[PATCH 7/7] clean up old atomic related files
WeiY wei.a.yang at gmail.com
Mon Jul 15 15:31:14 UTC 2013
 cpukit/score/Makefile.am                           |    3 -
 .../score/include/rtems/score/genericatomicops.h   |  274 -----------
 .../score/include/rtems/score/genericcpuatomic.h   |   62 ---
 cpukit/score/inline/rtems/score/atomic.inl         |  496 --------------------
 cpukit/score/preinstall.am                         |   12 -
 5 files changed, 847 deletions(-)
 delete mode 100644 cpukit/score/include/rtems/score/genericatomicops.h
 delete mode 100644 cpukit/score/include/rtems/score/genericcpuatomic.h
 delete mode 100644 cpukit/score/inline/rtems/score/atomic.inl
diff --git a/cpukit/score/Makefile.am b/cpukit/score/Makefile.am
index 338c797..793d840 100644
--- a/cpukit/score/Makefile.am
+++ b/cpukit/score/Makefile.am
@@ -62,8 +62,6 @@ include_rtems_score_HEADERS += include/rtems/score/cpuopts.h
 include_rtems_score_HEADERS += include/rtems/score/basedefs.h
 if ATOMIC
 include_rtems_score_HEADERS += include/rtems/score/atomic.h
-include_rtems_score_HEADERS += include/rtems/score/genericcpuatomic.h
-include_rtems_score_HEADERS += include/rtems/score/genericatomicops.h
 include_rtems_score_HEADERS += include/rtems/score/cpustdatomic.h
 endif
@@ -109,7 +107,6 @@ include_rtems_score_HEADERS += inline/rtems/score/tod.inl
 include_rtems_score_HEADERS += inline/rtems/score/tqdata.inl
 include_rtems_score_HEADERS += inline/rtems/score/watchdog.inl
 include_rtems_score_HEADERS += inline/rtems/score/wkspace.inl
-include_rtems_score_HEADERS += inline/rtems/score/atomic.inl
 if HAS_PTHREADS
 include_rtems_score_HEADERS += inline/rtems/score/corespinlock.inl
diff --git a/cpukit/score/include/rtems/score/genericatomicops.h b/cpukit/score/include/rtems/score/genericatomicops.h
deleted file mode 100644
index a6c09d3..0000000
--- a/cpukit/score/include/rtems/score/genericatomicops.h
+++ /dev/null
@@ -1,274 +0,0 @@
- * @file  rtems/score/genericatomicops.h
- * This include file includes the general atomic functions
- * for all the uniprocessors or working in UP mode architectures.
- * If the architecture is working at the UP mode, the atomic
- * operations will be simulated by disable/enable-irq functions.
- * Supposing that if the macro "RTEMS_SMP" is defined it works
- * in SMP mode, otherwise UP mode.
- * COPYRIGHT (c) 2013 Deng Hengyi.
- * The license and distribution terms for this file may be
- * found in the file LICENSE in this distribution or at
-#ifndef _RTEMS_SCORE_GENERAL_ATOMIC_OPS_H
-#define _RTEMS_SCORE_GEMERAL_ATOMIC_OPS_H
-#include <rtems/score/genericcpuatomic.h>
-#include <rtems/score/isr.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup RTEMS generic UP atomic implementation
- * @brief Atomically load an atomic type value from address @a address.
-#define ATOMIC_LOAD(NAME, TYPE)                                      \
-RTEMS_INLINE_ROUTINE Atomic_##TYPE _CPU_Atomic_Load_##NAME(	     \
-  volatile Atomic_##TYPE *address                                    \
-  Atomic_##TYPE  tmp;                                                \
-  ISR_Level   level;                                                 \
-  _ISR_Disable( level );                                             \
-  tmp = *address;                                                    \
-  _ISR_Enable( level );                                              \
-  return tmp;                                                        \
-ATOMIC_LOAD(int, Int);
-ATOMIC_LOAD(acq_int, Int);
-ATOMIC_LOAD(long, Long);
-ATOMIC_LOAD(acq_long, Long);
-ATOMIC_LOAD(ptr, Pointer);
-ATOMIC_LOAD(acq_ptr, Pointer);
-ATOMIC_LOAD(32, Int32);
-ATOMIC_LOAD(acq_32, Int32);
-ATOMIC_LOAD(64, Int64);
-ATOMIC_LOAD(acq_64, Int64);
- * @brief Atomically store an atomic type value @a value into address @a
- * address.
