[PATCH 14/25] rtems: Error for task variables on SMP
Thu Jul 18 14:26:02 UTC 2013
Task variables are not supported on SMP.
 cpukit/rtems/src/taskvariableadd.c          |    7 +++++++
 cpukit/rtems/src/taskvariabledelete.c       |    7 +++++++
 cpukit/rtems/src/taskvariableget.c          |    7 +++++++
 testsuites/smptests/smpunsupported01/init.c |    9 +++++++++
 4 files changed, 30 insertions(+), 0 deletions(-)
diff --git a/cpukit/rtems/src/taskvariableadd.c b/cpukit/rtems/src/taskvariableadd.c
index 7e03b66..5443bf2 100644
--- a/cpukit/rtems/src/taskvariableadd.c
+++ b/cpukit/rtems/src/taskvariableadd.c
@@ -19,6 +19,7 @@
 #endif
+#include <rtems/config.h>
@@ -32,6 +33,12 @@ rtems_status_code rtems_task_variable_add(
   Objects_Locations      location;
   rtems_task_variable_t *tvp, *new;
+#if defined( RTEMS_SMP )
+  if ( rtems_configuration_is_smp_enabled() ) {
+    return RTEMS_NOT_IMPLEMENTED;
+#endif
   if ( !ptr )
     return RTEMS_INVALID_ADDRESS;
diff --git a/cpukit/rtems/src/taskvariabledelete.c b/cpukit/rtems/src/taskvariabledelete.c
index 02f2bf0..65efecb 100644
--- a/cpukit/rtems/src/taskvariabledelete.c
+++ b/cpukit/rtems/src/taskvariabledelete.c
@@ -19,6 +19,7 @@
 #endif
@@ -31,6 +32,12 @@ rtems_status_code rtems_task_variable_delete(
   rtems_task_variable_t *tvp, *prev;
+#endif
   if ( !ptr )
diff --git a/cpukit/rtems/src/taskvariableget.c b/cpukit/rtems/src/taskvariableget.c
index 338e108..c1524a4 100644
--- a/cpukit/rtems/src/taskvariableget.c
+++ b/cpukit/rtems/src/taskvariableget.c
@@ -19,6 +19,7 @@
 #endif
@@ -38,6 +39,12 @@ rtems_status_code rtems_task_variable_get(
   rtems_task_variable_t *tvp;
+#endif
   if ( !ptr )
diff --git a/testsuites/smptests/smpunsupported01/init.c b/testsuites/smptests/smpunsupported01/init.c
index 3724cd4..3379de6 100644
--- a/testsuites/smptests/smpunsupported01/init.c
+++ b/testsuites/smptests/smpunsupported01/init.c
@@ -26,6 +26,15 @@ static void test(void)
   sc = rtems_task_delete(RTEMS_SELF);
   rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
+  sc = rtems_task_variable_add(RTEMS_SELF, NULL, NULL);
+  rtems_test_assert(sc == RTEMS_NOT_IMPLEMENTED);
+  sc = rtems_task_variable_delete(RTEMS_SELF, NULL);
+  sc = rtems_task_variable_get(RTEMS_SELF, NULL, NULL);
 static void Init(rtems_task_argument arg)
1.7.7
