13,12 +13,12 @@
>   #include <libchip/sersupp.h>
>   #include <rtems/error.h>
>   #include <rtems/bspIo.h>
> +#include <assert.h>
>   #include <termios.h>
>   #include <rtems/irq.h>
>   #include <bsp/irq.h>
>   #include <mc9328mxl.h>
>   /* Define this to use interrupt driver UART driver */
>   #define USE_INTERRUPTS 1
> @@ -34,18 +34,21 @@ static int imx_uart_set_attrs(int, const struct termios *);
>   static void imx_uart_init(int minor);
>   static void imx_uart_set_baud(int, int);
>   static ssize_t imx_uart_poll_write(int, const char *, size_t);
> +static int imx_uart_poll_read_char(int minor);
> +static void imx_uart_poll_write_char(int minor, char c);
> +static void _BSP_output_char(char c);
> +static int _BSP_poll_char(void);
>   #if defined(USE_INTERRUPTS)
>   static void imx_uart_tx_isr(rtems_irq_hdl_param);
>   static void imx_uart_rx_isr(rtems_irq_hdl_param);
> -static void imx_uart_isr_on(const rtems_irq_connect_data *irq);
> -static void imx_uart_isr_off(const rtems_irq_connect_data *irq);
> -static int imx_uart_isr_is_on(const rtems_irq_connect_data *irq);
> +static void imx_uart_isr_on(const rtems_irq_number);
> +static void imx_uart_isr_off(const rtems_irq_number);
>   static ssize_t imx_uart_intr_write(int, const char *, size_t);
> +static rtems_vector_number imx_uart_name_transmit(int minor);
> +static rtems_vector_number imx_uart_name_receive(int minor);
>   #endif
>   /* TERMIOS callbacks */
>   rtems_termios_callbacks imx_uart_cbacks = {
> @@ -71,11 +74,6 @@ rtems_termios_callbacks imx_uart_cbacks = {
>   #endif
> -#if defined(USE_INTERRUPTS)
> -static rtems_irq_connect_data imx_uart_tx_isr_data[NUM_DEVS];
> -static rtems_irq_connect_data imx_uart_rx_isr_data[NUM_DEVS];
> -#endif
>   typedef struct {
>       int minor;
>       mc9328mxl_uart_regs_t * regs;
> @@ -184,17 +182,9 @@ static void imx_uart_init(int minor)
>       imx_uart_data[minor].idx   = 0;
>       if (minor == 0) {
> -        imx_uart_tx_isr_data[minor].name = BSP_INT_UART1_TX;
> -        imx_uart_rx_isr_data[minor].name = BSP_INT_UART1_RX;
> -#endif
>           imx_uart_data[minor].regs =
>               (mc9328mxl_uart_regs_t *) MC9328MXL_UART1_BASE;
>       } else if (minor == 1) {
> -        imx_uart_tx_isr_data[minor].name = BSP_INT_UART2_TX;
> -        imx_uart_rx_isr_data[minor].name = BSP_INT_UART2_RX;
> -#endif
>               (mc9328mxl_uart_regs_t *) MC9328MXL_UART2_BASE;
>       } else {
> @@ -202,20 +192,6 @@ static void imx_uart_init(int minor)
>                       __FUNCTION__, __LINE__, minor);
> -    imx_uart_tx_isr_data[minor].hdl    = imx_uart_tx_isr;
> -    imx_uart_tx_isr_data[minor].handle = &imx_uart_data[minor];
> -    imx_uart_tx_isr_data[minor].on     = imx_uart_isr_on;
> -    imx_uart_tx_isr_data[minor].off    = imx_uart_isr_off;
> -    imx_uart_tx_isr_data[minor].isOn   = imx_uart_isr_is_on;
> -    imx_uart_rx_isr_data[minor].hdl    = imx_uart_rx_isr;
> -    imx_uart_rx_isr_data[minor].handle  = &imx_uart_data[minor];
> -    imx_uart_rx_isr_data[minor].on     = imx_uart_isr_on;
> -    imx_uart_rx_isr_data[minor].off    = imx_uart_isr_off;
> -    imx_uart_rx_isr_data[minor].isOn   = imx_uart_isr_is_on;
> -#endif
