[PATCH] Updated Legacy code in arm csb336
Wed Jul 10 08:12:23 UTC 2013
Hello,
how did you generate and send this patch?  I had to deal with this:
git am --reject \[PATCH\]\ Updated\ Legacy\ code\ in\ arm\ csb336.eml
Applying: Updated Legacy code in arm csb336
Checking patch c/src/lib/libbsp/arm/csb336/console/uart.c...
error: while searching for:
#if defined(USE_INTERRUPTS)
static ssize_t imx_uart_intr_write(int minor, const char *buf, size_t len)
     imx_uart_data[minor].buf = buf;
error: patch failed: c/src/lib/libbsp/arm/csb336/console/uart.c:291
Hunk #9 succeeded at 327 (offset 2 lines).
Hunk #10 succeeded at 371 (offset 2 lines).
Hunk #11 succeeded at 441 (offset 2 lines).
Hunk #12 succeeded at 449 (offset 2 lines).
Hunk #13 succeeded at 457 (offset 2 lines).
Hunk #14 succeeded at 467 (offset 2 lines).
Checking patch c/src/lib/libbsp/arm/csb336/network/network.c...
Applying patch c/src/lib/libbsp/arm/csb336/console/uart.c with 1 rejects...
Hunk #1 applied cleanly.
Hunk #2 applied cleanly.
Hunk #3 applied cleanly.
Hunk #4 applied cleanly.
Hunk #5 applied cleanly.
Hunk #6 applied cleanly.
Hunk #7 applied cleanly.
Rejected hunk #8.
Hunk #9 applied cleanly.
Hunk #10 applied cleanly.
Hunk #11 applied cleanly.
Hunk #12 applied cleanly.
Hunk #13 applied cleanly.
Hunk #14 applied cleanly.
Applied patch c/src/lib/libbsp/arm/csb336/network/network.c cleanly.
Patch failed at 0001 Updated Legacy code in arm csb336
When you have resolved this problem run "git am --resolved".
If you would prefer to skip this patch, instead run "git am --skip".
To restore the original branch and stop patching run "git am --abort".
I had to manually clean this up:
http://git.rtems.org/rtems/commit/?id=52e44630e57b030d22dc6866425929efb1abac0f
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
