[PATCH] Updated legacy code on arm gumstix
Fri Jul 12 19:59:16 UTC 2013
I got this:
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/
-B../../../../../.././gumstix/lib/ -specs bsp_specs -qrtems
-DHAVE_CONFIG_H   -isystem ../../../../../.././gumstix/lib/include
-D__INSIDE_RTEMS_BSD_TCPIP_STACK__   -mstructure-size-boundary=8
-mcpu=xscale -mfpu=vfp -mfloat-abi=soft -O2 -g  -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT rtl8019_rel-rtl8019.o -MD -MP -MF
.deps/rtl8019_rel-rtl8019.Tpo -c -o rtl8019_rel-rtl8019.o `test -f
'rtl8019/rtl8019.c' || echo
'/home/sh/rtems-4.11/c/src/lib/libbsp/arm/gumstix/'`rtl8019/rtl8019.c
/home/sh/rtems-4.11/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c: In
function 'ne_init_irq_handler':
/home/sh/rtems-4.11/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c:486:5: warning:
passing argument 4 of 'rtems_interrupt_handler_install' from
incompatible pointer type [enabled by default]
In file included from
../../../../../.././gumstix/lib/include/bsp/irq.h:19:0,
                  from
/home/sh/rtems-4.11/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c:12:
../../../../../.././gumstix/lib/include/rtems/irq-extension.h:114:19:
note: expected 'rtems_interrupt_handler' but argument is of type 'void
(*)(struct ne_softc *)'
  rtems_status_code rtems_interrupt_handler_install(
Didn't we agree, that you compile the code and eliminate all warnings?
http://git.rtems.org/rtems/commit/?id=163e88a8c36815dad65a0342a2d6f851f1f5ed9f
On 12/07/13 19:03, Vipul Nayyar wrote:
>   c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c | 15 ++++-----------
>   1 file changed, 4 insertions(+), 11 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c b/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c
> index ef8ae4e..d419eac 100644
> --- a/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c
> +++ b/c/src/lib/libbsp/arm/gumstix/rtl8019/rtl8019.c
> @@ -332,10 +332,8 @@ ne_check_status (struct ne_softc *sc, int from_irq_handler)
>   /* Handle an NE2000 interrupt.  */
>   static void
> -ne_interrupt_handler (rtems_irq_hdl_param handle)
> +ne_interrupt_handler (struct ne_softc *sc)
> -  struct ne_softc *sc = handle;
>     if (sc == NULL)
>       return;
> @@ -350,10 +348,8 @@ ne_interrupt_handler (rtems_irq_hdl_param handle)
>   /* Turn NE2000 interrupts on.  */
>   static void
> -ne_interrupt_on (const void * handle)
> +ne_interrupt_on (struct ne_softc *sc)
>   #ifdef DEBUG_NE
>     printk ("ne_interrupt_on()\n");
>   #endif
> @@ -364,10 +360,8 @@ ne_interrupt_on (const void * handle)
>   /* Turn NE2000 interrupts off.  See ne_interrupt_on.  */
>   static void
> -ne_interrupt_off (const void * handle)
> +ne_interrupt_off (struct ne_softc *sc)
>   #ifdef DEBUG_NE
>     printk ("ne_interrupt_off()\n");
>   #endif
> @@ -380,9 +374,8 @@ ne_interrupt_off (const void * handle)
>    *If it is eanbled, return 1
>   static int
> -ne_interrupt_is_on (const void * handle)
> +ne_interrupt_is_on (struct ne_softc *sc)
>     unsigned char imr;
>   #ifdef DEBUG_NE
>     printk("ne_interrupt_is_on()\n");
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
