BSP lm3s6965 broken
Mon Jul 15 15:56:55 UTC 2013
On 7/15/2013 10:45 AM, emanuel stiebler wrote:
> On 2013-07-15 02:36, Sebastian Huber wrote:> I don't get a build error.
>    What is the error in your case?
>   >> gmake[2]: *** No rule to make target `all'.  Stop.
> And it stops, not building anything ...
I just built it.
../rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp=lm3s6965 \
   --disable-posix \
   --enable-networking \
   --prefix=/home/rtems/rtems-4.11-work/bsp-install \
   --enable-tests=samples >c.log 2>&1 && \
make >b.log 2>&1
Was there something in the configure output that wasn't right?
> rtems-devel mailing list
> rtems-devel at rtems.org
