[PATCH] Updated Legacy code in arm rtl22xx
Vipul Nayyar
nayyar_vipul at yahoo.com
Mon Jul 15 08:59:18 UTC 2013
Hello,
I fail to see which part is superfluous, since the pointer cs is now used directly by the dispatch function to call the interrupt handler with parameter arg. The role of g_cs is completely removed.
Regards
Vipul Nayyar
________________________________
From: Sebastian Huber <sebastian.huber at embedded-brains.de>
To: Vipul Nayyar <nayyar_vipul at yahoo.com>
Cc: "rtems-devel at rtems.org" <rtems-devel at rtems.org>
Sent: Monday, 15 July 2013 1:57 PM
Subject: Re: [PATCH] Updated Legacy code in arm rtl22xx
On 07/13/2013 10:18 AM, Vipul Nayyar wrote:
> @@ -69,13 +63,26 @@ unsigned short cs8900_mem_get_reg (cs8900_device *cs,
> unsigned long reg)
> void cs8900_attach_interrupt (cs8900_device *cs)
> - g_cs = cs;
> - BSP_install_rtems_irq_handler(&cs8900_isr_data);
> + rtems_status_code status = RTEMS_SUCCESSFUL;
> + status = rtems_interrupt_handler_install(
> + LPC22xx_INTERRUPT_EINT2,
> + "Network",
> + RTEMS_INTERRUPT_UNIQUE,
> + (rtems_interrupt_handler)cs8900_isr,
Since you fixed the cs8900_isr(), this case is now superfluous.
Phone : +49 89 189 47 41-16
Fax : +49 89 189 47 41-09
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130715/39bbd112/attachment.html>
