[PATCH 2/4] Add cpukit shared libmm header and stubs
Hesham Moustafa
heshamelmatary at gmail.com
Thu Jul 18 03:13:18 UTC 2013
On Mon, Jul 15, 2013 at 4:22 PM, Gedare Bloom <gedare at rtems.org> wrote:
> Are there compiler function attributes that can limit code generation
> when stubs are used?
> I searched for GCC functions attributes and found that there are some
function attributes that may be used for that purpose but not sure about
that. These attributes are :
cold :
The cold attribute on functions is used to inform the compiler that the
function is unlikely to be executed. The function is optimized for size
rather than speed and on many targets it is placed into special subsection
of the text section so all cold functions appears close together improving
code locality of non-cold parts of program.
optimize:
The optimize attribute is used to specify that a function is to be compiled
with different optimization options than specified on the command line.
unused :
This attribute, attached to a function, means that the function is meant to
be possibly unused. GCC does not produce a warning for this function.
for more details check [1]
[1] http://gcc.gnu.org/onlinedocs/gcc/Function-Attributes.html
On Sat, Jul 13, 2013 at 7:05 PM, Hesham AL-Matary
> <heshamelmatary at gmail.com> wrote:
> > From: Hesham ALmatary <heshamelmatary at gmail.com>
> > c/src/lib/libcpu/shared/include/mm.h | 23
> > c/src/lib/libcpu/shared/src/no_memorymanagement.c | 17 +++++++++++++++++
> > 2 files changed, 40 insertions(+)
> > create mode 100644 c/src/lib/libcpu/shared/include/mm.h
> > create mode 100644 c/src/lib/libcpu/shared/src/no_memorymanagement.c
> > diff --git a/c/src/lib/libcpu/shared/include/mm.h
> b/c/src/lib/libcpu/shared/include/mm.h
> > new file mode 100644
> > index 0000000..02903f1
> > --- /dev/null
> > +++ b/c/src/lib/libcpu/shared/include/mm.h
> > @@ -0,0 +1,23 @@
> > + * Copyright (c) 2013 Gedare Bloom.
> > + * The license and distribution terms for this file may be
> > + * found in the file LICENSE in this distribution or at
> > + * http://www.rtems.com/license/LICENSE.
> > +#ifndef __LIBCPU_MM_H
> > +#define __LIBCPU_MM_H
> > +#include <rtems/score/mm.h>
> > +#ifdef __cplusplus
> > +extern "C" {
> > +#endif
> > +void _CPU_Memory_management_Initialize(void);
> > +#ifdef __cplusplus
> > +#endif
> > +#endif
> > diff --git a/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> > index 0000000..2e3f528
> > --- /dev/null
> > +++ b/c/src/lib/libcpu/shared/src/no_memorymanagement.c
> > @@ -0,0 +1,17 @@
> > + * Copyright (c) 2013 Hesham AL-Matary
> > +#include <rtems.h>
> > +#include <libcpu/mm.h>
> > +void _CPU_Memory_management_Initialize( void ) { }
> > +void _CPU_Memory_management_Install_entry( Memory_management_Entry
> *mpe, uint32_t flags ) { }
> > +void _CPU_Memory_management_Uninstall_entry( Memory_management_Entry
> *mpe ) { }
> > 1.8.3.1
> > rtems-devel mailing list
> > rtems-devel at rtems.org
> > http://www.rtems.org/mailman/listinfo/rtems-devel
URL: <http://lists.rtems.org/pipermail/devel/attachments/20130718/0a4ac170/attachment.html>
