[GSOC] Help regarding pc386 3c509.c file
Joel Sherrill
joel.sherrill at OARcorp.com
Mon Jul 15 16:50:39 UTC 2013
On 7/15/2013 11:47 AM, Vipul Nayyar wrote:
> Hello,
> I'm currently working on i386 pc386 BSP. This problem concerns the
> 3c509/3c509.c file.
> After turning rtems_3c509_driver_attach() from global to static, since
> it's not being used anywhere outside in the tree, I get this warning
> for unused function. Ideally I should delete it. If I delete it, then
> I end up deleting all other functions also. But this
> rtems_3c509_driver_attach() stores references to different handlers &
> calls them by passing a ifnet structure to if_attach(). I think it's a
> very important method & I don't think I should delete it.
This is the primary entry point to the driver. It is configured by the
user when they want to use this.
I think XXX_attach methods must stay global with the current network
stack.
> But this function rtems_3c509_driver_attach() is neither called
> locally , nor globally.
> If I were to treat it as global function, I think it should be
> declared in a header file, because declaring a global function locally
> seems bad.
> If I were to treat it as static, then I get this warning of unused
> function during compilation. How should I proceed ?
It should be in a global .h file and likely the only candidate in this
case is the bsp.h for the pc386.
> Regards
> Vipul Nayyar
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130715/02aca40f/attachment.html>