>       imx_uart_data[minor].regs->cr1 = (
>           MC9328MXL_UART_CR1_UARTCLKEN |
>           MC9328MXL_UART_CR1_UARTEN);
> @@ -243,13 +219,31 @@ static void imx_uart_init(int minor)
>   static int imx_uart_first_open(int major, int minor, void *arg)
>       rtems_libio_open_close_args_t *args = arg;
> +    rtems_status_code status = RTEMS_SUCCESSFUL;
>       imx_uart_data[minor].tty   = args->iop->data1;
> -    BSP_install_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
> -    BSP_install_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
> +#if defined(USE_INTERRUPTS)
> +    status = rtems_interrupt_handler_install(
> +        imx_uart_name_transmit(minor),
> +        "UART",
> +        RTEMS_INTERRUPT_UNIQUE,
> +        imx_uart_tx_isr,
> +        &imx_uart_data[minor]
> +    assert(status == RTEMS_SUCCESSFUL);
> +    imx_uart_isr_on(imx_uart_name_transmit(minor));
> +        imx_uart_name_receive(minor),
> +        "UART",
> +        imx_uart_rx_isr,
> +    imx_uart_isr_on(imx_uart_name_receive(minor));
>       imx_uart_data[minor].regs->cr1 |= MC9328MXL_UART_CR1_RRDYEN;
>   #endif
> @@ -259,8 +253,23 @@ static int imx_uart_first_open(int major, int minor, void *arg)
>   static int imx_uart_last_close(int major, int minor, void *arg)
> -    BSP_remove_rtems_irq_handler(&imx_uart_tx_isr_data[minor]);
> -    BSP_remove_rtems_irq_handler(&imx_uart_rx_isr_data[minor]);
> +    imx_uart_isr_off(imx_uart_name_transmit(minor));
> +    status = rtems_interrupt_handler_remove(
> +        imx_uart_tx_isr,
> +    imx_uart_isr_off(imx_uart_name_receive(minor));
> +        imx_uart_rx_isr,
>   #endif
>       return 0;
> @@ -317,22 +326,13 @@ static int imx_uart_set_attrs(int minor, const struct termios *t)
> +static void imx_uart_isr_on(const rtems_irq_number name)
> -    MC9328MXL_AITC_INTENNUM = irq->name;
> +    MC9328MXL_AITC_INTENNUM = name;
> +static void imx_uart_isr_off(const rtems_irq_number name)
> -    MC9328MXL_AITC_INTDISNUM = irq->name;
> -    int irq_num = (int)irq->name;
> -    if (irq_num < 32) {
> -        return MC9328MXL_AITC_INTENABLEL & (1 << irq_num);
> -    } else {
> -        return MC9328MXL_AITC_INTENABLEH & (1 << (irq_num - 32));
> +    MC9328MXL_AITC_INTDISNUM = name;
>   static void imx_uart_rx_isr(rtems_irq_hdl_param param)
> @@ -369,6 +369,28 @@ static void imx_uart_tx_isr(rtems_irq_hdl_param param)
>           rtems_termios_dequeue_characters(uart_data->tty, len);
> +    if (minor == 0) {
> +        return BSP_INT_UART1_TX;
> +    } else if (minor == 1) {
> +        return BSP_INT_UART2_TX;
> +    assert(0);
> +    if (minor == 0) {
> +        return BSP_INT_UART1_RX;
> +        return BSP_INT_UART2_RX;
> +    assert(0);
>   #endif
> @@ -417,7 +439,7 @@ static void imx_uart_set_baud(int minor, int baud)
>    * Polled, non-blocking read from UART
> -int imx_uart_poll_read_char(int minor)
>       return imx_uart_poll_read(minor);
> @@ -425,7 +447,7 @@ int imx_uart_poll_read_char(int minor)
>    * Polled, blocking write from UART
> -void  imx_uart_poll_write_char(int minor, char c)
>       imx_uart_poll_write(minor, &c, 1);
> @@ -433,7 +455,7 @@ void  imx_uart_poll_write_char(int minor, char c)
>    * Functions for printk() and friends.
