[PATCH 1/6] New atomic API definition based on C11 atomic
WeiY wei.a.yang at gmail.com
Sun Jul 14 09:07:33 UTC 2013
 cpukit/score/include/rtems/score/atomic.h |  445 +++++++++++++++--------------
 1 file changed, 232 insertions(+), 213 deletions(-)
diff --git a/cpukit/score/include/rtems/score/atomic.h b/cpukit/score/include/rtems/score/atomic.h
index 3b62cb1..80b9ea7 100644
--- a/cpukit/score/include/rtems/score/atomic.h
+++ b/cpukit/score/include/rtems/score/atomic.h
@@ -8,7 +8,7 @@
- * COPYRIGHT (c) 2012 Deng Hengyi.
+ * COPYRIGHT (c) 2012-2013 Deng Hengyi.
  * The license and distribution terms for this file may be
  * found in the file LICENSE in this distribution or at
@@ -32,241 +32,260 @@ extern "C" {
- * @brief the enumeration Atomic_Memory_barrier specifies the detailed regular
- * memory synchronization operations used in the atomic operation API
- * definitions.
+ * @brief Atomically load an atomic type value from atomic object.
+ * @param object an atomic type pointer of object.
+ * @param order a type of Atomic_Order.
+ * The order shall not be ATOMIC_ORDER_RELEASE.
-typedef enum {
-  /** no operation orders memory. */
-  ATOMIC_RELAXED_BARRIER,
-  /** a load operation performs an acquire operation on the affected memory
-  * location. This flag guarantees that the effects of load operation are
-  * completed before the effects of any later data accesses.
-  ATOMIC_ACQUIRE_BARRIER,
-  /** a store operation performs a release operation on the affected memory
-  * location. This flag guarantee that all effects of all previous data
-  * accesses are completed before the store operation takes place.
-  ATOMIC_RELEASE_BARRIER
-} Atomic_Memory_barrier;
+RTEMS_INLINE_ROUTINE uint_fast32_t _Atomic_Load_uint(
+  volatile Atomic_Uint *object,
+  Atomic_Order order
+  return _CPU_atomic_Load_uint( object, order );
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Load_ptr(
+  volatile Atomic_Pointer *object,
+  return _CPU_atomic_Load_ptr( object, order );
- * @brief Atomically load an atomic type value from address @a address with
- * a type of Atomic_Memory_barrier @a memory_barrier. The @a memory_barrier
- * shall not be ATOMIC_RELEASE_BARRIER.
+ * @brief Atomically store an atomic type value into a atomic object.
+ * @param value a value to be stored into object.
+ * The order shall not be ATOMIC_ORDER_ACQUIRE.
-RTEMS_INLINE_ROUTINE Atomic_Int _Atomic_Load_int(
-  volatile Atomic_Int *address,
-  Atomic_Memory_barrier memory_barrier
-RTEMS_INLINE_ROUTINE Atomic_Long _Atomic_Load_long(
-  volatile Atomic_Long *address,
-RTEMS_INLINE_ROUTINE Atomic_Pointer _Atomic_Load_ptr(
-  volatile Atomic_Pointer *address,
-RTEMS_INLINE_ROUTINE Atomic_Int32 _Atomic_Load_32(
-  volatile Atomic_Int32 *address,
-RTEMS_INLINE_ROUTINE Atomic_Int64 _Atomic_Load_64(
-  volatile Atomic_Int64 *address,
+RTEMS_INLINE_ROUTINE void _Atomic_Store_uint(
+  uint_fast32_t value,
+  _CPU_atomic_Store_uint( object, value, order );
+RTEMS_INLINE_ROUTINE void _Atomic_Store_ptr(
+  uintptr_t value,
+  _CPU_atomic_Store_ptr( object, value, order );
- * @brief Atomically store an atomic type value @a value into address @a
- * address with a type of Atomic_Memory_barrier @a memory_barrier. The @a
- * memory_barrier shall not be ATOMIC_ACQUIRE_BARRIER.
+ * @brief Atomically load-add-store an atomic type value into object
+ * @param object a atomic type pointer of object.
+ * @param value a value to be add and store into object.
+ * @retval a result value after add ops.
-RTEMS_INLINE_ROUTINE void _Atomic_Store_int(
-  Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_long(
-  Atomic_Long value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_ptr(
-  Atomic_Pointer value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_32(
-  Atomic_Int32 value,
-RTEMS_INLINE_ROUTINE void _Atomic_Store_64(
-  Atomic_Int64 value,
+RTEMS_INLINE_ROUTINE uint_fast32_t _Atomic_Fetch_add_uint(
+  return _CPU_atomic_Fetch_add_uint( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Fetch_add_ptr(
+  uintptr_t value,
+  return _CPU_atomic_Fetch_add_ptr( object, value, order );
- * @brief Atomically load-add-store an atomic type value @a value into address
- * @a address with a type of Atomic_Memory_barrier @a memory_barrier.
