[PATCH 25/25] score: Avoid direct usage of _Thread_Executing
Thu Jul 18 14:26:13 UTC 2013
Pass the executing thread as a function parameter.  Obtain the executing
thread inside a thread dispatch critical section to avoid problems on
SMP.
 cpukit/posix/src/mqueuerecvsupp.c              |    9 ++++++---
 cpukit/posix/src/mqueuesendsupp.c              |    5 ++++-
 cpukit/rtems/src/msgqreceive.c                 |    5 ++++-
 cpukit/score/include/rtems/score/coremsgimpl.h |    4 ++++
 cpukit/score/src/coremsgseize.c                |    5 ++---
 cpukit/score/src/coremsgsubmit.c               |    2 +-
 6 files changed, 21 insertions(+), 9 deletions(-)
diff --git a/cpukit/posix/src/mqueuerecvsupp.c b/cpukit/posix/src/mqueuerecvsupp.c
index 5eb856a..04a75a9 100644
--- a/cpukit/posix/src/mqueuerecvsupp.c
+++ b/cpukit/posix/src/mqueuerecvsupp.c
@@ -53,6 +53,7 @@ ssize_t _POSIX_Message_queue_Receive_support(
   Objects_Locations                location;
   size_t                           length_out;
   bool                             do_wait;
+  Thread_Control                  *executing;
   the_mq_fd = _POSIX_Message_queue_Get_fd( mqdes, &location );
   switch ( location ) {
@@ -88,8 +89,10 @@ ssize_t _POSIX_Message_queue_Receive_support(
        *  Now perform the actual message receive
+      executing = _Thread_Executing;
       _CORE_message_queue_Seize(
         &the_mq->Message_queue,
+        executing,
         mqdes,
         msg_ptr,
         &length_out,
@@ -100,16 +103,16 @@ ssize_t _POSIX_Message_queue_Receive_support(
       _Objects_Put( &the_mq_fd->Object );
       if (msg_prio) {
         *msg_prio = _POSIX_Message_queue_Priority_from_core(
-             _Thread_Executing->Wait.count
+             executing->Wait.count
-      if ( !_Thread_Executing->Wait.return_code )
+      if ( !executing->Wait.return_code )
         return length_out;
       rtems_set_errno_and_return_minus_one(
         _POSIX_Message_queue_Translate_core_message_queue_return_code(
-          _Thread_Executing->Wait.return_code
+          executing->Wait.return_code
diff --git a/cpukit/posix/src/mqueuesendsupp.c b/cpukit/posix/src/mqueuesendsupp.c
index 2b2acb8..7156763 100644
--- a/cpukit/posix/src/mqueuesendsupp.c
+++ b/cpukit/posix/src/mqueuesendsupp.c
@@ -63,6 +63,7 @@ int _POSIX_Message_queue_Send_support(
   CORE_message_queue_Status       msg_status;
   bool                            do_wait;
    * Validate the priority.
