[PATCH] Updated legacy code in arm edb7312
Vipul Nayyar nayyar_vipul at yahoo.com
Sat Jul 13 11:50:06 UTC 2013
 c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c  |  3 +--
 c/src/lib/libbsp/arm/edb7312/network/network.c | 12 +++++-------
 2 files changed, 6 insertions(+), 9 deletions(-)
diff --git a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
index af0448ff7..761387f 100644
--- a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
+++ b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
@@ -18,8 +18,7 @@
   #define CLOCK_DRIVER_USE_FAST_IDLE
 #endif
-void Clock_isr(rtems_irq_hdl_param arg);
-uint32_t clock_driver_get_nanoseconds_since_last_tick(void);
+void Clock_isr(void * arg);
 #define Clock_driver_support_at_tick()                \
   do {                                                \
diff --git a/c/src/lib/libbsp/arm/edb7312/network/network.c b/c/src/lib/libbsp/arm/edb7312/network/network.c
index ce139ec..773b4c4 100644
--- a/c/src/lib/libbsp/arm/edb7312/network/network.c
+++ b/c/src/lib/libbsp/arm/edb7312/network/network.c
@@ -7,14 +7,13 @@
 #define CS8900_BASE 0x20000300
 unsigned int bsp_cs8900_io_base = 0;
 unsigned int bsp_cs8900_memory_base = 0;
-cs8900_device *g_cs;
-void cs8900_isr(rtems_irq_hdl_param unused);
+void cs8900_isr(void *);
 char g_enetbuf[1520];
+void cs8900_isr(void *arg)
-    cs8900_interrupt(BSP_EINT3, g_cs);
+    cs8900_interrupt(BSP_EINT3, arg);
 /* cs8900_io_set_reg - set one of the I/O addressed registers */
@@ -64,14 +63,13 @@ unsigned short cs8900_mem_get_reg (cs8900_device *cs, unsigned long reg)
 void cs8900_attach_interrupt (cs8900_device *cs)
     rtems_status_code status = RTEMS_SUCCESSFUL;
-    g_cs = cs;
     status = rtems_interrupt_handler_install(
         BSP_EINT3,
         "Network",
         RTEMS_INTERRUPT_UNIQUE,
         cs8900_isr,
-        NULL
+        cs
     assert(status == RTEMS_SUCCESSFUL);
@@ -83,7 +81,7 @@ void cs8900_detach_interrupt (cs8900_device *cs)
     status = rtems_interrupt_handler_remove(
         BSP_EINT3,
         cs8900_isr,
-        NULL
+        cs
1.7.11.7
