[PATCH 2/6] A generic atomic implementation for smp architectures
WeiY wei.a.yang at gmail.com
Sun Jul 14 09:07:34 UTC 2013
 cpukit/score/Makefile.am                        |    1 +
 cpukit/score/include/rtems/score/cpustdatomic.h |  332 +++++++++++++++++++++++
 cpukit/score/preinstall.am                      |    4 +
 3 files changed, 337 insertions(+)
 create mode 100644 cpukit/score/include/rtems/score/cpustdatomic.h
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 3f6e686..82bf26d 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -63,6 +63,7 @@ include_rtems_score_HEADERS += include/rtems/score/basedefs.h
 include_rtems_score_HEADERS += include/rtems/score/atomic.h
 include_rtems_score_HEADERS += include/rtems/score/genericcpuatomic.h
 include_rtems_score_HEADERS += include/rtems/score/genericatomicops.h
+include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
 if HAS_PTHREADS
 include_rtems_score_HEADERS += include/rtems/score/corespinlock.h
diff --git a/cpukit/score/include/rtems/score/cpustdatomic.h b/cpukit/score/include/rtems/score/cpustdatomic.h
new file mode 100644
index 0000000..97cacc5
--- /dev/null
+++ b/cpukit/score/include/rtems/score/cpustdatomic.h
@@ -0,0 +1,332 @@
+ * @file  rtems/score/cpustdatomic.h
+ * This include file defines the generic data struct and implementation
+ * based on stdatomic.h for all the support architectures. You should not
+ * include this header file directly, because it will be used by atomic.h
+ * which should be included by score components
+ * COPYRIGHT (c) 2013 Deng Hengyi.
+ * http://www.rtems.com/license/LICENSE.
+#ifndef _RTEMS_SCORE_GENERAL_STDATOMIC_CPU_H_
+#define _RTEMS_SCORE_GENERAL_STDATOMIC_CPU_H_
+#include <stdatomic.h>
+#include <rtems/score/types.h>
+#ifdef __cplusplus
+extern "C" {
+#endif
+ * @defgroup RTEMS general stdatomic data type and implementation.
+ * @brief atomic operation unsigned integer type
+typedef atomic_uint_fast32_t Atomic_Uint;
+ * @brief atomic operation unsigned integer the size of a pointer type
+typedef atomic_uintptr_t Atomic_Pointer;
+ * @brief atomic operation flag type
+typedef atomic_flag Atomic_Flag;
+ * @brief the enumeration Atomic_Memory_barrier specifies the detailed regular
+ * memory synchronization operations used in the atomic operation API
+ * definitions.
+typedef enum {
+  /** no operation orders memory. */
+  ATOMIC_ORDER_RELAXED = memory_order_relaxed,
+  /** a load operation performs an acquire operation on the affected memory
+  * location. This flag guarantees that the effects of load operation are
+  * completed before the effects of any later data accesses.
+  ATOMIC_ORDER_ACQUIRE = memory_order_acquire,
+  /** a store operation performs a release operation on the affected memory
+  * location. This flag guarantee that all effects of all previous data
+  * accesses are completed before the store operation takes place.
+  ATOMIC_ORDER_RELEASE = memory_order_release
+} Atomic_Order;
+ * @brief Atomically load an atomic type value from atomic object.
+ * @param object an atomic type pointer of object.
+ * @param order a type of Atomic_Order.
+ * The order shall not be ATOMIC_ORDER_RELEASE.
+RTEMS_INLINE_ROUTINE uint_fast32_t _CPU_atomic_Load_uint(
+  volatile Atomic_Uint *object,
+  Atomic_Order order
+  return atomic_load_explicit( object, order );
+RTEMS_INLINE_ROUTINE uintptr_t _CPU_atomic_Load_ptr(
+  volatile Atomic_Pointer *object,
+ * @brief Atomically store an atomic type value into a atomic object.
+ * @param value a value to be stored into object.
+ * The order shall not be ATOMIC_ORDER_ACQUIRE.
+RTEMS_INLINE_ROUTINE void _CPU_atomic_Store_uint(
+  uint_fast32_t value,
+  atomic_store_explicit( object, value, order );
+RTEMS_INLINE_ROUTINE void _CPU_atomic_Store_ptr(
+  uintptr_t value,
+ * @brief Atomically load-add-store an atomic type value into object
+ * @param object a atomic type pointer of object.
