[PATCH] Updated Legacy code in arm csb336
Joel Sherrill
Joel.Sherrill at OARcorp.com
Tue Jul 9 12:34:13 UTC 2013
Chris Johns and I chatted about a similar situation with the use of some of the bspopts.h constants. Some are 0/1 and always defined which makes checking if it is defined bogus.
Personally I would move to the simple #if and define it to be 1. That way when 0 or defined, the code is correct.
Vipul Nayyar <nayyar_vipul at yahoo.com> wrote:
Hello,
Seems like a valid point to me, that you got there.
Sebastian, What do you suggest ? Simply remove the 1 from '#define USE_INTERRUPTS 1' or change #if defined() to simply #if ?
Regards
Vipul Nayyar
________________________________
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Tuesday, 9 July 2013 5:22 PM
Subject: Re: [PATCH] Updated Legacy code in arm csb336
On Jul 8, 2013, at 09:43 , Vipul Nayyar <nayyar_vipul at yahoo.com<mailto:nayyar_vipul at yahoo.com>> wrote:
> /* Define this to use interrupt driver UART driver */
> #if defined(USE_INTERRUPTS)
Personal observation:
I don't like using "#define USE_INTERRUPTS 1" in conjunction with "#if defined(USE_INTERRUPTS)". Someone not too careful will change it to "#define USE_INTERRUPTS 0" and not understand why it is still being used.
I either use "#define USE_INTERRUPTS" (I know it is defined to be 1) or "#define USE_INTERRUPTS 1" (or 0) in conjunction with "#if USE_INTERRUPTS". I use the second idiom in my own code, it also protects against typos such as "#if defined(USE_INTERUPTS)"
Peter
Peter Dufault
HD Associates, Inc. Software and System Engineering
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130709/6c41c83b/attachment.html>
