[GSoC|RTEMS-GDB] Project status.
Fri Jul 12 22:17:26 UTC 2013
Dhananjay Balan wrote:
> RTEMS GDB Updates
> A) The framework has undergone major re factoring. The code has been
> separated into following modules and this design will be followed in future,
> This is done mainly to reduce the clutter and to increase the
> re-usability of the code.
>   1) Object abstractions will go into a module of their own name or into
> a module corresponding to the parent API. (e.g CORE_ data structures are
> in the supercore module)
>   2) Pretty printers will go into $api_name_printers
>   (e.g id_printer is in supercore_printer)
>   3) Helper routines will be grouped into their own modules (ToDo as of
> current master)
> B) rtems object command now prints message_queue objects and I want to
> get an opinion on its implementation.
> If you look at the code,
> classic.message_queue creates a supercore.CORE_message_queue object, and
> each have a method to print the contents.
Nice.
> What I am intending to do is to add all the classic api objects into
> this, and then refactor again
>   - Move all the helper routine methods out of the main abstraction
>   - to have a robust inheritance in the code.
This sounds great.
> C) Testing the code.
> A testing framework can ensure that the code in this repository stays
> current as rtems moves forward. The idea is to write tests against a
> pre-defined sample code.
> Please go through the code at github and shoot any commends criticisms
> you have.
I have and it is looking great.
Joel's question about where to keep this code is something I need to
consider. This should not effect you or your progress but as you make
progress what it offers to RTEMS users is excellent and useful and
should be easily available.
Well done with your efforts.
> Note: the repo is here https://github.com/dbalan/rtems-gdb
> On 23 June 2013 21:28, Dhananjay Balan <mb.dhananjay at gmail.com
> <mailto:mb.dhananjay at gmail.com>> wrote:
>     Hi,
>     I was little bit delayed by my academic responsibilities, but I have
>     moved out and everything is in order so that concentrate
>     exclusively on the SoC. I have created a github repository[1] to
>     push my work. I am starting from what chris wrote and refactoring on
>     the go.
>     What I am done so far:
>     * Read and understood the GDB python API
>     * Initial scan through the RTEMS docs.
>     * GDB developer agreement completed
>     * A blog post on how to use the debug extenstions (Nothing new, but
>     I plan to blog along with my work progresses, and this will be the
>     first in it)[2]
>     What I will be doing next week:
>     * Pretty printers - Lots of pretty printers
>     I intend to start with the classic api, some parent objects in the
>     hierarchy is already implemented by Chris, My approach is to start
>     from top and implement them on the go.
>     * Port simple commands from rtems-gdb script, that utilizes the
>     pretty printers - it will also help for others to test my code.
>     I will update the work progress here by mail, and also in my blog.
>     [1] https://github.com/dbalan/rtems-gdb
>     [2] http://dbalan.github.io/blog/2013/06/23/debugging-rtems-with-gdb/
>     Dhananjay
> Regards,
> Dhananjay M Balan,
> Department Of Computer Science,
> College Of Engineering, Trivandrum.
> http://cet.ac.in
> rtems-devel mailing list
> rtems-devel at rtems.org