-#define ATOMIC_STORE(NAME, TYPE)                                     \
-RTEMS_INLINE_ROUTINE void _CPU_Atomic_Store_##NAME(	             \
-  volatile Atomic_##TYPE *address,                                   \
-  Atomic_##TYPE value                                                \
-  *address = value;                                                  \
-ATOMIC_STORE(int, Int);
-ATOMIC_STORE(rel_int, Int);
-ATOMIC_STORE(long, Long);
-ATOMIC_STORE(rel_long, Long);
-ATOMIC_STORE(ptr, Pointer);
-ATOMIC_STORE(rel_ptr, Pointer);
-ATOMIC_STORE(32, Int32);
-ATOMIC_STORE(rel_32, Int32);
-ATOMIC_STORE(64, Int64);
-ATOMIC_STORE(rel_64, Int64);
- * @brief Atomically load-add-store an atomic type value @a value into address
- * @a address.
-#define ATOMIC_FETCH_ADD(NAME, TYPE)                                 \
-RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_add_##NAME(	             \
-  *address += value;                                                 \
-ATOMIC_FETCH_ADD(int, Int);
-ATOMIC_FETCH_ADD(acq_int, Int);
-ATOMIC_FETCH_ADD(rel_int, Int);
-ATOMIC_FETCH_ADD(long, Long);
-ATOMIC_FETCH_ADD(acq_long, Long);
-ATOMIC_FETCH_ADD(rel_long, Long);
-ATOMIC_FETCH_ADD(ptr, Pointer);
-ATOMIC_FETCH_ADD(acq_ptr, Pointer);
-ATOMIC_FETCH_ADD(rel_ptr, Pointer);
-ATOMIC_FETCH_ADD(32, Int32);
-ATOMIC_FETCH_ADD(acq_32, Int32);
-ATOMIC_FETCH_ADD(rel_32, Int32);
-ATOMIC_FETCH_ADD(64, Int64);
-ATOMIC_FETCH_ADD(acq_64, Int64);
-ATOMIC_FETCH_ADD(rel_64, Int64);
- * @brief Atomically load-sub-store an atomic type value @a value into address
- * @a address.
-#define ATOMIC_FETCH_SUB(NAME, TYPE)                                 \
-RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_sub_##NAME(	             \
-  *address -= value;                                                 \
-ATOMIC_FETCH_SUB(int, Int);
-ATOMIC_FETCH_SUB(acq_int, Int);
-ATOMIC_FETCH_SUB(rel_int, Int);
-ATOMIC_FETCH_SUB(long, Long);
-ATOMIC_FETCH_SUB(acq_long, Long);
-ATOMIC_FETCH_SUB(rel_long, Long);
-ATOMIC_FETCH_SUB(ptr, Pointer);
-ATOMIC_FETCH_SUB(acq_ptr, Pointer);
-ATOMIC_FETCH_SUB(rel_ptr, Pointer);
-ATOMIC_FETCH_SUB(32, Int32);
-ATOMIC_FETCH_SUB(acq_32, Int32);
-ATOMIC_FETCH_SUB(rel_32, Int32);
-ATOMIC_FETCH_SUB(64, Int64);
-ATOMIC_FETCH_SUB(acq_64, Int64);
-ATOMIC_FETCH_SUB(rel_64, Int64);
- * @brief Atomically load-or-store an atomic type value @a value into address
- * @a address.
-#define ATOMIC_FETCH_OR(NAME, TYPE)                                  \
-RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_or_##NAME(	             \
-  *address |= value;                                                 \
-ATOMIC_FETCH_OR(int, Int);
-ATOMIC_FETCH_OR(acq_int, Int);
-ATOMIC_FETCH_OR(rel_int, Int);
-ATOMIC_FETCH_OR(long, Long);
-ATOMIC_FETCH_OR(acq_long, Long);
-ATOMIC_FETCH_OR(rel_long, Long);
-ATOMIC_FETCH_OR(ptr, Pointer);
-ATOMIC_FETCH_OR(acq_ptr, Pointer);
-ATOMIC_FETCH_OR(rel_ptr, Pointer);
-ATOMIC_FETCH_OR(32, Int32);
-ATOMIC_FETCH_OR(acq_32, Int32);
-ATOMIC_FETCH_OR(rel_32, Int32);
-ATOMIC_FETCH_OR(64, Int64);
-ATOMIC_FETCH_OR(acq_64, Int64);
-ATOMIC_FETCH_OR(rel_64, Int64);
- * @brief Atomically load-and-store an atomic type value @a value into address
- * @a address.