+ * @param value a value to be add and store into object.
+ * @retval a result value after add ops.
+RTEMS_INLINE_ROUTINE uint_fast32_t _CPU_atomic_Fetch_add_uint(
+  return atomic_fetch_add_explicit( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _CPU_atomic_Fetch_add_ptr(
+  uintptr_t value,
+ * @brief Atomically load-sub-store an atomic type value into object
+ * @param value a value to be sub and store into object.
+ * @retval a result value after sub ops.
+RTEMS_INLINE_ROUTINE uint_fast32_t _CPU_atomic_Fetch_sub_uint(
+  return atomic_fetch_sub_explicit( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _CPU_atomic_Fetch_sub_ptr(
+  uintptr_t value,
+ * @brief Atomically load-or-store an atomic type value into object
+ * @param value a value to be or and store into object.
+ * @retval a result value after or ops.
+RTEMS_INLINE_ROUTINE uint_fast32_t _CPU_atomic_Fetch_or_uint(
+  return atomic_fetch_or_explicit( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _CPU_atomic_Fetch_or_ptr(
+  uintptr_t value,
+ * @brief Atomically load-and-store an atomic type value into object
+ * @param value a value to be and and store into object.
+ * @retval a result value after and ops.
+RTEMS_INLINE_ROUTINE uint_fast32_t _CPU_atomic_Fetch_and_uint(
+  return atomic_fetch_and_explicit( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _CPU_atomic_Fetch_and_ptr(
+  uintptr_t value,
+ * @brief Atomically exchange an atomic type value into object
+ * @param value a value to exchange and and store into object.
+ * @retval a result value after exchange ops.
+RTEMS_INLINE_ROUTINE uint_fast32_t _CPU_atomic_Exchange_uint(
+  return atomic_exchange_explicit( object, value, order );
+RTEMS_INLINE_ROUTINE uintptr_t _CPU_atomic_Exchange_ptr(
+ uintptr_t value,
+ * @brief Atomically compare the value stored at object with a
+ * old_value and if the two values are equal, update the value of a
+ * address with a new_value
+ * @param old_value pointer of a value.
+ * @param new_value a atomic type value.
+ * @param order_succ a type of Atomic_Order for successful exchange.
+ * @param order_fail a type of Atomic_Order for failed exchange.
+ * @retval true if the compare exchange successully.
+ * @retval false if the compare exchange failed.
+RTEMS_INLINE_ROUTINE bool _CPU_atomic_Compare_exchange_uint(
+  uint_fast32_t *old_value,
+  uint_fast32_t new_value,
+  Atomic_Order order_succ,
+  Atomic_Order order_fail
+  return atomic_compare_exchange_strong_explicit( object, old_value,
+    new_value, order_succ, order_fail );
+RTEMS_INLINE_ROUTINE bool _CPU_atomic_Compare_exchange_ptr(
+  uintptr_t *old_value,
+  uintptr_t new_value,
+ * @brief Atomically clear the value of an atomic flag type object.
+ * @param[in, out] object an atomic flag type pointer of object.
+RTEMS_INLINE_ROUTINE void _CPU_atomic_Clear_flag(
+ volatile Atomic_Flag *object,
+  return atomic_flag_clear_explicit( object, order );
+ * @brief Atomically test and clear the value of an atomic flag type object.
+ * @retval true if the test and set successully.
+ * @retval false if the test and set failed.
+RTEMS_INLINE_ROUTINE bool _CPU_atomic_Test_set_flag(
+  return atomic_flag_test_and_set_explicit( object, order );
+#ifdef __cplusplus
+#endif
+#endif
+/*  end of include file */
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index dc84b21..1b7955e 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -235,6 +235,10 @@ $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h: include/rtems/score/genericat
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h
+$(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h: include/rtems/score/cpustdatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
+	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
+PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
 if HAS_PTHREADS
 $(PROJECT_INCLUDE)/rtems/score/corespinlock.h: include/rtems/score/corespinlock.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corespinlock.h
1.7.9.5