@@ -94,8 +95,10 @@ int _POSIX_Message_queue_Send_support(
       msg_status = _CORE_message_queue_Submit(
+        executing,
         msg_ptr,
         msg_len,
         mqdes,      /* mqd_t is an object id */
@@ -115,7 +118,7 @@ int _POSIX_Message_queue_Send_support(
       if ( msg_status == CORE_MESSAGE_QUEUE_STATUS_UNSATISFIED_WAIT )
-        msg_status = _Thread_Executing->Wait.return_code;
+        msg_status = executing->Wait.return_code;
       if ( !msg_status )
         return msg_status;
diff --git a/cpukit/rtems/src/msgqreceive.c b/cpukit/rtems/src/msgqreceive.c
index 265e71e..484cb53 100644
--- a/cpukit/rtems/src/msgqreceive.c
+++ b/cpukit/rtems/src/msgqreceive.c
@@ -47,6 +47,7 @@ rtems_status_code rtems_message_queue_receive(
   register Message_queue_Control *the_message_queue;
   bool                            wait;
   if ( !buffer )
     return RTEMS_INVALID_ADDRESS;
@@ -63,8 +64,10 @@ rtems_status_code rtems_message_queue_receive(
       else
         wait = true;
         &the_message_queue->message_queue,
+        executing,
         the_message_queue->Object.id,
         buffer,
         size,
@@ -73,7 +76,7 @@ rtems_status_code rtems_message_queue_receive(
       _Objects_Put( &the_message_queue->Object );
       return _Message_queue_Translate_core_message_queue_return_code(
 #if defined(RTEMS_MULTIPROCESSING)
diff --git a/cpukit/score/include/rtems/score/coremsgimpl.h b/cpukit/score/include/rtems/score/coremsgimpl.h
index 406a596..f579e63 100644
--- a/cpukit/score/include/rtems/score/coremsgimpl.h
+++ b/cpukit/score/include/rtems/score/coremsgimpl.h
@@ -274,6 +274,7 @@ CORE_message_queue_Status _CORE_message_queue_Broadcast(
 CORE_message_queue_Status _CORE_message_queue_Submit(
   CORE_message_queue_Control                *the_message_queue,
+  Thread_Control                            *executing,
   const void                                *buffer,
   size_t                                     size,
   Objects_Id                                 id,
@@ -320,6 +321,7 @@ CORE_message_queue_Status _CORE_message_queue_Submit(
 void _CORE_message_queue_Seize(
   Objects_Id                       id,
   void                            *buffer,
   size_t                          *size_p,
@@ -363,6 +365,7 @@ RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Send(
   return _CORE_message_queue_Submit(
     the_message_queue,
+    _Thread_Executing,
     buffer,
     size,
     id,
@@ -388,6 +391,7 @@ RTEMS_INLINE_ROUTINE CORE_message_queue_Status _CORE_message_queue_Urgent(
     the_message_queue,
     buffer,
     size,
     id,
diff --git a/cpukit/score/src/coremsgseize.c b/cpukit/score/src/coremsgseize.c
index f0567db..5d64616 100644
--- a/cpukit/score/src/coremsgseize.c
+++ b/cpukit/score/src/coremsgseize.c
@@ -29,6 +29,7 @@
   Objects_Id                       id,
   void                            *buffer,
   size_t                          *size_p,
@@ -38,9 +39,7 @@ void _CORE_message_queue_Seize(
   ISR_Level                          level;
   CORE_message_queue_Buffer_control *the_message;
-  Thread_Control                    *executing;
-  executing = _Thread_Executing;
   executing->Wait.return_code = CORE_MESSAGE_QUEUE_STATUS_SUCCESSFUL;
   _ISR_Disable( level );
   the_message = _CORE_message_queue_Get_pending_message( the_message_queue );
@@ -49,7 +48,7 @@ void _CORE_message_queue_Seize(
     _ISR_Enable( level );
     *size_p = the_message->Contents.size;
-    _Thread_Executing->Wait.count =
+    executing->Wait.count =
       _CORE_message_queue_Get_message_priority( the_message );
     _CORE_message_queue_Copy_buffer(
       the_message->Contents.buffer,
diff --git a/cpukit/score/src/coremsgsubmit.c b/cpukit/score/src/coremsgsubmit.c
index c5e9a6b..6acaada 100644
--- a/cpukit/score/src/coremsgsubmit.c
+++ b/cpukit/score/src/coremsgsubmit.c
@@ -30,6 +30,7 @@
   const void                                *buffer,
   size_t                                     size,
   Objects_Id                                 id,
@@ -122,7 +123,6 @@ CORE_message_queue_Status _CORE_message_queue_Submit(
      *  would be to use this variable prior to here.
-      Thread_Control  *executing = _Thread_Executing;
       ISR_Level        level;
1.7.7
