[rtems commit] Updated Legacy code in arm edb7312
Sebastian Huber
Thu Jul 11 07:17:08 UTC 2013
On 07/10/2013 07:18 PM, Joel Sherrill wrote:
> Module: rtems
> Branch: master
> Commit: 893d66937a17c4bb9fb3b909cf884948b466a3b5
> Changeset: http://git.rtems.org/rtems/commit/?id=893d66937a17c4bb9fb3b909cf884948b466a3b5
> Author: Vipul Nayyar <nayyar_vipul at yahoo.com>
> Date: Wed Jul 10 09:52:28 2013 -0500
> c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c | 49 ++++++++++--------------
> c/src/lib/libbsp/arm/edb7312/network/network.c | 27 +++++++++----
> 2 files changed, 39 insertions(+), 37 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
> index bd77dd6..af0448f 100644
> --- a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
> +++ b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
> @@ -12,24 +12,14 @@
> #include <ep7312.h>
> #include <bsp.h>
> #include <bsp/irq.h>
> +#include <assert.h>
> #if ON_SKYEYE==1
> #define CLOCK_DRIVER_USE_FAST_IDLE
> #endif
> void Clock_isr(rtems_irq_hdl_param arg);
Here we still use rtems_irq_hdl_param which is a type of the legacy API.
> -static void clock_isr_on(const rtems_irq_connect_data *unused);
> -static void clock_isr_off(const rtems_irq_connect_data *unused);
> -static int clock_isr_is_on(const rtems_irq_connect_data *irq);
> -rtems_irq_connect_data clock_isr_data = {
> - .name = BSP_TC1OI,
> - .hdl = Clock_isr,
> - .handle = NULL,
> - .on = clock_isr_on,
> - .off = clock_isr_off,
> - .isOn = clock_isr_is_on,
> +uint32_t clock_driver_get_nanoseconds_since_last_tick(void);
Declaring of a global function in a source file a bad hack.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
