[PATCH 2/4] Add cpukit shared libmm header and stubs
Hesham AL-Matary heshamelmatary at gmail.com
Sat Jul 13 23:05:19 UTC 2013
From: Hesham ALmatary <heshamelmatary at gmail.com>
 c/src/lib/libcpu/shared/include/mm.h              | 23 +++++++++++++++++++++++
 c/src/lib/libcpu/shared/src/no_memorymanagement.c | 17 +++++++++++++++++
 2 files changed, 40 insertions(+)
 create mode 100644 c/src/lib/libcpu/shared/include/mm.h
 create mode 100644 c/src/lib/libcpu/shared/src/no_memorymanagement.c
diff --git a/c/src/lib/libcpu/shared/include/mm.h b/c/src/lib/libcpu/shared/include/mm.h
new file mode 100644
index 0000000..02903f1
--- /dev/null
+++ b/c/src/lib/libcpu/shared/include/mm.h
@@ -0,0 +1,23 @@
+ * Copyright (c) 2013 Gedare Bloom.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef __LIBCPU_MM_H
+#define __LIBCPU_MM_H
+#include <rtems/score/mm.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+void _CPU_Memory_management_Initialize(void);
+#ifdef __cplusplus
+#endif
+#endif
diff --git a/c/src/lib/libcpu/shared/src/no_memorymanagement.c b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
index 0000000..2e3f528
--- /dev/null
+++ b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
@@ -0,0 +1,17 @@
+ * Copyright (c) 2013 Hesham AL-Matary
+#include <rtems.h>
+#include <libcpu/mm.h>
+void _CPU_Memory_management_Initialize( void ) { }
+void _CPU_Memory_management_Install_entry( Memory_management_Entry *mpe, uint32_t flags ) { }
+void _CPU_Memory_management_Uninstall_entry( Memory_management_Entry *mpe ) { }
1.8.3.1