+ * @brief Atomically load-sub-store an atomic type value into object
+ * @param value a value to be sub and store into object.
+ * @retval a result value after sub ops.
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_int(
-  Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_64(
+RTEMS_INLINE_ROUTINE uint_fast32_t _Atomic_Fetch_sub_uint(
+  return _CPU_atomic_Fetch_sub_uint( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Fetch_sub_ptr(
+  uintptr_t value,
+  return _CPU_atomic_Fetch_sub_ptr( object, value, order );
- * @brief Atomically load-sub-store an atomic type value @a value into address
+ * @brief Atomically load-or-store an atomic type value into object
+ * @param value a value to be or and store into object.
+ * @retval a result value after or ops.
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_int(
-  Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_64(
+RTEMS_INLINE_ROUTINE uint_fast32_t _Atomic_Fetch_or_uint(
+  return _CPU_atomic_Fetch_or_uint( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Fetch_or_ptr(
+  uintptr_t value,
+  return _CPU_atomic_Fetch_or_ptr( object, value, order );
- * @brief Atomically load-or-store an atomic type value @a value into address
+ * @brief Atomically load-and-store an atomic type value into object
+ * @param value a value to be and and store into object.
+ * @retval a result value after and ops.
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_int(
-  Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_64(
+RTEMS_INLINE_ROUTINE uint_fast32_t _Atomic_Fetch_and_uint(
+  return _CPU_atomic_Fetch_and_uint( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Fetch_and_ptr(
+  uintptr_t value,
+  return _CPU_atomic_Fetch_and_ptr( object, value, order );
+ * @brief Atomically exchange an atomic type value into object
+ * @param value a value to exchange and and store into object.
+ * @retval a result value after exchange ops.
+RTEMS_INLINE_ROUTINE uint_fast32_t _Atomic_Exchange_uint(
+  return _CPU_atomic_Exchange_uint( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _Atomic_Exchange_ptr(
+ uintptr_t value,
+  return _CPU_atomic_Exchange_ptr( object, value, order );
- * @brief Atomically load-and-store an atomic type value @a value into address
+ * @brief Atomically compare the value stored at object with a
+ * old_value and if the two values are equal, update the value of a
+ * address with a new_value
+ * @param old_value pointer of a value.
+ * @param new_value a atomic type value.
+ * @param order_succ a type of Atomic_Order for successful exchange.
+ * @param order_fail a type of Atomic_Order for failed exchange.
+ * @retval true if the compare exchange successully.
+ * @retval false if the compare exchange failed.
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_int(
-  Atomic_Int value,
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_long(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_ptr(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_32(
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_64(
+RTEMS_INLINE_ROUTINE bool _Atomic_Compare_exchange_uint(
+  uint_fast32_t *old_value,
+  uint_fast32_t new_value,
+  Atomic_Order order_succ,
+  Atomic_Order order_fail
+  return _CPU_atomic_Compare_exchange_uint( object, old_value, new_value,
+    order_succ, order_fail );
+RTEMS_INLINE_ROUTINE bool _Atomic_Compare_exchange_ptr(
+  uintptr_t *old_value,
+  uintptr_t new_value,
+  return _CPU_atomic_Compare_exchange_ptr( object, old_value, new_value,
- * @brief Atomically compare the value stored at @a address with @a
- * old_value and if the two values are equal, update the value of @a
- * address with @a new_value. Returns zero if the compare failed,
- * nonzero otherwise. The operation uses a type of Atomic_Memory_barrier
- * @a memory_barrier.
+ * @brief Atomically clear the value of an atomic flag type object.
+ * @param[in, out] object an atomic flag type pointer of object.
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_int(
-  Atomic_Int old_value,
-  Atomic_Int new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_long(
-  Atomic_Long old_value,
-  Atomic_Long new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_ptr(
-  Atomic_Pointer old_value,
-  Atomic_Pointer new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_32(
-  Atomic_Int32 old_value,
-  Atomic_Int32 new_value,
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_64(
-  Atomic_Int64 old_value,
-  Atomic_Int64 new_value,
+RTEMS_INLINE_ROUTINE void _Atomic_Clear_flag(
+ volatile Atomic_Flag *object,
+  _CPU_atomic_Clear_flag( object, order );
-#include <rtems/score/atomic.inl>
+ * @brief Atomically test and clear the value of an atomic flag type object.
+ * @retval true if the test and set successully.
+ * @retval false if the test and set failed.
+RTEMS_INLINE_ROUTINE bool _Atomic_Test_set_flag(
+  return _CPU_atomic_Test_set_flag( object, order );
 #ifdef __cplusplus
1.7.9.5
