[PATCH 4/6] spatomic test case update
Deng Hengyi wei.a.yang at gmail.com
Mon Jul 15 14:19:15 UTC 2013
But we can consider remove them later after a new test case has been designed.
在 2013-7-15,下午10:00,Deng Hengyi <wei.a.yang at gmail.com> 写道:
> In my opinion the spatomic test cases can be removed because of new atomic implementation will not support UP mode.
> 在 2013-7-15,下午7:30,Sebastian Huber <sebastian.huber at embedded-brains.de> 写道:
>> What is the difference between the atomic tests in sptests and smptests?  Do we really need both?
>> Sebastian Huber, embedded brains GmbH
>> Address : Dornierstr. 4, D-82178 Puchheim, Germany
>> Phone   : +49 89 189 47 41-16
>> Fax     : +49 89 189 47 41-09
>> E-Mail  : sebastian.huber at embedded-brains.de
>> PGP     : Public key available on request.
>> Diese Nachricht ist keine geschäftliche Mitteilung im Sinne des EHUG.
>> rtems-devel mailing list
>> rtems-devel at rtems.org
>> http://www.rtems.org/mailman/listinfo/rtems-devel