-#define ATOMIC_FETCH_AND(NAME, TYPE)                                 \
-RTEMS_INLINE_ROUTINE void _CPU_Atomic_Fetch_and_##NAME(	             \
-  *address &= value;                                                 \
-ATOMIC_FETCH_AND(int, Int);
-ATOMIC_FETCH_AND(acq_int, Int);
-ATOMIC_FETCH_AND(rel_int, Int);
-ATOMIC_FETCH_AND(long, Long);
-ATOMIC_FETCH_AND(acq_long, Long);
-ATOMIC_FETCH_AND(rel_long, Long);
-ATOMIC_FETCH_AND(ptr, Pointer);
-ATOMIC_FETCH_AND(acq_ptr, Pointer);
-ATOMIC_FETCH_AND(rel_ptr, Pointer);
-ATOMIC_FETCH_AND(32, Int32);
-ATOMIC_FETCH_AND(acq_32, Int32);
-ATOMIC_FETCH_AND(rel_32, Int32);
-ATOMIC_FETCH_AND(64, Int64);
-ATOMIC_FETCH_AND(acq_64, Int64);
-ATOMIC_FETCH_AND(rel_64, Int64);
- * @brief Atomically compare the value stored at @a address with @a
- * old_value and if the two values are equal, update the value of @a
- * address with @a new_value. Returns zero if the compare failed,
- * nonzero otherwise.
-#define ATOMIC_COMPARE_EXCHANGE(NAME, TYPE)                          \
-RTEMS_INLINE_ROUTINE int _CPU_Atomic_Compare_exchange_##NAME(        \
-  Atomic_##TYPE old_value,                                           \
-  Atomic_##TYPE new_value                                            \
-  int ret;                                                           \
-  if (*address == old_value) {                                       \
-    *address = new_value;                                            \
-    ret = TRUE;                                                      \
-  } else {                                                           \
-    ret = FALSE;                                                     \
-  return ret;                                                        \
-ATOMIC_COMPARE_EXCHANGE(int, Int);
-ATOMIC_COMPARE_EXCHANGE(acq_int, Int);
-ATOMIC_COMPARE_EXCHANGE(rel_int, Int);
-ATOMIC_COMPARE_EXCHANGE(long, Long);
-ATOMIC_COMPARE_EXCHANGE(acq_long, Long);
-ATOMIC_COMPARE_EXCHANGE(rel_long, Long);
-ATOMIC_COMPARE_EXCHANGE(ptr, Pointer);
-ATOMIC_COMPARE_EXCHANGE(acq_ptr, Pointer);
-ATOMIC_COMPARE_EXCHANGE(rel_ptr, Pointer);
-ATOMIC_COMPARE_EXCHANGE(32, Int32);
-ATOMIC_COMPARE_EXCHANGE(acq_32, Int32);
-ATOMIC_COMPARE_EXCHANGE(rel_32, Int32);
-ATOMIC_COMPARE_EXCHANGE(64, Int64);
-ATOMIC_COMPARE_EXCHANGE(acq_64, Int64);
-ATOMIC_COMPARE_EXCHANGE(rel_64, Int64);
-#ifdef __cplusplus
-#endif
-#endif
-/*  end of include file */
diff --git a/cpukit/score/include/rtems/score/genericcpuatomic.h b/cpukit/score/include/rtems/score/genericcpuatomic.h
index 2599d0d..0000000
--- a/cpukit/score/include/rtems/score/genericcpuatomic.h
+++ /dev/null
@@ -1,62 +0,0 @@
- * @file  rtems/score/genericcpuatomic.h
- * This include file includes the general atomic data type
- * for all the architecture.
- * COPYRIGHT (c) 2012 Deng Hengyi.