> -void _BSP_output_char(char c)
>       poll_write(c);
>       if (c == '\n') {
> @@ -443,7 +465,7 @@ void _BSP_output_char(char c)
>   BSP_output_char_function_type BSP_output_char = _BSP_output_char;
> -int _BSP_poll_char(void)
>       return poll_read();
> diff --git a/c/src/lib/libbsp/arm/csb336/network/network.c b/c/src/lib/libbsp/arm/csb336/network/network.c
> index e513595..f93fcc8 100644
> --- a/c/src/lib/libbsp/arm/csb336/network/network.c
> +++ b/c/src/lib/libbsp/arm/csb336/network/network.c
> @@ -19,6 +19,7 @@
>   #include <errno.h>
>   #include <sys/param.h>
>   #include <sys/mbuf.h>
> @@ -39,19 +40,8 @@
>   #define START_TRANSMIT_EVENT    RTEMS_EVENT_2
>   static void enet_isr(rtems_irq_hdl_param);
> -static void enet_isr_on(const rtems_irq_connect_data *unused);
> -static void enet_isr_off(const rtems_irq_connect_data *unused);
> -static int enet_isr_is_on(const rtems_irq_connect_data *irq);
> -/* Replace the first value with the clock's interrupt name. */
> -rtems_irq_connect_data mc9328mxl_enet_isr_data = {
> -    .name    = BSP_INT_GPIO_PORTA,
> -    .hdl     = enet_isr,
> -    .handle  = (void *)BSP_INT_GPIO_PORTA,
> -    .on      = enet_isr_on,
> -    .off     = enet_isr_off,
> -    .isOn    = enet_isr_is_on,
> +static void enet_isr_on(void);
>   typedef struct {
>     unsigned long rx_packets;        /* total packets received         */
>     unsigned long tx_packets;        /* total packets transmitted      */
> @@ -238,6 +228,7 @@ void  mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
>       uint16_t stat;
>       uint16_t my = 0;
>       lan91c11x_write_reg(LAN91C11X_RCR, LAN91C11X_RCR_RST);
>       lan91c11x_write_reg(LAN91C11X_RCR, 0);
> @@ -334,7 +325,15 @@ void  mc9328mxl_enet_init_hw(mc9328mxl_enet_softc_t *sc)
>       MC9328MXL_GPIOA_IMR |= bit(3);
>       /* Install the interrupt handler */
> -    BSP_install_rtems_irq_handler(&mc9328mxl_enet_isr_data);
> +        BSP_INT_GPIO_PORTA,
> +        "Network",
> +        enet_isr,
> +        (void *)BSP_INT_GPIO_PORTA
> +    enet_isr_on();
>   } /* mc9328mxl_enet_init_hw() */
> @@ -602,7 +601,7 @@ void mc9328mxl_enet_stats (mc9328mxl_enet_softc_t *sc)
>   /* Enables mc9328mxl_enet interrupts. */
>       /* Enable interrupts */
>       MC9328MXL_AITC_INTENNUM = MC9328MXL_INT_GPIO_PORTA;
> @@ -610,23 +609,6 @@ static void enet_isr_on(const rtems_irq_connect_data *unused)
>       return;
> -/* Disables enet interrupts */
> -    /* disable all various TX/RX interrupts */
> -    MC9328MXL_AITC_INTDISNUM = MC9328MXL_INT_GPIO_PORTA;
> -    return;
> -/* Tests to see if mc9328mxl_enet interrupts are enabled, and returns non-0 if so.
> - * If interrupt is not enabled, returns 0.
> -    return MC9328MXL_AITC_INTENABLEL & (1 << MC9328MXL_INT_GPIO_PORTA);
>   /*  Driver ioctl handler */
>   static int
>   mc9328mxl_enet_ioctl (struct ifnet *ifp, ioctl_command_t command, caddr_t data)
> 1.7.11.7
> rtems-devel mailing list
> rtems-devel at rtems.org
