[PATCH 1/6] New atomic API definition based on C11 atomic
Deng Hengyi wei.a.yang at gmail.com
Mon Jul 15 13:58:35 UTC 2013
Yeah, If the patch is ok, i will update all other architectures. And i will firstly test whether the compiler is ok. Acctually i have updated all the architectures. But when i test sparc there is some error. So i will modify and submit ASAP.
在 2013-7-15,下午7:29,Sebastian Huber <sebastian.huber at embedded-brains.de> 写道:
> This looks good.  Do you have to update now cpuatomic.h of all architectures to avoid compile time errors after this API change?
> rtems-devel mailing list
> rtems-devel at rtems.org