-#ifndef _RTEMS_SCORE_GENERAL_ATOMIC_CPU_H
-#define _RTEMS_SCORE_GEMERAL_ATOMIC_CPU_H
-#include <stdint.h>
-#ifdef __cplusplus
-extern "C" {
-#endif
- * @defgroup RTEMS general atomic data type
- * @brief atomic operation unsigned integer type
-typedef unsigned int Atomic_Int;
- * @brief atomic operation unsigned long integer type
-typedef unsigned long Atomic_Long;
- * @brief atomic operation unsigned 32-bit integer type
-typedef uint32_t Atomic_Int32;
- * @brief atomic operation unsigned 64-bit integer type
-typedef uint64_t Atomic_Int64;
- * @brief atomic operation unsigned integer the size of a pointer type
-typedef uintptr_t Atomic_Pointer;
-#ifdef __cplusplus
-#endif
-#endif
diff --git a/cpukit/score/inline/rtems/score/atomic.inl b/cpukit/score/inline/rtems/score/atomic.inl
index 313366c..0000000
--- a/cpukit/score/inline/rtems/score/atomic.inl
+++ /dev/null
@@ -1,496 +0,0 @@
- *  Atomic Manager
- *  http://www.rtems.com/license/LICENSE.
- *  The functions in this file implement the API to the RTEMS Atomic Manager and
- *  The API is designed to be compatable with C1X atomic definition as far as
- *  possible. And its implementation reuses the FreeBSD kernel atomic operation.
- *  The functions below are implemented with CPU dependent inline routines
- *  found in the path
- *  rtems/cpukit/score/cpu/xxx/rtems/score/cpuatomic.h
- *  In the event that a CPU does not support a specific atomic function it has,
- *  the CPU dependent routine does nothing (but does exist).
-#ifndef _RTEMS_SCORE_ATOMIC_H
-# error "Never use <rtems/score/atomic.inl> directly; include <rtems/score/atomic.h> instead."
-#endif
-#include <rtems/score/types.h>
-#ifndef _RTEMS_SCORE_ATOMIC_INL
-#define _RTEMS_SCORE_ATOMIC_INL
-RTEMS_INLINE_ROUTINE Atomic_Int _Atomic_Load_int(
-  volatile Atomic_Int *address,
-  Atomic_Memory_barrier memory_barrier
-  if(ATOMIC_ACQUIRE_BARRIER == memory_barrier)
-    return _CPU_Atomic_Load_acq_int(address);
-  return _CPU_Atomic_Load_int(address);
-RTEMS_INLINE_ROUTINE Atomic_Long _Atomic_Load_long(
-  volatile Atomic_Long *address,
-  if (ATOMIC_ACQUIRE_BARRIER == memory_barrier)
-    return _CPU_Atomic_Load_acq_long(address);
-  return _CPU_Atomic_Load_long(address);
-RTEMS_INLINE_ROUTINE Atomic_Pointer _Atomic_Load_ptr(
-  volatile Atomic_Pointer *address,
-    return _CPU_Atomic_Load_acq_ptr(address);
-  return _CPU_Atomic_Load_ptr(address);
-RTEMS_INLINE_ROUTINE Atomic_Int32 _Atomic_Load_32(
-  volatile Atomic_Int32 *address,
-    return _CPU_Atomic_Load_acq_32(address);
-  return _CPU_Atomic_Load_32(address);
-RTEMS_INLINE_ROUTINE Atomic_Int64 _Atomic_Load_64(
-  volatile Atomic_Int64 *address,
-    return _CPU_Atomic_Load_acq_64(address);
-  return _CPU_Atomic_Load_64(address);
-RTEMS_INLINE_ROUTINE void _Atomic_Store_int(
-  Atomic_Int value,
-  if (ATOMIC_RELEASE_BARRIER == memory_barrier)
-    return _CPU_Atomic_Store_rel_int(address, value);
-  return _CPU_Atomic_Store_int(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Store_long(
-  Atomic_Long value,
-    return _CPU_Atomic_Store_rel_long(address, value);
-  return _CPU_Atomic_Store_long(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Store_ptr(
-  Atomic_Pointer value,
-    return _CPU_Atomic_Store_rel_ptr(address, value);
-  return _CPU_Atomic_Store_ptr(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Store_32(
-  Atomic_Int32 value,
-    return _CPU_Atomic_Store_rel_32(address, value);
-  return _CPU_Atomic_Store_32(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Store_64(
-  Atomic_Int64 value,
-    return _CPU_Atomic_Store_rel_64(address, value);
-  return _CPU_Atomic_Store_64(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_int(
-  Atomic_Int value,
-    return _CPU_Atomic_Fetch_add_acq_int(address, value);
-  else if (ATOMIC_RELEASE_BARRIER == memory_barrier)
-    return _CPU_Atomic_Fetch_add_rel_int(address, value);
-  else
