[PATCH] Updated legacy code in arm edb7312
Mon Jul 15 11:06:26 UTC 2013
On 07/15/2013 12:48 PM, Vipul Nayyar wrote:
> I'll keep that in mind to closely look for warnings & errors while sending
> patches. But I might also add, that warnings for unused functions might be
> present in my patches, since you suggested to remove unused functions, if
> they're affected by change in API methods. Well, from what I saw, the warnings
> for unused functions encountered are not due to the work I'm doing. So, either
> I can stop touching those functions(& a couple of warnings will stay there), or
> remove all of these inter-related functions from the file. What say ?
If you have to touch a file, then you can also remove the warnings already present.
> I'll remove the clock_driver_get_nanoseconds_since_last_tick() function & the
> Clock_driver_nanoseconds_since_last_tick macro  in edb7312.
Ok.
> Is there a need to
> modify the clockdrv_shell.h file ?
I hope not.
Phone   : +49 89 189 47 41-16
Fax     : +49 89 189 47 41-09
