[PATCH] Updated Legacy code in arm rtl22xx
Vipul Nayyar
nayyar_vipul at yahoo.com
Fri Jul 12 15:30:36 UTC 2013
Ok, So before sending the updated patch I'll list in advance what I'm gonna change, so that we don't have to go through this again.
1) Change cs8900_isr to static. The sample code would be:
static void cs8900_isr(void *arg)
cs8900_device *cs = arg;
cs8900_interrupt(LPC22xx_INTERRUPT_EINT2, cs);
2)There don't seem to be any declarations for a global function in the network.c . So, no problem there.
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Friday, 12 July 2013 8:45 PM
Subject: Re: [PATCH] Updated Legacy code in arm rtl22xx
On 07/12/2013 02:27 PM, Vipul Nayyar wrote:
> I don't understand, why cs8900_isr() cannot be made to pass cs8900_device *cs
> like I did in my patch. From where is this function is called ?
You can look at the sources to find this out. Start with
bsp_interrupt_handler_dispatch().
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130712/06d2b316/attachment.html>