-    return _CPU_Atomic_Fetch_add_int(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_long(
-    return _CPU_Atomic_Fetch_add_acq_long(address, value);
-    return _CPU_Atomic_Fetch_add_rel_long(address, value);
-  else
-    return _CPU_Atomic_Fetch_add_long(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_ptr(
-    return _CPU_Atomic_Fetch_add_acq_ptr(address, value);
-    return _CPU_Atomic_Fetch_add_rel_ptr(address, value);
-  else
-    return _CPU_Atomic_Fetch_add_ptr(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_32(
-    return _CPU_Atomic_Fetch_add_acq_32(address, value);
-    return _CPU_Atomic_Fetch_add_rel_32(address, value);
-  else
-    return _CPU_Atomic_Fetch_add_32(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_add_64(
-    return _CPU_Atomic_Fetch_add_acq_64(address, value);
-    return _CPU_Atomic_Fetch_add_rel_64(address, value);
-  else
-    return _CPU_Atomic_Fetch_add_64(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_int(
-  Atomic_Int value,
-    return _CPU_Atomic_Fetch_sub_acq_int(address, value);
-    return _CPU_Atomic_Fetch_sub_rel_int(address, value);
-  else
-    return _CPU_Atomic_Fetch_sub_int(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_long(
-    return _CPU_Atomic_Fetch_sub_acq_long(address, value);
-    return _CPU_Atomic_Fetch_sub_rel_long(address, value);
-  else
-    return _CPU_Atomic_Fetch_sub_long(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_ptr(
-    return _CPU_Atomic_Fetch_sub_acq_ptr(address, value);
-    return _CPU_Atomic_Fetch_sub_rel_ptr(address, value);
-  else
-    return _CPU_Atomic_Fetch_sub_ptr(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_32(
-    return _CPU_Atomic_Fetch_sub_acq_32(address, value);
-    return _CPU_Atomic_Fetch_sub_rel_32(address, value);
-  else
-    return _CPU_Atomic_Fetch_sub_32(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_sub_64(
-    return _CPU_Atomic_Fetch_sub_acq_64(address, value);
-    return _CPU_Atomic_Fetch_sub_rel_64(address, value);
-  else
-    return _CPU_Atomic_Fetch_sub_64(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_int(
-  Atomic_Int value,
-    return _CPU_Atomic_Fetch_or_acq_int(address, value);
-    return _CPU_Atomic_Fetch_or_rel_int(address, value);
-  else
-    return _CPU_Atomic_Fetch_or_int(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_long(
-    return _CPU_Atomic_Fetch_or_acq_long(address, value);
-    return _CPU_Atomic_Fetch_or_rel_long(address, value);
-  else
-    return _CPU_Atomic_Fetch_or_long(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_ptr(
-    return _CPU_Atomic_Fetch_or_acq_ptr(address, value);
-    return _CPU_Atomic_Fetch_or_rel_ptr(address, value);
-  else
-    return _CPU_Atomic_Fetch_or_ptr(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_32(
-    return _CPU_Atomic_Fetch_or_acq_32(address, value);
-    return _CPU_Atomic_Fetch_or_rel_32(address, value);
-  else
-    return _CPU_Atomic_Fetch_or_32(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_or_64(
-    return _CPU_Atomic_Fetch_or_acq_64(address, value);
-    return _CPU_Atomic_Fetch_or_rel_64(address, value);
-  else
-    return _CPU_Atomic_Fetch_or_64(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_int(
-  Atomic_Int value,
-    return _CPU_Atomic_Fetch_and_acq_int(address, value);
-    return _CPU_Atomic_Fetch_and_rel_int(address, value);
-  else
-    return _CPU_Atomic_Fetch_and_int(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_long(
-    return _CPU_Atomic_Fetch_and_acq_long(address, value);
-    return _CPU_Atomic_Fetch_and_rel_long(address, value);
-  else
-    return _CPU_Atomic_Fetch_and_long(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_ptr(
-    return _CPU_Atomic_Fetch_and_acq_ptr(address, value);
-    return _CPU_Atomic_Fetch_and_rel_ptr(address, value);
-  else
-    return _CPU_Atomic_Fetch_and_ptr(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_32(
