[PATCH] Updated legacy code in arm edb7312
Mon Jul 15 08:32:23 UTC 2013
On 07/13/2013 01:50 PM, Vipul Nayyar wrote:
> diff --git a/c/src/lib/libbsp/arm/edb7312/network/network.c b/c/src/lib/libbsp/arm/edb7312/network/network.c
> index ce139ec..773b4c4 100644
> --- a/c/src/lib/libbsp/arm/edb7312/network/network.c
> +++ b/c/src/lib/libbsp/arm/edb7312/network/network.c
> @@ -7,14 +7,13 @@
>   #define CS8900_BASE 0x20000300
>   unsigned int bsp_cs8900_io_base = 0;
>   unsigned int bsp_cs8900_memory_base = 0;
> -cs8900_device *g_cs;
> -void cs8900_isr(rtems_irq_hdl_param unused);
> +void cs8900_isr(void *);
This is a global function declaration in a source file.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
