[PATCH] Updated legacy code in arm edb7312
Mon Jul 15 10:08:25 UTC 2013
Hello Vipul,
your patches are getting better, but please review them carefully before you
submit them and fix all obvious problems:
gmake[6]: Entering directory
`/scratch/git-build/b-edb7312/arm-rtems4.11/c/edb7312/lib/libbsp/arm/edb7312'
arm-rtems4.11-gcc --pipe -B../../../../../.././lib/
-B../../../../../.././edb7312/lib/ -specs bsp_specs -qrtems -DHAVE_CONFIG_H
-isystem ../../../../../.././edb7312/lib/include   -O2 -g -Wall
-Wmissing-prototypes -Wimplicit-function-declaration -Wstrict-prototypes
-Wnested-externs -MT clockdrv.o -MD -MP -MF .deps/clockdrv.Tpo -c -o clockdrv.o
`test -f 'clock/clockdrv.c' || echo
'/home/sh/rtems-4.11/c/src/lib/libbsp/arm/edb7312/'`clock/clockdrv.c
/home/sh/rtems-4.11/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c:74:10:
warning: no previous prototype for
'clock_driver_get_nanoseconds_since_last_tick' [-Wmissing-prototypes]
  uint32_t clock_driver_get_nanoseconds_since_last_tick(void)
The next patch from you with compiler warnings is the last patch I review from you.
If you are unsure, how to deal with a warning, then ask on the list, but don't
expect that reviewers solve the problems for you.
In this particular case you can completely remove the nanoseconds support.  See
also clockdrv_shell.h:
   #if defined(Clock_driver_nanoseconds_since_last_tick)
     rtems_clock_set_nanoseconds_extension(
   #endif
So this nanoseconds handler is optional.  All BSPs defining
   return 0;
have this problem.
On 07/15/2013 11:32 AM, Vipul Nayyar wrote:
>   c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c  |  3 +--
>   c/src/lib/libbsp/arm/edb7312/network/network.c | 12 +++++-------
>   2 files changed, 6 insertions(+), 9 deletions(-)
> diff --git a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
> index af0448ff7..761387f 100644
> --- a/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
> +++ b/c/src/lib/libbsp/arm/edb7312/clock/clockdrv.c
> @@ -18,8 +18,7 @@
>     #define CLOCK_DRIVER_USE_FAST_IDLE
>   #endif
> -void Clock_isr(rtems_irq_hdl_param arg);
> -uint32_t clock_driver_get_nanoseconds_since_last_tick(void);
> +void Clock_isr(void * arg);
>   #define Clock_driver_support_at_tick()                \
>     do {                                                \
> diff --git a/c/src/lib/libbsp/arm/edb7312/network/network.c b/c/src/lib/libbsp/arm/edb7312/network/network.c
> index ce139ec..468fb61 100644
> --- a/c/src/lib/libbsp/arm/edb7312/network/network.c
> +++ b/c/src/lib/libbsp/arm/edb7312/network/network.c
> @@ -7,14 +7,13 @@
>   #define CS8900_BASE 0x20000300
>   unsigned int bsp_cs8900_io_base = 0;
>   unsigned int bsp_cs8900_memory_base = 0;
> -cs8900_device *g_cs;
> -void cs8900_isr(rtems_irq_hdl_param unused);
> +static void cs8900_isr(void *);
>   char g_enetbuf[1520];
> +static void cs8900_isr(void *arg)
> -    cs8900_interrupt(BSP_EINT3, g_cs);
> +    cs8900_interrupt(BSP_EINT3, arg);
>   /* cs8900_io_set_reg - set one of the I/O addressed registers */
> @@ -64,14 +63,13 @@ unsigned short cs8900_mem_get_reg (cs8900_device *cs, unsigned long reg)
>   void cs8900_attach_interrupt (cs8900_device *cs)
>       rtems_status_code status = RTEMS_SUCCESSFUL;
> -    g_cs = cs;
>       status = rtems_interrupt_handler_install(
>           BSP_EINT3,
>           "Network",
>           RTEMS_INTERRUPT_UNIQUE,
>           cs8900_isr,
> -        NULL
> +        cs
>       assert(status == RTEMS_SUCCESSFUL);
> @@ -83,7 +81,7 @@ void cs8900_detach_interrupt (cs8900_device *cs)
>       status = rtems_interrupt_handler_remove(
>           BSP_EINT3,
>           cs8900_isr,
> -        NULL
> +        cs
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