-    return _CPU_Atomic_Fetch_and_acq_32(address, value);
-    return _CPU_Atomic_Fetch_and_rel_32(address, value);
-  else
-    return _CPU_Atomic_Fetch_and_32(address, value);
-RTEMS_INLINE_ROUTINE void _Atomic_Fetch_and_64(
-    return _CPU_Atomic_Fetch_and_acq_64(address, value);
-    return _CPU_Atomic_Fetch_and_rel_64(address, value);
-  else
-    return _CPU_Atomic_Fetch_and_64(address, value);
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_int(
-  Atomic_Int old_value,
-  Atomic_Int new_value,
-    return _CPU_Atomic_Compare_exchange_acq_int(address, old_value, new_value);
-    return _CPU_Atomic_Compare_exchange_rel_int(address, old_value, new_value);
-  else
-    return _CPU_Atomic_Compare_exchange_int(address, old_value, new_value);
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_long(
-  Atomic_Long old_value,
-  Atomic_Long new_value,
-    return _CPU_Atomic_Compare_exchange_acq_long(address, old_value, new_value);
-    return _CPU_Atomic_Compare_exchange_rel_long(address, old_value, new_value);
-  else
-    return _CPU_Atomic_Compare_exchange_long(address, old_value, new_value);
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_ptr(
-  Atomic_Pointer old_value,
-  Atomic_Pointer new_value,
-    return _CPU_Atomic_Compare_exchange_acq_ptr(address, old_value, new_value);
-    return _CPU_Atomic_Compare_exchange_rel_ptr(address, old_value, new_value);
-  else
-    return _CPU_Atomic_Compare_exchange_ptr(address, old_value, new_value);
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_32(
-  Atomic_Int32 old_value,
-  Atomic_Int32 new_value,
-    return _CPU_Atomic_Compare_exchange_acq_32(address, old_value, new_value);
-    return _CPU_Atomic_Compare_exchange_rel_32(address, old_value, new_value);
-  else
-    return _CPU_Atomic_Compare_exchange_32(address, old_value, new_value);
-RTEMS_INLINE_ROUTINE int _Atomic_Compare_exchange_64(
-  Atomic_Int64 old_value,
-  Atomic_Int64 new_value,
-    return _CPU_Atomic_Compare_exchange_acq_64(address, old_value, new_value);
-    return _CPU_Atomic_Compare_exchange_rel_64(address, old_value, new_value);
-  else
-    return _CPU_Atomic_Compare_exchange_64(address, old_value, new_value);
-#endif
diff --git a/cpukit/score/preinstall.am b/cpukit/score/preinstall.am
index a48d21e..130be84 100644
--- a/cpukit/score/preinstall.am
+++ b/cpukit/score/preinstall.am
@@ -228,14 +228,6 @@ $(PROJECT_INCLUDE)/rtems/score/atomic.h: include/rtems/score/atomic.h $(PROJECT_
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/atomic.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/atomic.h
-$(PROJECT_INCLUDE)/rtems/score/genericcpuatomic.h: include/rtems/score/genericcpuatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/genericcpuatomic.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/genericcpuatomic.h
-$(PROJECT_INCLUDE)/rtems/score/genericatomicops.h: include/rtems/score/genericatomicops.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/genericatomicops.h
 $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h: include/rtems/score/cpustdatomic.h $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/cpustdatomic.h
@@ -367,10 +359,6 @@ $(PROJECT_INCLUDE)/rtems/score/wkspace.inl: inline/rtems/score/wkspace.inl $(PRO
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/wkspace.inl
 PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/wkspace.inl
-$(PROJECT_INCLUDE)/rtems/score/atomic.inl: inline/rtems/score/atomic.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
-	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/atomic.inl
-PREINSTALL_FILES += $(PROJECT_INCLUDE)/rtems/score/atomic.inl
 if HAS_PTHREADS
 $(PROJECT_INCLUDE)/rtems/score/corespinlock.inl: inline/rtems/score/corespinlock.inl $(PROJECT_INCLUDE)/rtems/score/$(dirstamp)
 	$(INSTALL_DATA) $< $(PROJECT_INCLUDE)/rtems/score/corespinlock.inl
1.7.9.5
