BSP lm3s6965 broken
emanuel stiebler emu at e-bbes.com
Mon Jul 15 16:18:08 UTC 2013
On 2013-07-15 09:56, Joel Sherrill wrote:
> On 7/15/2013 10:45 AM, emanuel stiebler wrote:
>> On 2013-07-15 02:36, Sebastian Huber wrote:> I don't get a build error.
>>    What is the error in your case?
>>   >> gmake[2]: *** No rule to make target `all'.  Stop.
>> And it stops, not building anything ...
> I just built it.
> ../rtems/configure --target=arm-rtems4.11 --enable-rtemsbsp=lm3s6965 \
>    --disable-posix \
>    --enable-networking \
>    --prefix=/home/rtems/rtems-4.11-work/bsp-install \
>    --enable-tests=samples >c.log 2>&1 && \
> make >b.log 2>&1
> Was there something in the configure output that wasn't right?
No, I don't remember seeing any warnings. But after deleting my whole
tree, and cloning again a fresh copy it works again.
BTW, yesterday after a compile, the hello.exe and hello.ralf were the
same file. Today with the fresh clone, it is correctly made into a
binary version of .exe ...
Cheers & Thanks
